Sponsored by:
Sponsored by: CARiD
New 3.5L IM
Old Sep 14, 2006 | 06:30 PM
  #81
BlackBIRDVQ's Avatar
drag racing is for wussies
We've talked on the phone today, the manifold most likely is going to be a dual runner setup. I have to take some pictures, some more measurements etc....
It won't be plastic composite BS that our cars came with stock (DE-Ks atleast) so there should be no problem with VIAS rod cup breaking.
If everything goes well we might have the manifold in works in about 2 weeks.
Old Sep 14, 2006 | 07:27 PM
  #82
Nismo3112's Avatar
Custom User Title
^^ Good luck with everything Mike.
Old Sep 14, 2006 | 08:07 PM
  #83
MAXDADDY98's Avatar
Maxima.Org Bishes
Mike I'm Down I'm actually suppose to head up to Wisconsin to fix Waterpump and Ball Joints unless you can assist with that but back too topic Throw me on the list. But the only thing I will need to get with my IM is 6holes drilled for the Direct port Nitrous that I have on my existing IM.
Old Sep 14, 2006 | 08:10 PM
  #84
chinaonnitrous1's Avatar
Wow, mebby I should stick one onto my G20..
Old Sep 14, 2006 | 10:19 PM
  #85
michaelnyden's Avatar
subscribing....!!!
Old Sep 15, 2006 | 05:57 AM
  #86
NmexMAX's Avatar
dot dot dot ...
............... there you go..
Small, yes... but the cruves are most important here.
Old Sep 15, 2006 | 07:45 AM
  #87
meximax's Avatar
SC Overspinning Swapper!!
Originally Posted by Hoooper
was the dyno you just showed us BEFORE or with the spacer?
The Z33 dyno includes the spacer.
you tuned your Z33 IM for A/F, did you do that to the stock one? a few people have made those gains with altering the stock manifold.
No, I did not tune for A/F on my FWD IM. I spent my dyno runs tuning for a safe tune with my JWT/Nitrous ECU and still hit 400 ft/lb to the wheels.
Just look at the curves on my dyno chart :
Just kidding, here is the real uncorrected dyno graph:
Old Sep 15, 2006 | 12:49 PM
  #88
Hoooper
i think you need a better picture, it looks like the graph does a loop at around 2-3k
Old Sep 15, 2006 | 05:04 PM
  #89
NmexMAX's Avatar
dot dot dot ...
2.-3k .. I'm an A3B auto...
It's in th dyno forum, as with all my others....Tq converer raped me... I was a dyno newbl3t.
Using a right click anyone can make tht pic bigger, I sized it down becaus I didn' wanna rape the thread w/ big azz pics.
Old Sep 22, 2006 | 06:47 AM
  #90
mdemonte's Avatar
Any updates
Old Sep 22, 2006 | 04:35 PM
  #91
95maxrider's Avatar
Lightly modded
When was the last time you were on a dyno?
Old Sep 22, 2006 | 06:38 PM
  #92
Here is the update....
IM will be dual stage... and it will look VERY close to this.
It won't be identical but it will use a Honda-like intake manifold as they are know and proven to flow the best at all RPMs.
I will be going to the dyno again before the intake and after. I will also tune for THE best power with EU on VIAS and best power on the custom intake. See which one makes most power.
Old Sep 22, 2006 | 07:12 PM
  #93
NmexMAX's Avatar
dot dot dot ...
dual stage FTW...
Hmmm
Old Sep 23, 2006 | 10:17 AM
  #94
Jay.Are's Avatar
4G63
Progress looking well, looking forward to the results.
Old Sep 26, 2006 | 08:41 AM
  #95
VQ30GTR's Avatar
Im Q.
Mike,
would a P&P on the heads help this mod when available? Seems like it should almost be done if you add the new IM. And do you know anyone good enough in the Chicago area to do a good flow job?
Old Sep 26, 2006 | 08:43 AM
  #96
VQ30GTR's Avatar
Oops, almost forgot.
looks like with that style of IM, maybe you could sit something on top of it-like a roots S/C?
Old Sep 26, 2006 | 09:22 AM
  #97
from the guys I contacted regarding P&P on our heads that have done vq heads and have a great reputation said most of the gain would not be from polishing the actual combustion chamber or the pent roof/quench areas, but rather from doing the valves and the valve ports really well is where the vq heads are lacking. In addition, they stated that if you so choose to go all NA, you could have the heads milled/decked to increase compression somewhat. So it might not be a bad idea to have the done all at once with this manifold, cams, and valve springs (since all the labor is connected in a way), but then you are talking about $$$ and an NA monster!
Old Sep 26, 2006 | 04:11 PM
  #98
Fr33way™'s Avatar
Wild for Width
Interested in the progress. Good going Mike.
Old Sep 26, 2006 | 07:04 PM
  #99
You can't mill the heads too much, as the timing chain will have too much slap and it will result in catastrophic engine failure if the chain where to skip - especially on a high reving NA motor.
I'm trying to secure a intake manifold, I will have pictures of the one I got hopefully tomorrow and I will get going on the whole job. In the mean time I think I could get a roots blower "kit" made for our cars. I just dont know how well it would "flow" at top end and if the bottom end would hold up to instant boost. I have a feeling it would be quite a gain. I have to see if I can get my hands on a upgraded or even a stock GM 3800 Series II blower.....
Old Sep 26, 2006 | 07:55 PM
  #100
bigirish's Avatar
^ That sounds like a great idea. Is that the blower used for the Grand Prix, etc.?
Old Sep 26, 2006 | 08:15 PM
  #101
Hoooper
yeah, should be the same one
Old Sep 26, 2006 | 08:23 PM
  #102
Yeah same as the GTP, but I am thinking of something that is more efficient and can supply more air.... those blowers are not too expenssive. I could get my buddy to make an adapter plate so it bolts up to the stock lower IM and a piece that would connect the TB to the blower. Basically a KIT along with a pulley and tenssioner. You would buy the blower on your own.
Old Sep 26, 2006 | 09:25 PM
  #103
according to some shops that have done a lot of vq35 heads, they can mill them quite a bit as the chain tensioner has some adjustability...but you have to keep in mind that even a tiny bit of milling results in huge changes in compression...so when those shops say quite a bit, they mean .0something"...lol
Old Sep 26, 2006 | 11:14 PM
  #104
Nietzsche's Avatar
I am very interested in how this turns out. My list just got bigger.
Old Sep 27, 2006 | 06:13 AM
  #105
Luquire's Avatar
Damn you guys. I am drulling right now. I was thinking of getting a motorcycle but i think a new engine with a roots supercharger is a better deal.
Old Sep 27, 2006 | 08:20 AM
  #106
bigirish's Avatar
That sounds very excitiing. I wish this was available right now! Would the 3800 GM blower be the most affordable and most compatible for our set-up?
Old Sep 28, 2006 | 08:20 AM
  #107
VQ30GTR's Avatar
Hey,
any idea of how many benjamiins we are talking? no cams, just the valve job? Where is your guy located?
TIA.
Old Sep 28, 2006 | 08:23 AM
  #108
VQ30GTR's Avatar
Mike,
Why not one of the S/C from a Xterra?
Old Sep 28, 2006 | 08:37 AM
  #109
tavarish's Avatar
fwd gone rwd cr00
Hood clearance would definitely be an issue on any roots type blower. But i wanna see the gains from this manifold.
Old Sep 28, 2006 | 08:39 AM
  #110
grey99max's Avatar
LandShark has Cosworth
Originally Posted by VQ30GTR
Mike,
Why not?
It's kinda small, and the engines are different, but it looks good....
This one is on my 2003 Frontier SC....
http://i48.photobucket.com/albums/f2...3/DSCN0645.jpg
that pulls my car: http://i48.photobucket.com/albums/f2...xOnTrailer.jpg
Old Sep 28, 2006 | 08:49 AM
  #111
MAXSE5SPD's Avatar
doesnt an xterra use the same eaton m90as the 3800?
Old Sep 28, 2006 | 09:18 AM
  #112
as far as just the valve job goes, he offers what they refer to as a "head refresh" consisting of these services:
Complete Teardown
Complete Visual Inspection
Check All Surfaces for Straightness
Inspect Valve Train for Wear
Fully Degreased & Cleaned
Competition Valve Job
$350
or you can go with the next level they offer:
This includes porting intake and exhaust bowls and short side radius
Match intake and exhaust 36 mm into ports
Competition mult-angle valve job
Hand lapped & vacuum tested valve seats
Lap deck and gasket surfaces
Deburr, clean, and reassemble
$750 +$60 for any milling
of course there are many levels and work above this which start to go way up in price after this...
www.dprracing.com
they are in gardena, ca
Old Oct 9, 2006 | 07:09 PM
  #113
03maxima1's Avatar
Any news mike?
Old Oct 9, 2006 | 08:02 PM
  #114
michael... is that PER head or for both heads ? I have a local machine shop that will do everything but porting for the same $$$. I use them on regular basis and I am very satisfied with the results.
intake manifold idea has been scrapped for the supercharger project. Unfortunatelly the manifold I wanted to use would require way too much work to make it cost efficient. Manifold I was trying to use was a magnesium unit off a 04-06 Acura TL. It flows very well and has dual stage design.... its pretty cheap new and thats why I wanted to use it.
I will have to use a M90 SC off a Bonneville as the ones off the Xterra are hard to find- althou I see 1-2 on Ebay, they are not as eassy to find as the 3800 ones. Basically what I am aiming for is a SC starter kit that will allow you to buy a SC of your own and use our parts to install it on the motor. This would make the "kit" cheaper to purchase. Only thing I would leave out is ofcourse any kinda computer programming- like Emanage Ultimate. My car will be the test car for this project. I have a EU that I will tune and I could share my base program with people here so they could get the car runing safe from the get go.....
Old Oct 10, 2006 | 08:28 AM
  #115
95naSTA's Avatar
If your going to use a s/c from a 3800, use an 04+ Gen V m90. They are less of a heat gun than the 96-03 Gen III m90.
The Gen V gained 20 hp stock over the old Gen III. There were a few other minor tweaks but the efficiency was the better part of the hp increase.
With your higher compression VQs you'll definitely want the extra efficiency to keep outlet temps down.
Old Oct 13, 2006 | 05:49 PM
  #116
bigirish's Avatar
^^ Yeah, I was just on ebay looking for blowers, and saw several GM 3800's and only saw three Xterra superchargers.
How much clearance is this going to demand do you think?
Old Oct 14, 2006 | 03:45 AM
  #117
clborden's Avatar
I was really hoping this IM became a reality. Anyway, I'll be following your progress on this new endevour. This seems like an inexpensive alternative to the other kit available.
Old Oct 14, 2006 | 09:29 AM
  #118
Jay.Are's Avatar
4G63
Very disappointed the IM project was scrapped but at this point I'm more interested on a supercharger kit anyway. Make this happen, I will buy it!
Mahmuth
Sep 17, 2015 11:45 AM
soloist3
29
Sep 1, 2015 03:47 PM
95naSTA
Aug 16, 2015 05:03 PM
95naSTA
Aug 16, 2015 05:02 PM
Mike S.
Mar 16, 2001 05:53 AM
