Sponsored by:
Sponsored by: CARiD
VAFCII install help.. CEL
Old Jul 14, 2007 | 08:51 PM
maxima92se's Avatar
I I just installed my VAFC and it just triggered a CEL.. The rpm is reading about 150rpm @ idle and its not reading anywhere 800rpm that the tach is reading. I am going to autozone to have them pull the codes 2mrw but if someone can give me some info on what i did wrong and i will spend the nite reading through the manual. Thank you.
Old Jul 15, 2007 | 05:55 AM
Kevlo911's Avatar
Kevlo for President
Double check your wiring
Old Jul 15, 2007 | 09:27 AM
dfownz's Avatar
You need to set up some basic things in it before you can run it. Its probably not reading correctly because you have it set to the wrong motor size. Make it 6cyl with an upwards arrow for the throttle setting.
As for the cel, its probably the MAF sensor, as that's the only wire you cut (unless vafc is different from an safc).
DF
Old Jul 15, 2007 | 09:53 AM
machinehead131's Avatar
Make sure MAF wires are connected correctly. Make sure its on 6cyl. Make sure it the sensor numbers are the same. Make sure throttle is up right arrow.
Old Jul 15, 2007 | 11:37 AM
NmexMAX's Avatar
dot dot dot ...
My $'s on that.
Old Jul 15, 2007 | 12:40 PM
97_Roadrunner's Avatar
X2... check wiring and setings; 6 cyl, up arrow, sensor 1 in 1 out...
DF
I have already hooked 2 V-AFC2 and a S-AFC2 and they connect the same way. You only need to cut the MAF wire. The wires colors for MAF signal from V-AFC2 and S-AFC2 are the same.
Old Jul 15, 2007 | 02:50 PM
maxima92se's Avatar
aight guys the code is a P0171 which i am assuming is O2 sensor. I double checked the setting and according to the install instructions the sensor number is 4in and 4out. I am 6cycle and arrow up with vtec set to 1.
Old Jul 15, 2007 | 02:51 PM
NmexMAX's Avatar
dot dot dot ...
If it's an o2 sensor issue, then the VAFCII is obviously not the problem. This is assuming you did not tap into an O2 sensor wires.
Old Jul 15, 2007 | 03:31 PM
maxima92se's Avatar
I did. I actually taped into the o2 in the same bank so i dont know if i could have damaged the O2 sensor. I did a search and it also came up on with maf problem.
Old Jul 15, 2007 | 03:33 PM
maxima92se's Avatar
Maybe i should cut it and see what happens.. i dont need it right because i was going to get a WBo2 for tuning or get a dyno tune.
Old Jul 15, 2007 | 04:27 PM
Okay, you need to slow down and be sure of what you are splicing and cutting. The VAFC changed the MAF voltage...that is how it changes the AFR. You need to cut the MAF wire and connect one end of the vafc to the wire going to the maf and another wire on the vafc to the wire going to the ecu. You don't want to damage anything so you should be very careful and take your time. Be sure you cut the right wire.
Old Jul 15, 2007 | 08:39 PM
For the maf, double/triple check wiring and be certain about sensor in/out numbers.
As for the O2, the V-AFC2 should'nt be wired to the oem O2's, only to a wideband O2. The oem ones ares used mainly for the closed loop operation.
(<3000 rpm and <40% TPS) And not for monitoring your AFR.
They only range from 0 to 1 volt, while a WbO2 will range from 0 to 5 volts.
All AFC's I've hooked-up, were not equiped with a WbO2 and were only BUTTDYNOED. To prevent knocking and beign lean at red line, air/fuel setting were set to a conservative -12 from 3000 to 6000 and -8 from 6100 to 6600.
Old Jul 16, 2007 | 11:17 AM
Between the instructions that came with the VAFC, and GTR's writeup, it should be a slam dunk install. Slow down and
See link.
http://forums.maxima.org/showthread.php?t=519659
Old Jul 16, 2007 | 06:59 PM
maxima92se's Avatar
Okay the rpm is all set.. The only thing is the CEL and its still the o2 front bank lean so i am going to clen the MAF and check the voltages to make sure its still working. I double and triple checked the wiring just to be sure and everything is where its supposed to be. The car runs very clean and revs just fine and i did not change the settings because i dont have the wbo2 to see if i am rich or lean. Thank you for your help guys.
Old Jul 16, 2007 | 07:07 PM
gtr_rider's Avatar
192.168.1.1
remove the wire you connected to the o2 sensor, I really think that is what is causing the trouble.
Old Jul 17, 2007 | 07:51 PM
maxima92se's Avatar
I did. i am just waiting for 60miles to see if the light goes out. If it does then i move to stage 2 to install the VI.
Old Jul 20, 2007 | 06:38 PM
maxima92se's Avatar
Okay guys please help before i sell this freaking car and just buy the one that i wanted.. The code i got now is a P0100 and the P0171. I am going to buy a new MAF and see what happens. but if anyone has any experience please let me. Thank you for your help so far guys.
Excalibur23
Oct 13, 2015 04:33 PM
JoshG
51
Sep 21, 2015 10:41 PM
2kmaximel
Sep 16, 2015 03:19 PM
ballerchris510
Sep 10, 2015 09:35 PM
A32goldylocks
Sep 2, 2015 06:39 AM
