Sponsored by:
Sponsored by: CARiD
IACV allows too much air to bypass! i'm stumped
Old Dec 10, 2008 | 05:21 PM
  #41
chillin014's Avatar
im using the 3.0 one. remote mounted. I still need to adjust it, but it works fine.
Old Jun 16, 2011 | 06:53 PM
  #42
shadyonedeath's Avatar
Originally Posted by chillin014
I thought I'd update this thread for anyone who came across it in the future. I bought a 5 speed ECU and the problem is now gone. No more air flowing through the iacv under 2400 RPM and etc. thanks everyone
I know this is old but your still around...
How do us A/T transmission guys with A/T ECU's fix this problem?
Old Jun 17, 2011 | 10:51 AM
  #43
chillin014's Avatar
maybe you just have a vacuum leak. My issue was due to running the wrong ECU.
Old Jun 17, 2011 | 01:23 PM
  #44
Nah, I plugged up my Throttle body using KRRZ350's method (3" PVC expandable plug on the according piece) and blew air into the manifold via one of the vacuum lines, it held pressure and even blew it back out at me. I even sucked air out (yes sacrificing my lungs for this car ) and held the end of the hose with my thumb and it held vacuum. Keep in mind, the IACV required to be plugged too in order to hold vacuum.
Which leads me to believe the IACV is bad but measurements say otherwise. Resistance is in spec. 45ohms all around/12v from ECU. Tps is @ a perfect 545 ohms closed, 3500~ @ WOT, and measures linear all across.
Old Aug 4, 2011 | 10:44 AM
  #45
bump
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
