Sponsored by:
Sponsored by: CARiD
techno squares ECU
Old Jun 22, 2007 | 06:39 AM
midnight0045's Avatar
techno squares ECU
heyy just wondering if anyone has this ecu upgrade installed with the MEVI?? all the talk is with the JWT and the MEVI being a great combination for all around power but with the techno squares ecu? much difference? or generally the same result between ECU's?
Old Jun 22, 2007 | 06:43 AM
NmexMAX's Avatar
dot dot dot ...
TS does not reprogram A32 ECU's any longer. But, in order to answer you question:
It would be an upgrade since they do advance timing, and you will gain the midrange that you lost. BUT, you will not have an extended rev limiter in order to take advantage of the MEVI 100%. IMO, this is a question better suited for the 4th gen area.
Old Jun 22, 2007 | 06:48 AM
noted, i knew the rev limiter wasn't there but just wanted to see if one had the set up and could give first hand experience
Old Jun 22, 2007 | 06:57 AM
NmexMAX's Avatar
dot dot dot ...
So what are you looking for, a dyno, timeslip? I cannot give you first hand experience, so I did have a JWT ECU
Old Jun 22, 2007 | 07:27 AM
DandyMax's Avatar
3.5 in the works
Welcome to 3 years ago (or more? ). If you do some searching around there are lots of old threads on both ECU's. But both those ECU's are "old-tech" now. In terms of performance with the MEVI, I'd give the edge to the JWT just for the rev limiter. Other than that they were pretty comparable.
If I were you I'd forget both and get an EU. You'll spend the same amount just about and get WAY more.
Old Jun 22, 2007 | 07:36 AM
NmexMAX's Avatar
dot dot dot ...
x2
But if you were him, then he'd be you and you'd be him, so...
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
