Sponsored by:
Sponsored by: CARiD
How much would a VAFCII help this AFR?
Old Dec 31, 2007 | 03:11 PM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
I already have an SAFCII installed and tuned but I have seen a few members on here that have a much straighter line than mine. Mods are I/H/E/UDP
Old Dec 31, 2007 | 03:31 PM
NiSmOVQ35's Avatar
i dont belivbe the vafc II will do much on top of the safc II jsut need a better tune from a shop i believe.
or just EU that bit**
Old Dec 31, 2007 | 05:32 PM
An EU is tempting...I guess I should do A LOT MORE research on Dandymax's experience. Thanks for the info.
Old Jan 2, 2008 | 09:51 AM
NmexMAX's Avatar
dot dot dot ...
SAFC II = 12 correction points, VAFCII = 24 tuning points. In theory, this would allow better resolution which should make it easier to make the AFR curve flatter.
Old Jan 2, 2008 | 10:23 AM
95BLKMAX's Avatar
This is weird, and its not the 1st time I see this. I have only 8 tuning points on my SAFC- and my a/f curve is noticeably (not completely straight, but more so than your graph) straighter than yours.
Just a thought in my head. Not that there's anything wrong since so many others have similar curves.
And to answer the question, it SHOULD. Is it worth the switch over? thats up to you. I say just keep fine-tuning with what you have. Cus if I can match your curve, or be slightly straighter, with 4 less points, I dont see why anyone else cant do it. Then again last year I was living strapped on the dyno, so I had plenty of time to fine-tune, hahah
Old Jan 2, 2008 | 11:52 AM
I hate to buy a used vafcII and I cannot find a new one for any less than $269(optionimports) This is going to be my last performance mod after I finish the SSIM and Vias removal. I MIGHT need to purchase the TS L-spec ECU for the redline increase to see optimal gains for that<---That's for another thread. It's been said before that these cars can be quite different from each other so we'll see about mine(straightening out my AFR that is).
And no I will not be purchasing and EU, EB, UTEC, or any other Fuel management products.
Old Jan 9, 2008 | 03:47 PM
killerVQ30DE's Avatar
A novice tuner mistake I have seen is wasting correction points by trying to correct below 3000rpm or over 5600rpm .. if you only have 8 points then your best to only use them where the A/F is dip/peaking
Old Jan 9, 2008 | 04:28 PM
MDeezy's Avatar
killervq30de brings up a good point. at what rpms are you making your corrections?
Old Jan 10, 2008 | 06:54 AM
NmexMAX's Avatar
dot dot dot ...
I correct mine all the way to 7000, and if I had a stock rev limit, I would correct to 6500. Not sure where 5600 comes into play here.
Old Jan 11, 2008 | 07:49 AM
I retract my statement in post #6...I will be getting an EB to advance my timing and tune my car MUCH better than it is now. More to come on that in a few months.
Old Jan 13, 2008 | 02:39 PM
kzoosho's Avatar
U do know that eb wont raise your rev limit right?
Old Jan 13, 2008 | 02:41 PM
MDeezy's Avatar
why not?
Old Jan 13, 2008 | 03:06 PM
kzoosho's Avatar
Originally Posted by MDeezy
why not?
Not ultimate here we are talking about blue.
Old Jan 13, 2008 | 03:08 PM
MDeezy's Avatar
yea. the rev limiter is a fuel cut. so all you need to do is add fuel (simplified explination). why wouldnt the blue be able to add fuel close to the redline to fight the fuel cut?
Old Jan 13, 2008 | 03:15 PM
kzoosho's Avatar
Because you would need to add more fuel than blue will let you.
Old Jan 13, 2008 | 03:17 PM
MDeezy's Avatar
okay. didn't know the blues limitation. that would explain it then.
the blue cant add enough fuel? whats the most/least fuel the blue can add/subtract?
Old Jan 13, 2008 | 04:30 PM
I am not worried about increasing the redline...it's just something I am not interested in doing. Not a lot of people have posted much about the EB on here, but when I get this installed and git'r'tuned I will have more info on it. Like I said before, it will be a few(3-4) months. But, thanks for the info though, I will definitely need as much of it as possible due to my ignorant a$$.
Finkle
Sep 27, 2015 09:53 PM
EZEMaxima
May 21, 2005 02:27 PM
Stephen Max
Oct 22, 2004 10:40 AM
Stephen Max
Jul 31, 2004 11:40 AM
max'n out
Jan 4, 2002 09:12 PM
