1st Fully Built 5.5Gen - NA
Dec 5, 2010 | 12:17 PM
  #401
I just got some L.E.D's
Gooduck deckedout2. Can't wait to see results from this build
Dec 5, 2010 | 01:13 PM
  #402
I heard the car yesterday...you can definitely tell it's got a little more than a stock vq. Good job brosef.
Dec 17, 2010 | 10:52 PM
  #403
Any Update?
Dec 17, 2010 | 11:43 PM
  #404
Quote: Any Update?
It stands to reason that were he to have any updates, he would post them.
Dec 18, 2010 | 06:24 AM
  #405
Quote: You seem very knowledgeable about building maximas. Care to tell us about your built maximas? They gots some sweet rims
Still waiting for this.
Dec 23, 2010 | 09:55 AM
  #406
I know some of you guys are curious for an update, or to even see if I've given up or not. Well, I'm here to say that life has been busy but the below is all you will get for now.
Hopefully, January will treat me better with giving me more time to finish tuning this thing up.
Please Enjoy (Iron Chef)......
Dec 23, 2010 | 10:02 AM
  #407
Double wideband is a good choice considering the fact that you're using the FWD 3.5 IM.
Dec 23, 2010 | 10:07 AM
  #408
First of the First! I like it!
Dec 23, 2010 | 10:12 AM
  #409
Nice, getting rid of the UTEC. You guys didn't get along too well with it, eh?
Dec 23, 2010 | 10:25 AM
  #410
Nice! Finally somebody using the Haltech on a maxima(and posting about it).
Dec 23, 2010 | 10:32 AM
  #411
O ****.......I don't even know what to say
Dec 23, 2010 | 10:34 AM
  #412
Impressive man. Shouldn't be too hard to install, I believe they already have the VQ35 sensors in their software.
Dec 23, 2010 | 12:24 PM
  #413
that is plug and play for me...
Dec 27, 2010 | 07:27 PM
  #414
Quote: that is plug and play for me...
So is the Uprev software... Lucky you.
Dec 28, 2010 | 05:27 PM
  #415
Can't wait to see the results after the Haltech is setup! Such a hectic time of the year already, never mind working on projects like this. Keep us posted.
Dec 29, 2010 | 05:58 AM
  #416
So this haltech is for the 350z and you are going to splice into it?
Cant wait to see the results though
Dec 29, 2010 | 06:49 AM
  #417
It is the Platinum Pro for the 350z. I would have to wire it in manually just like the Emanage. However, I opted to get this without the 350z PnP harness so I wouldn't have to hack anything, and for the cost savings. IP (Injected Performance) offered me the option of getting this kit with just the plugs and pins, and I did just that. So, instead of going with the same route of the Utec and wiring it into factory harness, I had a patch harness made so that my ish could be PnP too. (Jefffaafaa)
The choice of the dual w/b came down to number 1 wanting that extra feature, and 2 the fact that all it cost me was just another w/b sensor. I still had to get the controller and 1 sensor already, and it was under $60 to just get the second sensor so why not. I could have gone with a number of other options here, but I like the fact that it was proprietary to Haltech, and if I'm already going this far, I might as well go all the way and get precise datalogging.
One of the main reasons I went with Haltech, not only for the fact that it's a robust system but the software interface alone was enough for me to say, yes. I'm the type that likes things to work flawlessly, and do exactly what I want it to if I'm going to expend any time and effort on it, so after viewing my options and putting it up against what I've created here, the Haltech was the best option for me. I've been researching the Haltech and other standalones for months and I spoke with Hal at Injected Performance for a very long time, about this and my other viable options, however nothing else seemed to be able to do everything I wanted it to compacted into 1 unit.
The only thing I wish that this unit had was multiple maps capability with a flip of a switch. If I want to change a map it has to be uploaded/reflashed every time. Not that I do a lot of map changing nitrous runs, but it would have been nice to have that option on the fly.
Dec 29, 2010 | 10:03 AM
  #418
Quote: It is the Platinum Pro for the 350z. I would have to wire it in manually just like the Emanage. However, I opted to get this without the 350z PnP harness so I wouldn't have to hack anything, and for the cost savings. IP (Injected Performance) offered me the option of getting this kit with just the plugs and pins, and I did just that. So, instead of going with the same route of the Utec and wiring it into factory harness, I had a patch harness made so that my ish could be PnP too. (Jefffaafaa)
Being able to change maps on the fly if you do water/meth for the summer (to run good timing) would be pretty awesome. Just run a conservative map 95% of the time, then when you want to go fast swap to the water/meth map and hit the activation switch.
Otherwise, I completely agree with you. The haltech is 100% what I would do if I stepped up to something bigger than the UTEC. You should make some nice midrange gains being able to adjust intake cam timing!
Jan 4, 2011 | 09:30 AM
  #419
Switchable tables is very nice..Hell my MS1 had that. It is nice to simply reach down, flip a switch and be ready for trouble, lol.
Jan 4, 2011 | 10:53 PM
  #420
Damn man, you have some crazy money into this build. Hopefully it pays off and you run some 11s with this thing.
That would be awesome!
Jan 5, 2011 | 12:10 AM
  #421
Quote: Damn man, you have some crazy money into this build. Hopefully it pays off and you run some 11s with this thing.
^ I agree
Jan 6, 2011 | 02:08 PM
  #422
Don't know if it was asked before but were the heads flow tested? You only did valve worl correct?
Jan 6, 2011 | 04:33 PM
  #423
Quote: Don't know if it was asked before but were the heads flow tested? You only did valve worl correct?
The heads should be flowing at 50 to 70cfm more by the shop that ported them for me. Port work and valve job was done.
Jan 6, 2011 | 05:50 PM
  #424
This project has come to an end guys, sorry to say. I've got a bug for a new much more powerful car. I'm ready to make that move now. As exhilarating as this build has been and as much as I've learned from it, I can't fight the urge anymore. The motor is for sale here.
http://forums.maxima.org/general-max...ml#post7880307
Jan 6, 2011 | 06:25 PM
  #425
Blah... that's too bad. What is the higher powered vehicle you are looking at? This maxima could have certainly attained bottom 11s maybe even high 10s if it went on a diet and had a nice healthy 200 shot.
Jan 6, 2011 | 06:42 PM
  #426
Quote: Blah... that's too bad. What is the higher powered vehicle you are looking at? This maxima could have certainly attained bottom 11s maybe even high 10s if it went on a diet and had a nice healthy 200 shot.
It all depends on what the partout can bring in. Would love to be on the NAGTROC forum, but it's too soon to say. If not that then I'd like to try my hand at something German. This is the longest I've owned a car, and I've upped my game everytime (10+ past cars). I don't think I'll ever go this far again, but I would fully bolton mod and tune anything new that I get.
You should get this.
Jan 6, 2011 | 06:45 PM
  #427
Quote: It all depends on what the partout can bring in. Would love to be on the NAGTROC forum, but it's too soon to say. If not that then I'd like to try my hand at something German. This is the longest I've owned a car, and I've upped my game everytime (10+ past cars). I don't think I'll ever go this far again, but I would fully bolton mod and tune anything new that I get.
In that case, you should go for a CTS-V or vette... full bolton, cam, and tune on the vette could put you in the 10s with traction German... sounds very expensive to mod.
I would probably have considered it a few months from now, this time of year I'm recovering from holidays and tuition/books. I'm getting the nitrous bug again... lol
Jan 6, 2011 | 06:51 PM
  #428
Quote: In that case, you should go for a CTS-V or vette... full bolton, cam, and tune on the vette could put you in the 10s with traction German... sounds very expensive to mod.
i agree with both those choices
Jan 6, 2011 | 08:17 PM
  #429
C6Z06
/thread
Jan 7, 2011 | 09:04 AM
  #430
Quote: The heads should be flowing at 50 to 70cfm more by the shop that ported them for me. Port work and valve job was done.
That is a LOT of cfm to pickup..but certainly possible..
Best of luck in your new endeavor.
Jan 7, 2011 | 09:42 AM
  #431
SO what went wrong? lol
Jan 7, 2011 | 01:52 PM
  #432
Tax season just around the corner.
Jan 7, 2011 | 04:44 PM
  #433
Quote: SO what went wrong? lol
Nothing at all. Just gotta scratch that itch I've had for a while now for a new car.
Quote: Tax season just around the corner.
You are correct!
Jan 7, 2011 | 07:06 PM
  #434
Well I hope your next car is worth it. This woulda been nice to read up on. Def a stout motor with some proven parts.
Do you still plan on getting it tuned and dyno'd? Its make a good selling point.
  #435
Jan 7, 2011 | 07:26 PM
  #436
Quote: Well I hope your next car is worth it. This woulda been nice to read up on. Def a stout motor with some proven parts.
He probably wants to return the Haltech before its used, and those charlotte boys can't handle the UTEC.
Jan 8, 2011 | 10:53 AM
  #437
So realistically what kind of power should you expect from this setup 310whp?? 320whp?? Are the 380 inj's still in??
Jan 8, 2011 | 10:58 AM
  #438
Quote: So realistically what kind of power should you expect from this setup 310whp?? 320whp?? Are the 380 inj's still in??
We haven't really seen built engine results with FWD intake manifold and headers. Somewhere around low 300s is likely with good headers and a SSIM.
Jan 8, 2011 | 11:47 AM
  #439
Hate to see it never reached its full potential. Would have been nice to see results.
I'm going to vote for an M3 or E55 AMG for the replacement
-Will
Jan 8, 2011 | 11:55 AM
  #440
Quote: Hate to see it never reached its full potential. Would have been nice to see results.
-Will
I vote for something fast.
