Sponsored by:
Sponsored by: CARiD
1st Fully Built 5.5Gen - NA
Old Jun 26, 2010 | 06:32 PM
  #201
SurraTT's Avatar
HR Swap Pioneer
np man, whats goin on with yours??? the tuner not connecting to the utec ??
Old Jun 28, 2010 | 02:05 PM
  #202
SR20DEN's Avatar
VQ Wizard
I just called TurboXS about the connection problem and they told me that it is a known issue and there is no fix from them in the works. Rebooting the tuner after the fact is the known fix. Other than that, we're all left to come up with fixes on our own. Awesome.
Old Jun 29, 2010 | 06:08 AM
  #203
Deckdout2's Avatar
Play with my balls
Could throw it on a switch like Darren said, but what a PITA.
Old Jun 29, 2010 | 06:17 AM
  #204
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
The Tuner has to see the UTEC ON and booted up as soon as it turns on for them to interface. If I want my tuner and utec to interface, what I do is turn the ignition switch all the way to on and wait for the auto climate control display to come up, then quickly turn it off (the utec holds power for a few seconds) and back on. That causes the tuner to recognize the UTEC and it's all good to go. A switch would work as well, but I just flick my key twice... not a big deal.
Old Jun 29, 2010 | 06:20 AM
  #205
Originally Posted by Deckdout2
I need to clarify this so that I understand you. We were taking before about that one issue you were trying to solve with your patch harness where you had startup issues because you or someone was saying the UTEC was cold or something. I don't recall those details at the moment. Something that you or John was suggesting was putting a heating pad on the UTEC or something like that. Was that not a Tuner related issue?
Yeah I actually have a small inverter and a heating pad that I turn on on cold mornings (sub 55 degrees or so) for 2-3 minutes to warm up the UTEC so the misfires don't happen.
It actually took me quite a while to figure out that it was the UTEC case being cold that was causing the problem, but once I did it's not such a big deal anymore, just annoying/embarrassing until it warms up.
Old Jun 29, 2010 | 06:27 AM
  #206
Does anyone else hate the UTEC?
The interface sucks and takes a while to get used to, but it's a great tool and very easy once you're used to it. The misfire and tuner/UTEC linking problem can be annoying, but it's kinda a "oh well" for me at this point.
So yes, I hate it... but I couldn't think of a better option without trying to have my ECU modified (extra memory) for osiris or pay big money on one of the haltechs.
Old Jun 29, 2010 | 07:06 AM
  #207
Kevlo911's Avatar
Kevlo for President
http://www.350zmod.com/Osiris-Tuner-...12-07-1260.htm
Ever think about that?
Old Jun 29, 2010 | 08:06 AM
  #208
NmexMAX's Avatar
dot dot dot ...
The UTEC must be wired in post ECU, and the Osirus uses the Consult interface, so, there is no pre/post ECU wiring needed, but a Z33 (post year A33B ECU) is required for it to work, unless you use a Z33 ECU .. Did I get that right?
Old Jun 29, 2010 | 08:35 AM
  #209
Kevlo911's Avatar
Kevlo for President
I believe it works with any ECU that starts with 23710-?????
IIRC, early G35's have the same ECU has 5.5gens and it works for them.
Old Jun 29, 2010 | 08:49 AM
  #210
NmexMAX's Avatar
dot dot dot ...
Jeff will be glad to hear about this, and I might put my first born up for sale....
Old Jun 29, 2010 | 09:06 AM
  #211
SR20DEN's Avatar
VQ Wizard
I don't have to wait more than two seconds once the ignition is on. I flip it back off and on quickly and the tuner will reboot. It makes it work, but for something that costs as much as these things do, we shouldn't have to do things to 'make' them work.
Old Jun 29, 2010 | 09:08 AM
  #212
SR20DEN's Avatar
VQ Wizard
One fix I am considering is to wire the UTEC to the accessory switch so that it gets to boot first. That can help to solve this problem but it's not the best solution I can come up with.
Old Jun 29, 2010 | 09:09 AM
  #213
SR20DEN's Avatar
VQ Wizard
AFAIK, the Osiris only works with wideband ECUs. The early model G35s and 350Zs were not wideband until 2004.5 IIRC.
Old Jun 29, 2010 | 09:37 AM
  #214
SurraTT's Avatar
HR Swap Pioneer
Itll work with the older Z ecu's trust me
Old Jun 29, 2010 | 09:46 AM
  #215
Kevlo911's Avatar
Kevlo for President
I believe it just can't data log AFR on early ECU's.
http://uprev.com/documentation/UpRev...02-16-2010.pdf
They have maps for them all. I don't think anyone has tried it on the max but I am pretty sure it will work.
Old Jun 29, 2010 | 10:03 AM
  #216
It won't work on any of the early VQ ECUs that have a square connector, according to the Osiris guy that I was talking to on the Z forums. I believe some of the early G's were among this group.
Apparently the earlier ECUs do not have enough memory.
They said it may be possible to modify the ECU and add more memory, but I got the impression they would charge an exorbitant price.
Again just to clarify, they told me Osiris WILL NOT work on a 02-03 maxima ECU without modification.
Old Jun 29, 2010 | 10:08 AM
  #217
Kevlo911's Avatar
Kevlo for President
Oh, damn.
Figured it would be able to at least do the 1map over and over. I know the others store 5 maps but that is pretty useless(very few people will use more than 3)
Old Jun 29, 2010 | 10:09 AM
  #218
SR20DEN's Avatar
VQ Wizard
If you guys keep talking about this you'll make Paramy want to swap out his ECU with a newer one so we can use the Osiris on it. (I know that's what I would do). That whole package would still be cheaper than a Haltech.
Old Jun 29, 2010 | 10:13 AM
  #219
Kevlo911's Avatar
Kevlo for President
Only need to get an ecu with the harness correct? All the wires should match up. Should be pretty cheap
And dealer will reprogram the key; but that is no biggie.
  #220
Kevlo911's Avatar
Kevlo for President
And then he can run wideband o2's for the front and rear banks and get a better tune too huh
Old Jun 29, 2010 | 10:37 AM
  #221
Oh, damn.
The actual maps are probably a very minimal amount of storage. Just a small text file worth of info. It's probably the actual osiris program that needs the extra storage.
Old Jun 29, 2010 | 10:53 AM
  #222
Deckdout2's Avatar
Play with my balls
SOB! This is one less thing that I wanted to consider that I'm now considering. Damn you All Motor peeps!
I was actually waiting for a Haltech to come along, which I know would do more then I would need.
What are the pros and cons of the vs between going the Haltech route or the new ECU and Osiris route? I'm not positive that you can change cam timing on the Osiris program, and am I able to go in there an manipulate any single parameter I choose like so with the Utec or Haltech?
Also means that I can't run this Tuner wideband on it does it?
hmmmmmm......6th or 7th gen ECU should work right, or just 6th gen only cause of the 6-speed and HSLD?
Old Jun 29, 2010 | 10:59 AM
  #223
Kevlo911's Avatar
Kevlo for President
You can use a z/g/6thgen/alt ecu. They all have the same connector I think
Parameters that are supported in the ROM Editor include:
* Up to 5 Maps on cruise control equipped vehicles
* Idle RPM
* Speed Limiter
* Electronic Throttle Control to achieve Wide Open Throttle at all speeds.
* Rev Limiter
* CEL / DTC disable
* AFR Targets
* Fuel Tuning
* Ignition Timing Advance
* Cam Phasing for equipped vehicles
* MAF transfer function
* Cranking Enrichment and Ignition Advance
* Injector Latency
* K Fuel Multiplier
* Intake Temp
* Calculated Load vs. RPM
* Minimum Effective Injector Pulse Width
Old Jun 29, 2010 | 11:03 AM
  #224
Deckdout2's Avatar
Play with my balls
Thank Kevlo. My favorite feature so I can pass inspection.
* CEL / DTC disable
Not sure if it would bypass what is actually wrong with it, but that's good to know.
Old Jun 29, 2010 | 11:08 AM
  #225
Kevlo911's Avatar
Kevlo for President
Just bust out the FSM's and compared pinouts. And then find a cheapest ecu/harness combo
Old Jun 29, 2010 | 11:46 AM
  #226
Deckdout2's Avatar
Play with my balls
Does the ECU need to be HLSD specific as well? Anyone know?
Old Jun 29, 2010 | 12:50 PM
  #227
Kevlo911's Avatar
Kevlo for President
No just 6speed. Might wanna ask Matt bout the Can system stuff tho
Old Jun 29, 2010 | 03:15 PM
  #228
SurraTT's Avatar
HR Swap Pioneer
ya i know thats why i said Z. the early Z's are still the black connector.
no the wires dont match up. the max ecu controls more things than the z ecu does. specificity gauges, AC, and fans, cc too.
and no the dealer cant program the key, the NATS system is totally different, it goes through the BCM on the z ecu.
this is so funny to come up now.... if u only knew what was sitting my car right now... hahahah
Old Jun 30, 2010 | 07:02 AM
  #229
NmexMAX's Avatar
dot dot dot ...
This has come up many times before, and i was encouraging the A34 to get it, but no one sacked up from what I remember.
I was never able to convince rich@uprev to even consider the 02-03 A33B, but it seems as if sparks sparked his interest more than I did. Although I was trying like 4 years ago or some shat.
So, to get this straight, as in nothing's changed, just the nomenclature of the subject.
Early G's and Maximas have the same ECU pinout/connector, so no go on either of those, as we've known (or at least thought we did) for at leat a few years now.
No WB's = a non issue Z33's, but will not work with G/A33B ECU's.
So, this just semi clarifies this .. sorta.
Old Jun 30, 2010 | 07:57 AM
  #230
Kevlo911's Avatar
Kevlo for President
So he can only use Altima/Max ecu's?
Old Jun 30, 2010 | 08:05 AM
  #231
SurraTT's Avatar
HR Swap Pioneer
P. we talked about this yesterday.
IF the ECU is a GREY connector ecu. then osiris does not work.
If the ECU is a BLACK connector then osiris SHOULD work as well as utec/haltech/
Old Jun 30, 2010 | 08:08 AM
  #232
Kevlo911's Avatar
Kevlo for President
http://cgi.ebay.com/ebaymotors/2005-...Q5fAccessories
Might wanna watch that just incase
Old Jun 30, 2010 | 08:15 AM
  #233
Deckdout2's Avatar
Play with my balls
I don't have an automatic or else this would have been sweet apple pie.
Old Jun 30, 2010 | 08:20 AM
  #234
Kevlo911's Avatar
Kevlo for President
Turn off DTC's
Old Jun 30, 2010 | 08:31 AM
  #235
Deckdout2's Avatar
Play with my balls
Turn off DTC's
Good point! I would like to get as much working/functioning as possible with as little codes I'd have to disengage as I can though. Since this is a daily driver, and I would like to try and everything to function as it should. But yes that is an option.
Old Jun 30, 2010 | 09:03 AM
  #236
Deckdout2's Avatar
Play with my balls
btw, I don't like talking to Rich. Spoke to him a few times, and he just seems like he doesn't want to hear about anything Maxima. I understand that, but his CS is out the door. Spoke to him yesterday and he was kinda rude and blew me off. I wasn't asking him anything other then about particulars on ECU's via Osiris. He asked me what I was wanting to do and I just mentioned minor info, and he totally disregarded my initial question proceeding to demote the fact about me doing anything with the Osiris and a Maxima. Not cool dude, not cool at all!
Old Jun 30, 2010 | 09:46 AM
  #237
Kevlo911's Avatar
Kevlo for President
This is what richard told me when we were gonna do it on my buddies maxima:
K Patel wrote:
I read that you guys require the ECU part number to start with 23710. My ECU part number is 23710-5Y701. The ecu has the same connector as the EARLY g35's if that helps any. I was wondering if you guys think your products will work with the 2002+ Maximas.
K,
Our product works with all of the 2002 and newer Nissan ECUs. We just don't directly support many of the vehicles as we don't have the ROM files to patch, nor have we done any base tunes to start with. If you're located near one of our Pro Tuners, they can download the ROM file from the ECU and submit it to us so that we can patch it for our tuning software. Once that is done then they can do the tuning at their facility. Understand that the Pro Tuners will charge for this tuning time, and it is not something that we control, our pricing is for our product only.
As we have more Maxima owners come forward and want their cars supported, the more ROM files we'll have available and the more base tunes we'll have available to support them. At this time we don't actually have a single Maxima ROM or base tune.
Where are you located?
Rich-
See if one of the local dealers are willing you help you. We never got around to it since my buddy went ahead and got a VAFC2
Old Jun 30, 2010 | 10:00 AM
  #238
Deckdout2's Avatar
Play with my balls
Interesting, how long ago was this?
Old Jun 30, 2010 | 10:14 AM
  #239
SR20DEN's Avatar
VQ Wizard
This car really loves fuels with extra octane.
Old Jun 30, 2010 | 10:17 AM
  #240
e=m3's Avatar
< crawls out from hole in ground, looks around for numbers and sees only tuning clouds; 2 more months of winter! returns to hole >
