Sponsored by:
Sponsored by: CARiD
00VI start up issues, dies at start up when its cold outside
Old Dec 14, 2007 | 10:54 PM
96blackmaxSE's Avatar
boost me.....
I've had my VI for almost 2 years now and I've always had troubles with it when cold weather rolls around.
Last winter I could start the car and it would die unless I immeadiately revved and held it at 1500 rpm for about a 10 seconds, then I would let off the pedal and it would be fine.
It seems that the start ups are getting harder this year and sometimes when I do my normal revving routine and let off it will still die. When this happens it usually takes about 1 or 2 more tries to finally act normal.
I don't have any idle issues or any other times when it dies. It only happens when its cold out.
Anyone else have issues like this? What can I do about this other than my usual revving-routine?
Thanks for any help in advance....
Old Dec 14, 2007 | 11:32 PM
Ceasars Chariot's Avatar
Old Maxima Legend
there is a thread somewhere around here with someone who was able to remedy this. i forget what he did. mine did the same thing. it was ok at first just reved it up a few seconds and she was fine, then after a few months same thing, but at stops it would die on me ? so now i just slide it neutral before a stop and it doesnt die.
will have to get that sorted one of these days 00vi owns !
Old Dec 14, 2007 | 11:51 PM
boost me.....
Its never died when I've been stopped but sometimes when I'm taking off from a stop it feels almost like it tries to die but then catches itself real quick.
Old Dec 15, 2007 | 06:48 PM
boost me.....
bump, for help.
Old Dec 15, 2007 | 07:49 PM
streetzlegend's Avatar
I have also had this same problem since day one of doing my 00vi, i have been dealing with it for about the same time. Sometimes when i start it, it starts right up instantly with just half a crank, no need to rev or anything. and other times, which is more often i have to give it gas to get it to start then hold it a lil bit, then idle levels out then its fine.
Old Dec 18, 2007 | 06:50 AM
KRRZ350's Avatar
IACV adaptor hose as short as possible or 5th gen iacv ftmfw. You can try to bump the idle up via iacv a little also.
Old Dec 18, 2007 | 08:44 AM
spdfreak's Avatar
Mind elaberating? Maybe post a picture or two.
It's always good to learn.
Old Dec 18, 2007 | 02:02 PM
in my case i dont have a IACV ....
Old Dec 20, 2007 | 03:15 PM
boost me.....
Theres an idle adjustment screw on the side of the IACV, you turn it and the idle can go up or down.
Thanks for the info, Im gona crank that idle up and see if it does anything.
Old Dec 20, 2007 | 03:18 PM
spdfreak's Avatar
Thanks. This is the second thing I learned today about the Maxima.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
02PearlSE
Oct 7, 2015 02:12 AM
Finkle
Sep 27, 2015 09:53 PM
Maximeltman
Aug 31, 2015 01:01 PM
305head
Aug 26, 2015 09:03 PM
