Sponsored by:
Sponsored by: CARiD
Stock 3.5 IM vs. VIAS delete vs. SSIM dyno comparo
Old Jan 16, 2009 | 10:34 AM
  #41
Scottwax's Avatar
That's Mr. Detail to you
Originally Posted by m_turner_02
I have an 05 altima, 5spd auto, and I did the vias plate about a month before I did the spacers. The low to mid range loss was somewhat noticeable, but the gain from 3500 up more than made up for the minimal loss. If you are debating on doing this mod, then quit...just do it, it will be the best 30 bucks you have spent on your car, and there are dyno numbers to prove it
Thanks, that's what I wanted to know.
Old Jan 27, 2009 | 06:58 PM
  #42
dat01max's Avatar
is there a post anywhere that gives instructions on how to do the vias delete on an 02 max????
Old Jan 27, 2009 | 07:41 PM
  #43
Stormzusmc's Avatar
http://nwpengineering.com/VQ35DE_FWD_VIAS.pdf
yes when you buy the blockoff plate this comes with it
Old Jan 27, 2009 | 08:31 PM
  #44
Scottwax's Avatar
Looking over the instructions, I can see how the VIAS assembly would be a restriction at higher rpms.
Old Jan 28, 2009 | 06:45 PM
  #45
dat01max's Avatar
i c in the instructions that the butterfluy is there..... is where you can remove the butterfly?
Old Jan 29, 2009 | 07:23 AM
  #46
chillin014's Avatar
the butterfly valve is attached to that plate....you are replacing the OEM plate with one without anything attached to it. A pretty simple concept really.
Old Jul 8, 2009 | 01:16 PM
  #47
MIKERNM1990's Avatar
wow! its very interesting! stock intake manifold with vias deleted is best than kinetix intake manifold ~$1000
Old Nov 1, 2010 | 01:46 PM
  #48
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
seems to depend on top end. if you have an eextended rev limiter and cams and a full setup beyond 7100rpms is when the kinetix is supposed to be at its best. aside form that my understanding is that the ssim is still an equal to that to a point both give good top end gains.
personally i have a ssim on mine. I plan to extend my limiter and cam the car around summer so i dont intend to go back to a stock manifold until i get to street tune and a couple of track days under my belt..
Fbana41
Aug 29, 2016 12:18 PM
Maximan190
Dec 16, 2015 06:01 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Maxboy23
Sep 4, 2015 06:04 PM
