Sponsored by:
Sponsored by: CARiD
WHY is this not a sticky!?!
Old Oct 14, 2006 | 11:12 AM
  #121
Cdg2125's Avatar
So I checked my VIN and the 12 letter on the second level is U. Which means I'm fed spec right? I was confused because I read that U was fed spec but my vapor box is in the back left which is said to be on Cali spec....weird.
Old Oct 14, 2006 | 01:55 PM
  #122
Tatanko's Avatar
Bacon Lover
U is Fed spec, correct.
Old Oct 14, 2006 | 04:06 PM
  #123
Cdg2125's Avatar
Good to know. I can use that #2 for my PCV hose. Also, does the stock egr diaphragm (hat looking thing) fit the 00 egr guide tube?
Old Oct 14, 2006 | 05:29 PM
  #124
Tatanko's Avatar
Bacon Lover
The EGR guide tube bolts to the EGR valve, not the diaphragm. The valve uses the same hole/bolts, etc. and bolts right up. I've been told you need to bend the tube a little though
Old Oct 14, 2006 | 09:49 PM
  #125
Cdg2125's Avatar
So that little cap thing doesnt sit on the egr tube anymore? Where does that go?
Old Oct 15, 2006 | 05:27 AM
  #126
toddemullins's Avatar
The 00 EGR guide tube should line right up to the hole in the upper intake. The key is leaving the lower part of the guide tube loose, tighten the plate to the upper, then tighten the lower part of the guide tube to the EGR plumbing. There should be no bending involved as far as I saw.
Old Oct 15, 2006 | 05:33 AM
  #127
Tatanko's Avatar
Bacon Lover
Mine never had anything to do with my guide tube I'm not so sure what you're even referring to now. Could you take a pic?
Just going by what StreetzLegend told me I didn't use a guide tube (although I have one). I blocked my EGR off
Old Oct 15, 2006 | 05:49 AM
  #128
I had heard of people bolting down the lower bolts, then trying to make the top plate line up with the upper by bending it. I guess that is where common sense and some automotive experience comes in.
Old Oct 15, 2006 | 06:41 AM
  #129
Tatanko's Avatar
Bacon Lover
Which are two things that come in VERY handy with this swap
Old Oct 15, 2006 | 08:30 AM
  #130
Cdg2125's Avatar
Well I'll try to snap a pic later. Maybe it's just the 4th gen egr. Idk. Anyway, Tatanko are you gonna sell that 00 guide tube? Cause I need one.
Old Oct 15, 2006 | 11:24 AM
  #131
Tatanko's Avatar
Bacon Lover
Yep, I'll sell it to you if you want it. Send me a PM, I'll see it tommorrow (going to Pittsburgh tonight until tommorrow).
PH98I30
29
Feb 10, 2025 12:03 PM
Tiniform
Dec 25, 2015 07:40 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
bill99gxe
Jun 15, 2001 11:38 AM
PrinzII
May 8, 2001 04:03 PM
