Sponsored by:
Sponsored by: CARiD
rwd vq35 valve covers
Old Dec 25, 2007 | 08:30 AM
MAXSE5SPD's Avatar
i got a free vq35 from a 2005 g35 6spd from work and i was wondering if the rwd vq35 valve covers can be used on the fwd vq35. they are the updated ones, and i believe my rear one is leaking. i assume the drivers side cover cant be used because the oil filler neck is too high, but what about the rear one?
Old Dec 25, 2007 | 08:46 AM
!PrjctMax!'s Avatar
Motor for free?! Not bad!
Old Dec 25, 2007 | 09:39 AM
KRRZ350's Avatar
If they are the updated ones than try confirming by checking the part #'s between the 6th gen & Z for bank 1.
Old Dec 25, 2007 | 09:40 AM
nismology's Avatar
^^ Not the same part #.
Old Dec 25, 2007 | 09:42 AM
nismology's Avatar
In any case, we know that it'll bolt up since RWD/FWD heads are the same. The only difference is probably where on the cover the PCV valve is located. Perhaps also whether or not the #1 coil is secured at an angle.
Old Dec 25, 2007 | 09:44 AM
Weimar Ben's Avatar
Helicopters! Money!!!
Your 3.5/6spd is begging to go into a S13.
Old Dec 25, 2007 | 10:03 AM
MAXSE5SPD's Avatar
lol, i wish. not enough time, money, resources.
Old Dec 25, 2007 | 11:22 AM
Alex_V
Then I'll take the block off your hands. My s13 shell is getting a VQ30 or 35 before spring!
~Alex
Old Dec 25, 2007 | 03:49 PM
MAXSE5SPD's Avatar
pm me......
Old Dec 25, 2007 | 04:48 PM
!PrjctMax!'s Avatar
Will those valve covers fit in a 6th gen engine bay?
Old Dec 25, 2007 | 05:10 PM
Kevlo911's Avatar
Kevlo for President
Yes but why?
Old Dec 25, 2007 | 05:15 PM
!PrjctMax!'s Avatar
Originally Posted by Kevlo911
Yes but why?
Because I saw some "painted" covers over on www.350z.com and was curious. I have better things to spend my money on right now, but maybe a little "bling" in the future.
Old Dec 25, 2007 | 05:47 PM
coinage's Avatar
the fronts would be pointless to put in since they have an "extended" oil fill to clear the 350z intake manifold... rears might fit as mentioned as long as the coils are in the same positions as the fwd's
Old Dec 25, 2007 | 05:53 PM
!PrjctMax!'s Avatar
True, maybe I'll just grow some nuts and remove my own!
____
You've got a nice little mod list in your sig
Old Dec 26, 2007 | 04:08 AM
L.M.L.
as far as i know, the front one fits fine, no issue with the clearance.
Old Dec 26, 2007 | 07:47 PM
1997 GA16DE's Avatar
you got a free VQ35 and all you're interested in are the valve covers?
Old Dec 26, 2007 | 07:49 PM
MAXSE5SPD's Avatar
well i cant use the block. cams will do me no good. head work prolly wouldnt be worth the trouble.
Old Dec 26, 2007 | 07:59 PM
Unless I missed the part where you say, 'the motor is blown' I'd dunk that sucker into a car it was never meant to belong.
Old Dec 26, 2007 | 08:05 PM
MAXSE5SPD's Avatar
its just a long block. too much money to buy a car, buy parts for the engine. no time, nor a place to work.
Old Dec 26, 2007 | 08:07 PM
Alex_V
Its going in my s13 instead. Buhahahaha. Its gotta be ready by spring too.
edit- how hard is it to use 3L valve covers on the 3.5L? Would I have to notch the vtc actuator assembly? I thought I read they bolt on...
~Alex
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
jonreidhead
Jan 6, 2016 09:38 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
