Sponsored by:
Sponsored by: CARiD
6 Speed Starting Problem
Old Jun 12, 2007 | 09:34 AM
95turbo gxe's Avatar
Ok where should I start! Well I got the 6speed swap all rapped up. But I been having this stating problem from day one. When you spin it over it will turn a few times and then get binded up and will not turn. If you go to the crankpulley side and try to turn it by a breaker bar it will not turn. If you take the starter out and then try to turn it by the breaker bar it will rotate. You CAN ONly get the car to crank once out of 20 trys. I used the 350z flywheel and the maxima 6speed starter. OK well you say well maybe its the 350 flywheel but sr20 used one maybe he can chime in. Ok well MAXSE5SPD did this this swap also and used the 350 flywheel at first and then swap to the maxima 6speed flywheel and still has the binding issue going on too. So what gives he has the right starter flywheel and tranny.
Old Jun 12, 2007 | 10:08 AM
Kevlo911's Avatar
Kevlo for President
Drop tranny and see what is rubbing if anything is
Old Jun 12, 2007 | 02:24 PM
I have took the starter out and had my friend rotate the crank to look and cant not see anything wrong.
Old Jun 12, 2007 | 02:41 PM
Kevlo911's Avatar
Kevlo for President
RPM needle funky when attempting to start?
Old Jun 12, 2007 | 02:45 PM
nah not at all the cps is good no problem with it crank that way just it get binded up!
Old Jun 12, 2007 | 04:59 PM
nismology's Avatar
Any odd noises when it starts to bind?
Old Jun 12, 2007 | 05:22 PM
MAXSE5SPD's Avatar
heres a pic of charles's starter. his internet is fcukin up
Old Jun 12, 2007 | 05:24 PM
nah it just goes bam and then binds up
Old Jun 12, 2007 | 06:20 PM
Nismo3112's Avatar
Custom User Title
Did you try engaging the starter with it out?
Old Jun 12, 2007 | 08:14 PM
yeah and it works great!
Old Jun 14, 2007 | 07:39 PM
any other ideas?
Old Jun 17, 2007 | 07:42 AM
XJinCT's Avatar
<3's the all motor section
i read everything. but i stil feel its the 350z flywheel man. why not just use an oem 6 speed maxipad flywheel?
Old Jun 17, 2007 | 05:39 PM
MaxObesset's Avatar
i got an oem 6 speed flywheel got no issues with my setup if you need more info contact maxtuning in ny
Old Jun 18, 2007 | 06:32 PM
how can I contact them?
Old Jun 18, 2007 | 09:11 PM
Kevlo911's Avatar
Kevlo for President
Searching for their website and call or yellow pages online and call... There is enough info on this forum if you just search on how to use the oem flywheel
Old Jun 19, 2007 | 09:00 PM
mforrest100's Avatar
Yeah...Jeff did this swap like 2 years ago...ask him...
Old Jun 20, 2007 | 05:02 AM
yeah who is Jeff?
vingodine
45
May 21, 2016 12:46 PM
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Tha'-Max
Aug 30, 2015 01:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Gsantos79
Aug 8, 2015 07:41 AM
