Sponsored by:
Sponsored by: CARiD
Prepped VQ35 from 95 to 00-01?
Old Oct 12, 2006 | 09:12 PM
JClaw's Avatar
Fairly lightweight question here.
I've got a VQ35 w/ VQ30 timing chain that was prepped with 1995 sensors and timing assembly. I know all major sensors from 95-99 to 00-01 are still the same but the electrical system/ECU in the last few years is somewhat different.
Would it drop right in and fire up fine in a 2000-2001, so long as the complete wiring harness from the 00-01 is used?
Old Oct 13, 2006 | 02:49 AM
MDeezy's Avatar
I would assume it should work in a 00-01.
Since the DEK timing equipment can be used to prep the motor and work in a 4th gen then it would be natural to assume it can work vice versa. Since both DE and DEK look for the same signal output from the sensors.
Old Oct 13, 2006 | 03:25 AM
matty's Avatar
Itll work but I believe youll probably have to change the ECTS (coolant temp sensor) cause its a differnt type and probably the cam sensor (top one on the timing cover). Also remember that the EGR valves on the 00-01 are electronically controlled, NOT vaccum
-matt
Old Oct 15, 2006 | 07:43 PM
Weimar Ben's Avatar
Helicopters! Money!!!
the cam sensor is the same from 95-2001. As matty said, the ects and egr are different for 00-01.
Old Oct 15, 2006 | 07:56 PM
nismology's Avatar
The DE-K uses 2 ECTS's just like the DE. It's the VQ35 that uses 1 sensor for both the gauge and the ECU.
mclasser
22
Nov 12, 2020 01:58 PM
soloist3
29
Sep 1, 2015 03:47 PM
Balkins
Aug 9, 2015 02:48 PM
