Sponsored by:
Sponsored by: CARiD
Stock MAF Housing VS Big Bore MAF Housing (76.2mm ~ 3") Technical Discussion
Old Jul 17, 2007 | 11:36 AM
  #41
harmbone2k2's Avatar
6yrs old=36,500 miles :)
Originally Posted by NmexMAX
Little tweaks @ what? You can do everything SR mentioned in an hour, AND get at least 4 runs in (part of #2 on his list).
Maybe he doesn't have as much time as other people do.
Old Jul 17, 2007 | 12:13 PM
  #42
NmexMAX's Avatar
dot dot dot ...
That's a commonly misconceived view around here.
People get dyno time and do not take full advantage of the time they have. There is an entire thread on this in the dyno forum. I'd suggest reading it thoroughly before going to dyno.
To answer your question, if he rented the dyno for some 'tuning' time, then an hour is a very common timeframe, and as SR stated, if he cannot get those items done, he is not doing it right. All my sessions were an hour, and so were probably many other people on here. That is more than enough time to get a decent AFR. This eliminates the concept that 'he may not have as much time as me'.
Old Jul 22, 2007 | 05:41 PM
  #43
AuAltima3.5's Avatar
You have to get a dyno after a couple hundred miles of driving.
O2 readings aren't used at WOT, but what does the car do then for AFR at WOT? Just dump in a fixed amount of fuel?
I have a feeling the computer will relearn and richen up the mix again via O2 readings.
Old Jul 22, 2007 | 05:48 PM
  #44
NmexMAX's Avatar
dot dot dot ...
Why? ECU compensation time?
MAF & CPS/TPS. This thread sorta proves this to a certain degree.
Not @ WOT.
Old Jan 10, 2008 | 10:26 AM
  #45
Any updated info on this being made?
Old Jan 11, 2008 | 11:42 AM
  #46
krismax's Avatar
Father of the 00 VI
i dont think ive ever seen this thread.
iam gonna check lb per minute airflow with a slightly bigger MAF vs stock
ill try a few RPM points
Old Jan 11, 2008 | 06:01 PM
  #47
NmexMAX's Avatar
dot dot dot ...
I’ve done that, you’ll just see a dramatic decrease in airflow depending on how large you go.
Old Jul 5, 2010 | 08:04 PM
  #48
perkman87's Avatar
I see you Moncef
Old Jan 16, 2012 | 07:27 PM
  #49
kurt1's Avatar
So does this mod actually gain power? Is it worth it?
Old Jan 17, 2012 | 12:13 AM
  #50
shrek's Avatar
yeah is worthy....trust me
Old Jan 22, 2012 | 12:56 AM
  #51
kurt1's Avatar
Cheers mate. Im from australia. Does this guy ship out this product?
Old Feb 2, 2012 | 06:28 AM
  #52
95maxrider's Avatar
Lightly modded
So if getting EU isn't an option, what are the results of using a VAFC with a JWT ECU? I seem to remember reading a long time ago that the two didn't play nice together. Or is it possible that JWT could reflash the ECU to compensate for the BB MAF?
Old Feb 2, 2012 | 06:34 AM
  #53
NmexMAX's Avatar
dot dot dot ...
Why isn't an EU an option? Pretty sure it has a MAF scaling option, and if not, there are plenty of members with BBMAF + EU with success.
JWT would charge you your first born and your brand new puppy, and I don't even think they've done it before for our cars.
VAFC works fine with JWT. It's just it(VAFCII) needs to be manually set-up(tune by trial & error using WB) vs, PnP with the SAFCII (MAF scaling option).
Old Feb 2, 2012 | 10:43 AM
  #54
95maxrider's Avatar
Lightly modded
Oh, I wasn't saying EU won't work with the BB MAF, just that I don't want to go through with an EU install and tuning
So you're saying the SAFC is the better option for tuning with a BB MAF and will work in conjunction with the JWT ECU? Interesting....
Old Feb 2, 2012 | 02:41 PM
  #55
shrek's Avatar
VAFC has maf scale too ,i'm using it on my car....i have a VQ30 with a Q45 maf and i have it 1 IN and 4 OUT ijust needed to add a little more fuel(+4%) on most RPMs and a little more up top.... response is incredible with the BBMAF
P.S.i dont have JWT ECU,i have a 4th gen ECU with DE-K injectors, Z33 IM (all 3 pieces),BLOX 1/2 spacer and PFTB
Old May 1, 2019 | 07:31 PM
  #56
Santana777's Avatar
Maf trouble
Originally Posted by maxspeedse02
SR what is your take on running w/o the MAF screen on a bigger MAF? Is it really unnecessary? I have done some searching and found nothing real concrete. Judging by this thread it seems to be ok, would running w/o a screen put more pressure on the sensor reducing it's life or its effectiveness?
my boost sensor quit on me ... maf sensor causing this? And I cant even find wherever this Hitachi boost sensor is located!! I've got an 03 ...5th gen se 6 speed maxima, skyline trans, k&n intake and full stainless exhaust someone please help...??
rmh3093
Aug 31, 2007 04:18 PM
95BLKMAX
Aug 16, 2007 06:15 AM
ornery1
Jul 31, 2006 06:43 PM
Kevlo911
May 25, 2005 08:58 AM
MaMasMax
26
Jul 3, 2002 06:00 PM
