Re-strating issues when travelling short distance
Since the weather has gotten cold outside I have had issues when driving a short distance. For example the car will start fine once sitting, if I drive just to the gas station, the car give problems starting up again. This doesn't happen if I drive a longer distance or the car sits for awhile. This hasn't happen before getting the Greddy EU and cammed DEK done. Any idea's?
Exactly. I would even say the motor is fully warmed up at times but it seem's like the motor wants to be driven hard (not that I mind lol) since local city stop and goes give re-starting issues. For example if I did a few grocery runs locally I get starting issues. Yet going to work (50kms including highway) it has no issue.
check your grounds and battery, i had same symptoms. i found if i left the car off for a while after stopping (long trips, to work etc.) that i didn't have a problem starting up again, however if i drove to the petrol station or just to the shops i always had problems.. To fix i replaced the battery and fixed the grounds.
I'll check that. Today I did a quick stop off and when trying to start it I noticed a strong smell of gas. Cranking etc is fine. Is it possibly the fuel filter being clogged or something?
And are you pulling any codes (especially coolant temp sensor)?
I just did some research and my symptoms are on par with coolant temp sensor issues. Since its like a $30 part and easy fix I'll change that out and see. I've had a CEL since the swap which was the cam sensor and just never cleared it so this code could have popped up as well.
Thanks for the suggestions. I doubt it's EU related as I checked everything last night and it looked fine since we did the tune.
03-12-2020 12:06 AM
BrandonCause
09-14-2015 10:41 PM
Maxima30
09-07-2015 06:13 PM
