Anyone do a VQ30-> VQ37 swap?
#41
#42
When I'm farther along and working on it more, then I was planning on it... I have a build in the sponsors section on G20.net, but i havent had time over the last year to do much on it. Hopefully i can start getting somewhere with it again soon, I'd start a thread on it then... I just dont want to start a thread, and then have it sitting around for weeks, months with no updates...
#43
#45
Is this a full ECU swap? Pretty sure those smaller valves won't help things without the VIAS's dialed in - the lower portion of the intake tract is a little straighter and the cams have no overlap (altima tuning) so I'm pretty sure the power curve relies more on intake velocity than scavenging. My guess is swapping these 07+alt/09+max motors needs to be approached a little differently than the 02-08(max) ones. I'm curious to know how it was done.
#46
#47
The put down some sick numbers with minimal mods in their original chassis though. I've seen 260whp through the 6 speed at 6500rpm with just intake and catback with the power curve looking like its still climing when it smacks redline.
#50
I didnt wanna comment but if an engine is running rough, 95% of the time its tuner error. My engine runs smooth, almost near stock feel, even with no EGR, EVAP, IACV, MAF still runs great.
#51
the 07/08 Maxima VQ35 should be the same swap as I did with the 02 VQ35?
That would also mean a 04-06 Altima will work too.. but the 07/08 Altima, and 09+ Maxima has a different engine and it would be more complex?
Do you have a link to someone doing the swap with an 08? At this point, I just want the car running again so I want to make sure the engine I buy will work the same. Of course using a newer engine will typically be less mileage on it so if the work is the same I want to go that route.
Thanks.
#52
I think a new engine is in my future.. So, I want to confirm;
Thanks.
Thanks.
Linkee...
http://forums.maxima.org/1-4-1-8-mil...ce-2010-a.html
#54
Not far at all: http://forums.maxima.org/all-motor/611201-yet-another-3-5-swap-thread-4th-gen-chasis-2008-vq35.html
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
HerpDerp1919
09-29-2015 02:02 PM
