Sponsored by:
Sponsored by: CARiD
q45 maf
Old Jan 6, 2008 | 05:24 PM
kzoosho's Avatar
q45 maf
I am trying to find the wiring for a q45 maf and what would be the settings for the safcII. 1 in 4 out since im a a32?
Old Jan 6, 2008 | 06:31 PM
BLACKonBLACK98's Avatar
Former Vendor
get back in the fi section...
Old Jan 6, 2008 | 07:47 PM
kzoosho's Avatar
no. I dont have to.
Old Jan 8, 2008 | 10:31 AM
NmexMAX's Avatar
dot dot dot ...
If that's what the setting is, then that should work. I'm using 1IN/17OUT...in an A33.
Best thing is to try it and see how it reacts.
Old Jan 9, 2008 | 05:26 PM
ajcool2's Avatar
What year Q45 maf are you using? Also do you know what year Q45 TB can be used on our cars.
Old Jan 20, 2008 | 11:01 AM
kzoosho's Avatar
I used 1 in and 4 out and works fine.
Old Jan 20, 2008 | 11:24 AM
NmexMAX's Avatar
dot dot dot ...
Q45 TB = mucho big, probably too big.
Old Jan 20, 2008 | 12:08 PM
kzoosho's Avatar
Yea i was looking at that too man lol. I wonder what the size is.
Old Jan 20, 2008 | 01:24 PM
96blkonblkse's Avatar
I believe the Q45 TB is a 90mm unit. If i remember correctly from my good ol' supra days it was a very common upgrade for the big hp 2jz/7m guys.
Old Jan 20, 2008 | 01:28 PM
NmexMAX's Avatar
dot dot dot ...
90mm.
Old Jan 20, 2008 | 01:41 PM
kzoosho's Avatar
Hmm so that would be too big lol. I may look into it. I have the maf already. I will have a mevi soon also.
Old Jan 20, 2008 | 02:21 PM
NmexMAX's Avatar
dot dot dot ...
Overkill IMO, but this is coming from a member that has an 82mm MAF and a 70mm TB.
Old Jan 20, 2008 | 02:24 PM
kzoosho's Avatar
Yea and think im boosted also.
Old Jan 31, 2008 | 02:56 PM
Cdg2125's Avatar
sorry to bounce this back up but how are the results? I'm thinking of buying a SAFCII and getting a bigger maf to run on my 00vi but just thought i'd see what the results were first.
Old Feb 1, 2008 | 07:37 AM
NmexMAX's Avatar
dot dot dot ...
For that application, I'd get a larger MAF, but not as large as the Q45.
Old Feb 1, 2008 | 09:19 AM
Cdg2125's Avatar
what do you recommend? z32? Or something else?
Old Feb 1, 2008 | 09:36 AM
NmexMAX's Avatar
dot dot dot ...
You would need to re-wire it in, and calibrate (SAFCII) for your ECU, but yeah, I've heard it's 76.2mm ID, vs 70mm.
Old Feb 1, 2008 | 09:53 AM
Cdg2125's Avatar
hmm ok. Well I don't remember how to wire the z32 in really. Been awhile since I read threads on that.
Old Feb 1, 2008 | 10:35 AM
kzoosho's Avatar
Isnt there a setting for the z32 maf in the safc? I thought it did.
Old Feb 1, 2008 | 10:54 AM
Cdg2125's Avatar
i think it was 1 in 4 out for the safc with the z32. But I don't remember how to wire it into the stock harness and all.
Old Feb 1, 2008 | 11:33 AM
dfownz's Avatar
Put the two grounds together and wire it to the maf ground.
Signal to signal. (white i think)
Pos to pos.
Really easy, JWT has a writeup (or did years ago) check that out.
And yes, q45 maf should only be used for people with crazy power that have exhausted everyother mod. The thing is huge.
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
dcardello
Sep 3, 2015 11:44 PM
