Sponsored by:
Sponsored by: CARiD
shadyonedeath's 00vi swap - 1999 SE-L
Old May 23, 2012 | 03:12 AM
  #41
wirelessdude04's Avatar
Quick question when wiring in a safc 2 for the maf. I cut the wire for the maf so the wire still connected to the ECU plug I connect the yellow wire from the safc and then the wire coming from the harness I connect the white wire correct? I'm getting 3% on my safc for AF is the common? No corrections mades
Old Aug 26, 2012 | 09:02 PM
  #42
maxed_out_99's Avatar
sorry to bump an old thread but i didnt want to start a new one for a simple question
is tuning possible without a wideband?
Old Aug 26, 2012 | 09:07 PM
  #43
what i am gathering form this info is that you cut the wire, the end that goes into the ecu is connected to the yellow wire on the VAFC then the other wire that was cut it connected to the white wire on the VAFC. as for the percentage i wish i coud help but i simply have no clue
Originally Posted by shadyonedeath
Before you do ANY of this, make sure you disconnect your Negative battery terminal before you work on splicing into the ECU.
Here we have the wiring. There are two power wires (red) and two ground wires (one black and one brown) required to function the VAFC2. Each set is spliced into the same Power or Ground in on the ECU harness and spaced apart 1cm or more. The MAF wire on the ECU harness must be CUT, not spliced. Once cut, the end still attached to the ECU CONNECTOR/CLIP is connected to the YELLOW wire on the VAFC2 harness. The other end of the MAF wire we cut is attached to the WHITE wire of the VAFC2 harness.
Refer to YOUR Maxima model's Factory Service Manual for correct wire colors on the ECU harness. Wire listings can be found in section EC under ECM Terminals and Reference Value.
Note: I haven't messed with the MAF wire yet because i need to get some plugs for the wiring. These plugs will allow the MAF wire to be reconnected to its original form easily should you choose to remove the VAFC2. Also it helps make a cleaner and secure install. I also avoided splicing into the Knock Sensor wire, apparently this caused some issues with the car starting and previous installers have avoided this part of the install. Please correct me if im wrong on this.
Edit: DO NOT use knock sensor wire. We dont need it. - per gtr_rider. Its not designed for our cars
Go to the Passenger side and remove the cover concealing the rear of the ECU/ECM. You will see a white plastic cover over the wire harness. Use a 10mm socket wrench to remove the bolt and then proceed to remove the harness/clip from the ECU. Once off, give the harness a bit of a tug to expose more working space. Nothing to drastic, just enough to get an extra inch or two. Remove the white/clear plastic cover from the harness clip using a flat head screw driver. Now we can begin searching for our desired wires.
Splice connectors are pretty self explanatory.
Don't ask me how im going to get the plastic cover from the ECU harness back on, i probably wont.
Old Apr 22, 2013 | 04:03 PM
  #44
Envy1r's Avatar
Jus wanted to know if this was needed if i had the emanage ultimate which i plan to put on once i go 00vi with cams
Originally Posted by maxspeed96CT
Does anyone know if the wiring diagram is the same for the 5th gen (01)
I found diagrams for the 5.5 gen but none for the 3.0.
Is it the same as the fourth gen for a vafc 2?
Old Apr 22, 2013 | 04:10 PM
  #45
Crusher103's Avatar
^^Updated with 00vi painting
I finally got some more brass fittings from ebay. My local source ran out of them and they were getting a bit pricey. (5$ a elbow). I got (6) 3/8 x 1/4 elbow fittings for about 10$.
Why six? Well, i need two for the 2nd 00vi im going to sell, 2 for my oil catch can, and 1 for my current 00vi, which i painted in above posts.
I like that.....A LOT actually. Very innovative im going to steal that idea from you.
Old Apr 27, 2013 | 05:20 AM
  #46
carsnwomen91's Avatar
ha same here once it hits summer! I used this as my guide for the vafc2 hook up
Old May 6, 2013 | 08:29 AM
  #47
risingmist's Avatar
Quick question Shady,
your catch can, it seems to have a suction valve on the bottom, did you disable it somehow?
Edit: Nevermind, just noticed the date of the original posts lol
Old Jul 28, 2013 | 11:05 AM
  #48
SIBlofa's Avatar
vias vafc2 wire routing
how did you route the pink wire to the vias? through the same hole in firewall for ecu pins?
Old Aug 5, 2013 | 08:56 AM
  #49
maxman1988's Avatar
Wow great write up I've been looking for this info for forever :-)
Old Nov 15, 2013 | 04:49 PM
  #50
Johnny9595's Avatar
Where would one go to find an 00vi?
Old Nov 15, 2013 | 08:25 PM
  #51
Slamrod's Avatar
All of the parts come from a 5th gen so everything can be found at your local junkyard.
However, theres at least one thread on the 4th gen classifieds with an entire setup listed. You may wish to check one of those out.
Keep in mind, this isnt a bolt on setup. Even if you buy the whole swap its not something you just throw on. If you enjoy having a car you better do your homework.
Old Nov 16, 2013 | 03:30 AM
  #52
kenc15's Avatar
johnny9595 I have a setup for sale with a vafc2
Old Nov 17, 2013 | 07:12 PM
  #53
Johnny9595's Avatar
How long did it take you to do the swap?
Old Nov 19, 2013 | 06:18 PM
  #54
kenc15's Avatar
its pretty easy
Old May 5, 2014 | 04:10 PM
  #55
SSC's Avatar
SSC
Thanks for the writeup I know this thread is old but it might help me troubleshoot my no start issue with a 98 max 00vi swap I just bought. Plus I gotta clean up the swap the previous owner did.. (terrible job) seems alot easier than my 3.5 swap with megasquirt I did on my other 4th gen.
Old May 5, 2014 | 06:01 PM
  #56
kenc15's Avatar
Yeah man I hear ya on that, I took a project for my friend one time and the guy completely fubar that car
Old May 5, 2014 | 06:20 PM
  #57
darrick's Avatar
Dallas Nissan Enthusiast
I just did complete dek swap ,it's a little hard to start on cold mornings ,I think because of the delete but other than that totally worth the work .still need to get my neo apexi installed for the RPM switch and to tune the fuel on the larger dek injectors ,car runs strong but I think it's using more fuel than it should .
Old May 8, 2014 | 06:59 AM
  #58
SSC's Avatar
SSC
Yeah sometimes the diy jobs people do are horrible. I have **** plugged in with no vaccum lines going to it and all the wiring is kinda flapping around under the hood. Least now she will get the TLC she deserves
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
