Sponsored by:
Sponsored by: CARiD
Starting 00VI
Old Oct 6, 2007 | 03:42 PM
  #121
MOHFpro90's Avatar
^^What is that for?^^ IACV adapter?
Old Oct 6, 2007 | 04:00 PM
  #122
XAugusta MoonX's Avatar
No sir, it's the fuel rail adapter. Anywho, I tapped the TAM screw and the RPM switch is finally lighting up. Unfortunately, the green light comes on almost 1000 revolutions before the actual switch is set at. I'm thinking of setting it at 6K so that it opens at 5K. Any ideas? Oh, I got a VAFC. I've found the write-ups on the VAFC-II. Same thing or different?
Old Oct 6, 2007 | 04:59 PM
  #123
Tatanko's Avatar
Bacon Lover
Just play with the settings on the switch until you get it to where you want it - simple as that. The VAFC II writeup should be similar enough for you to get the job done, as far as I know.
Old Oct 6, 2007 | 09:10 PM
  #124
MOHFpro90's Avatar
FR adapter: Ahh, I see.
RPM switch: Yeah, that would make sense. I think it was earlier in this thread(or another) that said since they are designed for 8 cyls, the rpms would be off.
Old Oct 8, 2007 | 06:45 PM
  #125
Hey, what color wire is the TPS? I think I tapped the wrong one because I'm not getting any reading on the throttle % on the SAFC.
Old Oct 9, 2007 | 12:11 PM
  #126
NmexMAX's Avatar
dot dot dot ...
Old Oct 9, 2007 | 03:53 PM
  #127
MOHFpro90's Avatar
^^Thank you SO much. Referenced in my thread.^^
Old Oct 9, 2007 | 06:32 PM
  #128
The write-up can also be found on VQPower. I have that it's just not as easy to follow as you think it would be....
Old Oct 9, 2007 | 06:37 PM
  #129
NmexMAX's Avatar
dot dot dot ...
That's where it originated/where I got it from. It's already on his (MOHpro's) 'How To' thread though (Link to VAFCII write-up)
Old Oct 9, 2007 | 10:43 PM
  #130
MOHFpro90's Avatar
Oh. Oh well. I generally skim threads, and just copy/paste the url into the most applicable category. I haven't read them all yet! The more links, the better!
Oh, and by referenced, I meant that I added a link just to that specific post for info. Anyhow.
Old Oct 13, 2007 | 01:20 AM
  #131
How can I tell for sure if the VIAS is working? Should I set the RPM switch to open earlier and see if there is a boost in power at 5000 RPM? I can't tell if it's switching over or not.
Old Oct 13, 2007 | 04:48 AM
  #132
goldtooth's Avatar
pull the throttle from the engine bay, and if you know where the VIAS is( im assuming) look slightly under it while reving past 5000( idunno where u set it to) and if everything is good, you will see something moving only past that certain rpm point.
Old Oct 13, 2007 | 08:08 AM
  #133
Tatanko's Avatar
Bacon Lover
That is the easiest *accurate* way to test it. Make sure the car is up to operating temp when you do that, of course, and I suggest doing it somewhere out of the way so you don't **** the neighbors off
Old Oct 13, 2007 | 08:21 PM
  #134
CRiME's Avatar
oem ftw!
i'm not sure if it's because i'm using a short ram setup at the moment (can't fit the stock intake FTL!), but I noticed that the car sounds different when the vias opens - it sounds meaner than it did before I wired up the rpm switch (anyone else notice this, or is it the good old placebo effect? )
But the easiest way to be sure, as has been posted, is to go under the hood and pull on your throttle cable. look at the plunger/arm, whatever you want to call that part of the vias, and see if it moves when your revs get high
Old Oct 13, 2007 | 10:11 PM
  #135
Tatanko's Avatar
Bacon Lover
It's either placebo or your settings aren't correct. What is your RPM switch set to open the VIAS?
Old Oct 13, 2007 | 10:40 PM
  #136
CRiME's Avatar
oem ftw!
My summit is set to 3200, activates somewhere between 4500 and 5,000. I think it may actually be activating too soon - haven't had a chance to precisely tweak it yet, have to find a good place to do it where there are no angry neighbors
Old Oct 14, 2007 | 08:36 AM
  #137
Tatanko's Avatar
Bacon Lover
Yeah, sounds to me as though it is activating too soon or too late. If that's the case, you'll also "feel" the VIAS switchover, too. You'll have a lag and then a sudden rush of power. Feels kind of cool, but it's not what you want
Old Oct 16, 2007 | 03:34 PM
  #138
Keem's Avatar
shilov
Feb 19, 2024 09:40 PM
t6378tp
Sep 29, 2018 04:27 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
