time to install headers ...???
how much time does it take to install headers on a VQ3.0dek Also is there anything i should look out for ( special tools needed ) and if i would need new head studs......
First get the heat shields off. kinda a pain, but not bad.
then take the y-pipe off
You'll need to remove the crossmember under the motor. then take the (front and rear) motor mounts off the brackets. get the brackets off the engine and go to town on the manifolds. (swivels and extensions will be a life-saver) sometimes the nuts came off the studs, other times the studs cam out. either way you should be fine. mine went back together fine.
Also, if you're getting oem nissan gaskets (which you should) look into gaskets from an xterra with the 3.3 v6. I don't remember what year it was, but we happened to stumble upon these because they looked identical, but the part number was for the xterra, not the max. Anyway, they were about 8 bucks as opposed to the maxima's 25ish. worked fine.
EDIT: this was on a 97 vq30de, not de-k. AFAIK it shouldn't be any different though...
a full day or two depending on how things go. it took me two because i was so frustrated.
removal of the the upper intake manifold +throttle body, radiator fans, lower crossmember and rear motormount, ypipe. tag and bag every bolt and hose because there will be a lot of pieces loose. when removing the lower crossmember, remember to jack up the tranny/engine so it doesnt fall down. using new gaskets will make things easier in the long run.
for tools: a slew of extensions, swivel joints, closed end swivel ratchet wrenches were my friend, an assortment of sockets, and lots of patients.
depending on the amount of time you have and tool you have accessable to you. It might be easier and faster to pull the motor and install the headers.
take a few hours to pull the motor. 20mins to install headers, another couple hours to drop back in.
a radical idea i know
But I imagine no one would pull the motor just to install headers. it was a wild out there suggestion. If he needed to change his clutch too then such a move could be better justified.
RE: tricky bolts
I'll add that there's more than one way to skin a cat. I never removed the lower cross member or messed with the motor mounts. I removed my MEVI to gain access to the tricky bolts.
me,too.... Lots of work, and tall jack stands, 3/8" flex-head ratchet, plumber's wrench, 6-pt sockets, lots of assorted swear words and tools, and patience..
Lots of patience....
The part # is 14036-0w000. I've checked the part # with the FAST CD and on Pinnacle Nissan's part website. This gasket covers all Xterra VG33s since they started making them in 1999 and until 2004. So something you did doesn't follow.
Both exhaust gaskets I have on there are only a year old, so Im gonna chance it and re-use them with the headers. It's too late in the week to order and get them by Saturday anyways.
IIRC Cattman gained around 20 WHP from a stock Y pipe to headers.
It's taken a while for anyone to do this. However Im dynoing in another week or so with headers. Provided I can pull a similar A/F curve there will direct before/after dynos for a VQ30DEK with an aftermarket Y-pipe Vs. headers.
It's also about area under the curve, the 20 whp is a peak number but the average gains over various rpm ranges were impressive too, I had all that info in an old post somewhere...
VQ'ed
69
Aug 27, 2020 12:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
