Sponsored by:
Sponsored by: CARiD
coil firing Qs
Old Nov 19, 2006 | 08:26 PM
95turbo gxe's Avatar
coil firing Qs
Im wondering if anyone know how the ecu fires the coil packs? Is it from negative pulse or postive pules.
Old Nov 19, 2006 | 09:43 PM
grey99max's Avatar
LandShark has Cosworth
The FSM manual shows a 4-volt positive-going pulse to fire the plug... I've been digging into this subject lately.
Old Nov 20, 2006 | 07:28 AM
Fred Allen Burge's Avatar
The coil is always hot (if the key is on) and the ECU grounds the proper wire to complete the circuit. The ECU doesn't send a + signal to the coil.
Fred
Old Nov 20, 2006 | 08:21 AM
LA02MAX's Avatar
Fred
hmm, learn something new every day. I always thought it sent a + signal to fire them.
Old Nov 20, 2006 | 08:50 AM
NmexMAX's Avatar
dot dot dot ...
This practice is very common with Nissan. (GND)
Old Nov 20, 2006 | 09:44 AM
eng92's Avatar
Fred
That is how the injector circuit works. That is NOT how the ignition circuit works.
If you look at the wiring diagrams in the FSM, you will see that there is an NPN power transistor in each ignition coil. The ecu is connected to the base, the emitter is connected to ground and the collector is connected to the primary side of a transformer which is also built into the coil.
To fire the plug, the ecu sends a pulse signal (~+5V relative to GND) to the base. This "closes the switch" allowing current to flow in the transformer primary (12V - collector to emitter - GND) The high voltage induced in the transformer secondary causes a spark to jump to ground via the spark plug.
Old Nov 20, 2006 | 12:05 PM
grey99max's Avatar
What I said......
Old Nov 20, 2006 | 06:37 PM
can some one test and see what kind of voltage is present at the coil connecter(unpluged from coil) Check the 1 red wire and ground it to the 2nd wire and see what kind of volts you at the connector
Old Nov 20, 2006 | 07:36 PM
grey99max's Avatar
The red wire is at battery voltage when the key is on / car is started.
Connecting the red wire to anything else isn't recommended -- fuses blow or coils slag down !
Old Nov 20, 2006 | 08:02 PM
OK I WAS saying connect a muti meter to the red wire and then ground it to see how much voltage it has stock. Im having problem with the eu install of melting coils and my voltage is at 23.0 volts.
Old Nov 21, 2006 | 09:16 AM
Does anyone know what it should test stock at the coil?
Old Nov 21, 2006 | 09:47 AM
eng92's Avatar
^^^^^^^ What he said ^^^^^^^^
Are you back-probing the coils to check the voltage?
Old Nov 21, 2006 | 11:54 AM
im putting the red probe on the red wire at coil connecter(1st wire)and putting the ground probe on the engine from the multi meter
Old Nov 21, 2006 | 12:17 PM
grey99max's Avatar
Er.. Is the meter set on DC volts? Is your ground wire (black probe, I guess) on the engine block - hard ? If you do that, leave the black lead on the block, lift the red lead and touch the + battery terminal. With the car off, should read about 12.5 - 13.5 volts, depending on charge.
The red coil wires - they are all connected together - should read the same as battery voltage, whether key is ON or engine is running.
Old Nov 21, 2006 | 04:00 PM
yes its on dc. But mine are reading higher maybe due to emanage ultimite!
Old Nov 21, 2006 | 06:52 PM
eng92's Avatar
Unplug all six coils and the three emanage connectors.
Measure the DC voltage between any coil connector red wire and the engine grounding point with the ignition ON.
Old Nov 25, 2006 | 01:33 PM
I stand corrected, I guess I was wrong. I thought they worked more like a relay. I still don't understand all of your terms in relation to the FSM's coil diagram but I'm trying. Can you tell us which part of the coil diagram (EC 118 for the 95 Maxima electronic FSM) correlates to which of your terms?
thanks,
Fred
Old Nov 25, 2006 | 09:27 PM
eng92's Avatar
thanks,
Fred
You will find a thousand pages or more that will explain transistor terminology better than I can.
http://www.talkingelectronics.com/Fr...ts/Page10.html
You can use the figures in the above link and reference them to the wiring diagrams in the FSM.
TKHanson
Nov 24, 2018 01:39 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
zmcneely13
Sep 26, 2015 02:26 PM
