Sponsored by:
Sponsored by: CARiD
Hybrid swap
Old Aug 13, 2007 | 08:04 PM
  #41
nismology's Avatar
My point was that VQ35 headers could be used. Whether or not the OP decides to use them is another story.
OT: Based on dyno evidence the A33B VQ35 made more like 245HP/265TQ. Same as the L31 altima. The extra 15HP that the maxima supposedly had was marketing hype.
IBNmexMAX
Old Aug 13, 2007 | 08:05 PM
  #42
NmexMAX's Avatar
dot dot dot ...
Originally Posted by made in china
Blackwind is trying to do his mods on a budget. I too would like a full-on exhaust system, but for now I am quite happy that my VQ35DE, which makes 255HP stock, will be flowing thru VQ30 manifolds and a Warpspeed Y pipe. I ran out of money for the full exhaust, but the fact that the VQ30 manifolds are larger in diameter, smoother (relative term) than the VQ35 units makes me happy. Hey, they gotta be worth some gains, right? And they are free.
This paragraph is making it seem as if I stated that the stock A33B units are better than the VQ30's. I never said that. At this point, my point is moot, so I will just let you fellas carry on.
Old Aug 13, 2007 | 08:10 PM
  #43
Blackwind's Avatar
he is refering to this:
Originally Posted by scrhale
I don't understand why you are trying to keep your MEVI anyway. I think it was Krismax who discovered that the 3.5 SSIM flows better than 00VI. We all know 00VI flows better than MEVI. We also know that 3.5 heads flow better than 3.0 heads. You are losing every battle here dude.
Old Aug 13, 2007 | 08:16 PM
  #44
nismology's Avatar
scrhale's post was talking about the intake manifolds.
made in china's post was talking about the exhaust manifolds.
Old Aug 13, 2007 | 08:19 PM
  #45
Blackwind's Avatar
READ MY PREVIOUS POST. i DO NOT want a full 3.5 motor in my car. I DONT CARE if you and all the people you know swear by it like its the gospel truth fresh from the burning bush. this thread has gon from me asking a few questions that had not been asked about this setup before to a full out debate on why I SHOULDNT do this swap. as i said before, im not out to impress anyone, all i am doing is choosing one of the many options for performance that we finally have available to us. and yes i am on a strict budget. thats why i asked the specifc questions that i asked.
NmexMAX,nismology, Made-in-china; thanks for clearing the air on some of the questions that i had. if anyone else has anything to add in regards to THE HYBRID MOTOR SWAP please chime in.
thanks.
Old Aug 13, 2007 | 08:29 PM
  #46
NmexMAX's Avatar
dot dot dot ...
thanks.
http://forums.maxima.org/showthread.php?t=437478
http://forums.maxima.org/showthread.php?t=335200
http://forums.maxima.org/showthread.php?t=431185
Old Aug 13, 2007 | 08:33 PM
  #47
Blackwind's Avatar
thanks, the last two i had seen before but i for some reason couldnt find them.
Old Aug 13, 2007 | 10:22 PM
  #48
japmaxSE's Avatar
Go Get a Life!
thanks.
Go for it, it's a simple cheap swap you can do in one day . Being that you have all the parts ready.
I'm not exactly sure what the difference in power is with the 3.5 cams vs 3.0 cams but I used the 3.5's and with a simple SAFCII tune. I got to tell ya I had mad fun with my Hybrid just ask gtr_rider or 95blkmax they were all there when I spanked an RSX S 6spd that I believe had IHE. I had a terrible slipping Auto at that race. I also believe Tilley also mentioned there was a wider range of TQ under the curve with the Hybrid. I can sure as heck agree to that.
Old Aug 14, 2007 | 02:21 AM
  #49
Blackwind's Avatar
ok. thanks for that. ill be keeping it simple by just using the 3.0 cams. i imagine that this is going to be fun after i have finshed.
Old Aug 14, 2007 | 04:09 AM
  #50
nismology's Avatar
More simple? Not really. All you have to do to use 3.5 cams is slap on some spacer/adapters. Cheaper? I suppose.
There are really no advantages to using 3.0 cams that I can think of. Almost 1mm less lift and 6°/8° less duration in/ex. Please don't do it.
Old Aug 14, 2007 | 06:10 AM
  #51
NmexMAX's Avatar
dot dot dot ...
I'm finding that hard to believe.
Old Aug 14, 2007 | 12:06 PM
  #52
NmexMAX's Avatar
dot dot dot ...
More links:
http://forums.maxima.org/showthread.php?t=506364
http://forums.maxima.org/showthread.php?t=401382
http://forums.maxima.org/showthread.php?t=392537
http://forums.maxima.org/showthread.php?t=448760
Old Aug 14, 2007 | 10:27 PM
  #53
japmaxSE's Avatar
Go Get a Life!
Just to make sure I'm clear on this, I'm not comparing the Hybrid to a full 3.5 setup but a 3.5 on a 3.0 Ecu.
In this case they both have the same stroke of 81.4mm but the compression says it all. The higher the static compression the more powerful the explosion.
Hybrid 11.5:1 comp
EDIT: VQ35DE on 3.0 ECU 10.4:1 - 5.5gen 10.3:1
EDIT:
In general the Hyrbrid does have an edge down low but up top in the rev range the VQ35DE on 3.0 ECU should benefit allot more.
Only if we had a dyno graph of the Hybrid setup, that would be real nice to see if it's even worth the effort.
Old Feb 2, 2009 | 10:17 PM
  #54
JAMAICANLOVRBOY's Avatar
what are PROs and CONs of doing a hybrid swap as appose to a full vq35 swap, i have a 98 maxima and i'm gonna be doing the full 3.5 swap. i have a s-afcII, and got it tuned with the 3.0, wont that make a difference since i'm using the 3.0 ECU with the 3.5 motor?.. i have a 95 spd ECU to send to JWT later to get it really running good.
Old Feb 3, 2009 | 12:22 AM
  #55
nismology's Avatar
JAMAICANLOVRBOY: There is tooooo much info for me to stand by and not say anything about you looking up info for yourself. Do you need some help with using the search feature?
Old Feb 3, 2009 | 12:28 AM
  #56
so much info, and different opinions. i'm gonna just do the 3.5 swap, run my S-AFCII A32 ECU for now, and later get the jwt programmed ECU. i have a y-pipe, and stillen 2.5" catback, that should be good for now. i cant find a good set of headers, most companies selling y-pipe header combo.(98 maxima 5spd)
Old Feb 3, 2009 | 01:26 AM
  #57
DrunkieTheBear's Avatar
Turbo'd Saab
Uh cattman sells a good header/y combo...ebay is not the only place to resource parts.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
