Sponsored by:
Sponsored by: CARiD
Tuning, OBD-II Style
Old Aug 16, 2007 | 09:52 AM
DasYears
i have access to a Snap-on OBD-II scanner and i swear that i remember seeing AFR on the tool. i have used it before and i remember there being graphs of AFR (13.0-15.0 at the time). now since ive picked up a VAFC-II, would it be possible to tune this way? or would it be too inaccurate since its still with a narrowband? planning to dynotune soon but i was hoping i could get it close before that so that it could be really fine tuned at the dyno. what do you think?
PS: the scanner is one of the absolute newest models, my gf's dad is a snap-on salesman so i have access to some pretty new and cool stuff, which i just realized i can use to my advantage
Old Aug 16, 2007 | 09:56 AM
KRRZ350's Avatar
It would deffinitly be inacurate since it's just working off the narrowband o2's, but you already new that, I plan to do the same thing before I go to the dyno though, def. not a bad idea at all to give it a rough tune before you go, it will also help you to be able to program the vafc-II quicker
Old Aug 16, 2007 | 10:07 AM
DasYears
yeah thats basically what i was thinking. i wonder how inaccurate the narrowband is. could it be like +/- 5%? or you could be looking at 13.5 and actually be getting a 14.0...i figure i will tune it for rich and lean it out at the dyno. maybe i can get ahold of a snap-on wideband...
Old Aug 16, 2007 | 10:09 AM
nismology's Avatar
Unless you want to tune between 14.5:1 and 14.9:1 AFR the narrowband "rich/lean" sensor signals are completely worthless to you.
Old Aug 16, 2007 | 10:12 AM
Jeff92se's Avatar
I'm needing a caw
Unless you have a newer maxima featuring widebands. Ala 05+ G/Zs.
Dang. I should have bought a 05+ G. Osyris + email maps + data logging using w/b + not requiring a dyno or expensive add on w/b = FTW
Old Aug 16, 2007 | 10:26 AM
DasYears
Originally Posted by nismology
Unless you want to tune between 14.5:1 and 14.9:1 AFR the narrowband o2 signals are completely worthless to you.
it wont show below 14.5? or does it show the same signal after that? im not really familiar with NBO2 operation. so does it give the same signal voltage for every value below 14.5 and above 14.9?
Old Aug 16, 2007 | 10:28 AM
nismology's Avatar
Everything below 14:7:1 will just show up as a rich reading. Everything above that will show up as a lean reading. In terms of voltage, anything below stoich will show as .1v, and anything above will be .9v. That's why I like to call them rich/lean sensors because they have no clue what the actual AFR is.
Old Aug 16, 2007 | 10:40 AM
Jeff92se's Avatar
I'm needing a caw
a/f guage and narrowband = light show, light show! hehe
Old Aug 16, 2007 | 10:46 AM
DasYears
lol. damn that sucks. well i guess im gonna be hoping he has a WB sensor laying around...
PS: as for connecting the VAFC, im not the best at soldering, so i was thinking about using t-tap connectors, like these: T-tap. Is that a bad idea?
Old Aug 16, 2007 | 11:56 AM
NmexMAX's Avatar
dot dot dot ...
I had never soldered in my life, learn something, solder it.
Also, 05+ A334's also have WB's, Just FYI.
Old Aug 16, 2007 | 12:04 PM
DasYears
yes, but i have a 2002...and will NEVER have an 05+
05+ g/z on the other hand...
can i get a second opinion?
PS: i know how to solder, i just dont have a soldering gun
Old Aug 16, 2007 | 12:05 PM
NmexMAX's Avatar
dot dot dot ...
Oh yeah, BTW, here's my take on NB's.
http://forums.maxima.org/showpost.ph...02&postcount=2
Old Aug 16, 2007 | 02:34 PM
MOHFpro90's Avatar
Get a 15/30W iron from Radioshack. Theyre under $10, just trust me, GET FLUX TOO! Especially with soldering wires together. I generally use 30W, Flux, Solder(0.032 thickness), and a suction bulb to remove solder. That's my arsenel.
Oh, and try soldering with and w/o flux, and see the difference.
Good luck!
Old Aug 16, 2007 | 03:15 PM
DasYears
only $10?!?!?! sounds worth it. i have lots of flux, i used to use a soldering gun...but then i broke it and havent gotten a new one. it thought it would be expensive. glad to know its cheap...will be soldering now.
Old Aug 16, 2007 | 06:44 PM
MOHFpro90's Avatar
Irons are cheap. Guns, I think are like $30. They make 40 W irons, which are better for larger guage wire, say 18 or so.
I used 255 strand 18G wire in RC cars, I had to pull out my dad's gun in order to heat it up correctly. With the iron, the heat would dissipate through the plug and down the wire without melting the large ammount of solder needed.
For what you're doin, I would suggest something like this: http://www.radioshack.com/product/in...entPage=search
Check them out, you could really go with anything. If you want more help, shoot me a pm.
http://www.radioshack.com/search/ind...%3BDesoldering
Old Aug 16, 2007 | 07:09 PM
NmexMAX's Avatar
dot dot dot ...
Solder tips.
http://forums.maxima.org/showpost.ph...33&postcount=3
Old Aug 17, 2007 | 06:27 AM
DasYears
i went with a 25w since it was considerably cheaper, came with a cold grip and stand, where the 40 just came with stand...lol. not to mention it will do the job fine, just maybe slower. cant wait to get started!
Old Apr 12, 2020 | 09:12 AM
CMax03's Avatar
How does Darren (NISformance) get around this issue tuning the OEM ECU?
Old Jun 5, 2020 | 12:15 PM
schmellyfart's Avatar
Romraider+nisprog or uprev
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Socalstillen
Sep 26, 2015 12:01 PM
Maxboy23
Sep 4, 2015 06:04 PM
