Sponsored by:
Sponsored by: CARiD
Thoughts on 5spd Auto swap?
Old Feb 7, 2007 | 03:00 PM
Cdg2125's Avatar
I'm not sure how this thread will go over but I was just curious. I know you guys know a **** load about customizing to fit 3.5 and all the other swaps so I'm curious what the difference is on the bolt patterns of the 05 5spd auto tranny w/ manual mode (the gate shifter). I'm guessing its not possible to make it work with the 3.0 because of the patterns and ECU. Not sure how the VDC would come to play in this either. Has anyone used this with a 3.5 swap? Just wanted to see what kind of stuff is out there on this.
Old Feb 7, 2007 | 03:13 PM
Kevlo911's Avatar
Kevlo for President
We have discussed it a few times, search for some threads.
Old Feb 7, 2007 | 03:14 PM
Nismo3112's Avatar
Custom User Title
It's probably possible if you really want it done......But why on earth?
Old Feb 7, 2007 | 03:21 PM
Zack342's Avatar
Your better off with manual swap.
Old Feb 7, 2007 | 06:34 PM
Cdg2125's Avatar
I know everyone will say a 5spd is better but I don't want the manual. My family needs to be able to drive the car in case of emergency or whatnot, and the only one in my family that can is my father. I actually like having an auto most of the time and having the manumatic would be real nice. I think it would do good in the 4th gen as well. Unfortunately I can't search on the org so I didn't know where to go. I didn't expect much more response.
Old Feb 7, 2007 | 06:47 PM
Kevlo911's Avatar
Kevlo for President
If you want a manumatic, make the 4switch mechanism some of us are using. It is called the "shiftfast" mod and the thread is on page 1 of hte all motor forum.
Old Feb 7, 2007 | 08:48 PM
Cdg2125's Avatar
Yeah I know I started the thread. It's not a manumatic tho. I don't want to have to control the downshifts. The shift_fast everyone is making with the 4 gang was my idea. Well not full credit but the topic was posted by me. Greymax and tatanko helped me out on the wiring. I never got to do this because the thread got so off topic. I don't want anything to do with the tc. Just wanted to get the shift_fast having 1-4 working. Nobody posted on having 4th gear working. I know you had one made kevlo. Do you have all gears working?
Old Feb 8, 2007 | 08:44 AM
pmohr's Avatar
No more Maximas...
I posted what I believe is the key to 4th gear, but no one has tried it yet, best I know.
Old Feb 8, 2007 | 09:38 AM
Kevlo911's Avatar
Kevlo for President
Leave it in drive then. I don't understand what you want. In "manual mode" in automatics, it will stay in the gear selected(ie 4bang switch) you can somewhat force downshifts and control upshifts.
Old Feb 8, 2007 | 11:34 AM
grey99max's Avatar
LandShark has Cosworth
Refresh my brain again - what was your idea/thoughts on the 4th gear issue??
I've got a pushbutton shift_fast module installed, but never tried fourth gear. Too busy spraying and electric-clutching, and I forgot about fourth gear...
Old Feb 8, 2007 | 11:53 AM
Cdg2125's Avatar
The manumatic itself controls downshifts. All you have to do is upshift when you want and it will downshift as you slow. The 4gang switch doesnt do that. You have to shift up and down. I don't feel like its a great idea to down shift in the auto. I was just trying to see if it was possible.
Old Feb 8, 2007 | 12:09 PM
pmohr's Avatar
No more Maximas...
Cut power to the overrunning clutch solenoid when you try to use 4th. I can almost guarantee getting 4th with that, can't really be anything else.
Old Feb 8, 2007 | 12:38 PM
Kevlo911's Avatar
Kevlo for President
The only cars that do that is my 03 g35. Our mazda6 and when I drove the 04.5 G's, they don't do it. They are similar to real manuals and stay in w/e gear you pick. You can control the upshifts right now if you want. Floor it and then go into w/e gear its in. Its either gonna be 1 or 2. No need to redline 3rd.
Old Feb 8, 2007 | 01:10 PM
grey99max's Avatar
Interesting - well, that would be easy enough to test out. I've hacked into every other wire going into the tranny, so putting a switch on that wire shouldn't be hard. I can use the clutch control switch - just need to look in the FSM for the wire color and position.
Maybe this weekend - temp here is still in the 'teens, and I don't like to get that cold. Thanks...
Old Feb 8, 2007 | 04:17 PM
Cdg2125's Avatar
So you think it's possible to wire the 4th gang switch to turn off power to the clutch solenoid and run power to solenoid B?
Old Feb 8, 2007 | 06:30 PM
grey99max's Avatar
If - If that does it, then I can - the quick answer is to use a small 12 volt relay piggybacked onto the 4th gear switch, to pick and open the circuit to the overrun solenoid... The relay should pass whatever the TCU is sending to the solenoid, and interrupt it when in fourth gear.
Actually, shouldn't it disconnect when the pushbutton bank is engaged, when the switch is in RACE and not NORMAL?? That covers everything, I think.
The hard part is not the circuit, it's figuring out exactly what should happen and when.
Old Feb 13, 2007 | 10:46 AM
Cdg2125's Avatar
sounds like more work than I thought. Has anyone done a 3.5 swap with the 5spd auto tranny? How crazy would that be? Need new mounting and ecu? what would come with trying that swap?
Old Feb 20, 2007 | 11:36 AM
NmexMAX's Avatar
dot dot dot ...
x2
http://forums.maxima.org/showthread.php?t=402818
Old Feb 20, 2007 | 12:43 PM
Cdg2125's Avatar
Thanks for that link. Helped out a lot. So there was never any progress on it huh?
Old Feb 20, 2007 | 12:56 PM
NmexMAX's Avatar
dot dot dot ...
Nope. I talked through my **** and never pursued it.
I had a very quick short/crash course w/ the TCM & wiring as of late that may have helped me gain experience in that direction.
Haven't counted it out yet. Need a commuter car though
Old Feb 20, 2007 | 01:40 PM
Cdg2125's Avatar
gotcha. Well keep me posted if you ever develop anything. 3.5 isnt in the picture for a while.
220k+ A32
Sep 11, 2015 02:18 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Maxboy23
Sep 9, 2015 10:37 AM
robtroxel
Sep 8, 2015 08:15 PM
mpbclutch33
Sep 8, 2015 06:21 PM
