Sponsored by:
Sponsored by: CARiD
cardana24's 3.5 swap
Old Jan 17, 2011 | 08:49 AM
  #241
Shift_Max's Avatar
any updates?
Old Jan 17, 2011 | 09:02 AM
  #242
cardana24's Avatar
Blown
Originally Posted by Shift_Max
any updates?
It's been cold I insulated my garage doors over the weekend so hopefully I can pick at it this week a little. The only thing I have done since my last update is I put the outer timing chain cover on. Next I need to flip the engine over and put the oil pans and baffle back on. Hopefully i will be updating the thread this week.
Old Jan 17, 2011 | 07:54 PM
  #243
cardana24's Avatar
Blown
man!! I need to work on this thing more often. I forget where I put things. I had to look for bolts for an hour before I could get anything done. Anyway I put the 3.5 oil baffle on, and I put the upper and lower 3.0 oil pans and called it a night. Here are a few pictures.
Old Jan 18, 2011 | 01:44 PM
  #244
cardana24's Avatar
Blown
is the correct tq for the crank pulley bolt really just 29-36ft/lbs? That what the fsm says but I remember it was hard to get the bolt out with my impact gun.
Old Jan 19, 2011 | 05:41 AM
  #245
ampire's Avatar
Wow, I thought it would be like 90 lb/ft on that crank pulley. I used a 9 foot fence post to break my pulley loose. Also, my 3.5 's oil baffle was bolted to the oil pan just like the 3.0 rather than the crank girdle, must be a 6th gen 3.5 thing. Don't forget to plug that coolant hole in the back with the 3.0's bolt if you use the 3.0 oil pan.
Old Jan 19, 2011 | 06:39 AM
  #246
cardana24's Avatar
Blown
Yeah, for some reason I do not think that is right. As for the oil baffle I am using the one that bolts to the girdle because I knew were all of the bolts were that hold it down. I took the one off my my 3.0 oil pan earlier because someone had mentioned something about arp rod bolts being too big or something...but that is not the case. You could use either one on my set up.
Looking at the tq specs closer it looks like you you tighten it to 29-36 ft/lbs. then turn it an additional 60-66*. I'm glad I bought that torque angle meter
Old Jan 19, 2011 | 06:33 PM
  #247
cardana24's Avatar
Blown
are the knock sensors the same on the 3.0 and 3.5? If they are the same does it matter what harness you use?
Old Jan 19, 2011 | 06:56 PM
  #248
ampire's Avatar
I would use the 3.0 knock sensor just because its on the 3.0 harness and you know it works well if your 3.0 worked well. You could measure the resistance across both and see if its the same and if the plugs fit the harness the same.
Old Jan 19, 2011 | 07:07 PM
  #249
cardana24's Avatar
Blown
That's what I want to do but I am having trouble finding my 3.0 sensor and harness....I don't know what I did with it
Old Jan 19, 2011 | 07:11 PM
  #250
ampire's Avatar
http://forums.maxima.org/all-motor/3...p-running.html
Summary: They say to use the 3.5's and that it will work with the harness, bottom post is pretty interesting however:
Originally Posted by JClaw
IMO the worst case senario is that the Knock Sensor will be less sensitive. The harnesses are identical, the diameter of the magnet base is identical. The 3.5 KS seems ever so slightly taller though. The harnesses both start out as two wires and then go down to one.
The 1995 ECU may not be able to read the 2002 KS right, which is another problem.
Interesting theories nonetheless, but 2000-2004 Maximas use the same knock sensor. 2000-2001= VQ30. 2002-2004= VQ35. (http://www.trademotion.com/partlocat...5&model=Maxima)
So the displacement has no effect on that. Nissan just decided to go with a crappier knock sensor in 2000.
You guys might also want to take a look at this:
http://www.courtesyparts.com/Merchan...Category_Code=
Look at how many applications the knock sensor has. This is the one I bought. Used on anything from V6 Maximas, 300zx to 4-banger Altimas and Sentras.
I always run 94 Octane anyway.
Old Jan 19, 2011 | 07:18 PM
  #251
cardana24's Avatar
Blown
he is saying it may not run with the 95 ecu according to the part you quoted.
Old Jan 20, 2011 | 03:31 AM
  #252
t6378tp's Avatar
Turbo 3.5
I used the 3.5 ks since it was already on the motor and the 3.0 harness. But I really don't think it matters
btw I did have a 2nd ks on my strut tower for the track cause if I would shift really hard the shock would make the car think it's knocking and pull timing during my shifts
Old Jan 20, 2011 | 06:08 AM
  #253
cardana24's Avatar
Blown
Are connectors on the harness the same? I am having trouble finding my 3.0 harness.
Wouldn't the knock sensor on your strut tower vibrate too on hard shifts? Or did that way give you full timing?
Old Jan 20, 2011 | 06:44 AM
  #254
t6378tp's Avatar
Turbo 3.5
The ks harness is in two parts and the 3.5 and 3.0 harness for the part that goes on the actual ks will plug into the other half connected to your engine harness. I left the 3.5 ks on the block and the 3.0 ks on the strut tower. It appears the 3.5ks is alittle too sensitive for the 4gen ecu. When the ks on the strut tower I always had full timing thru shifts. The only time it would pull timing on the tower is if I had wheelhop. You could also just put the 3.0ks on the 3.5block but due to the thinner walls of the motor it will still detect alittle more knock than with a de block.
Old Jan 20, 2011 | 07:29 AM
  #255
cardana24's Avatar
Blown
where can I get an egr block off?
this is the sku number I am finding in a few other threads, but when I go to courtsey there is no description of the part. SKU is 14017-4y900
Old Jan 20, 2011 | 01:40 PM
  #256
cardana24's Avatar
Blown
also, for the guys that are running an iacv in your 4.5 are you just remote mouting your 4th gen iacv? If not what are you doing?
Old Jan 20, 2011 | 01:47 PM
  #257
ampire's Avatar
My 4th gen IACV was remote mounted by the shop, and I had them install a PFTB with the IACV removed. The shop plugged the EGR as well. I have a 95 so theres very few sensors compared to later gen 4's.
Old Jan 20, 2011 | 02:51 PM
  #258
ajcool2's Avatar
We used the PF iacv. Plugged it in and was good to go.
Old Jan 20, 2011 | 02:53 PM
  #259
ajcool2's Avatar
I believe Pmohr posted the link to it in my thread. I'll check it out.
Found it: http://www.courtesyparts.com/14003k-...3-p-53839.html
Old Jan 20, 2011 | 03:03 PM
  #260
ajcool2's Avatar
Also we bypassed our KS with a resistor.
Old Jan 20, 2011 | 04:43 PM
  #261
cardana24's Avatar
Blown
That's the one for the exhaust...I am talking about the one that goes in the intake. I will be running aftermarket headers so there is noting for me to plug on the exhaust as far a egr.
Old Jan 20, 2011 | 04:44 PM
  #262
cardana24's Avatar
Blown
Plugged it in where? Do you have a picture of this? Does it use the same plugs as a fourth gen?
Old Jan 20, 2011 | 05:11 PM
  #263
essential1's Avatar
My axles cry for mercy...
If I'm not mistaken, you have 6th gen motor/intake manifold. I have a 5.5gen one for sale that doesnt have this hole for egr if you want.
Old Jan 20, 2011 | 05:50 PM
  #264
cardana24's Avatar
Blown
yeah, my engine is from an 05. I did buy an extra intake manifold so I will have to check that one out. If that one has the egr port too then I will PM you about that. Thanks for the offer.
Old Jan 21, 2011 | 06:02 AM
  #265
cardana24's Avatar
Blown
It turns out my extra uppper intake manifold does not have the egr port, so I am good to go on that.
I took my oil "T" out last night and just put the pressure sensor back in the upper oil pan. I took the water passage stud out of the right side head and put the plug in there from my 3.0 head. I also installed the 3.5 knock sensor with the 3.5 harness....will this sub harness work with the 4th gen wiring harness? I am curious because this sub harness is tied into wires that go to the 3.5 intake cam sensors that plug into the back of the heads.
I also installed NWP spacers on the LIM and then installed the LIM. Right now I am waiting on some water outlet gaskets so I can put the 3.0 water pipes on the 3.5 engine. My goal is to have the engine in the engine bay by the end of weekend....we will see how it goes.
Old Jan 21, 2011 | 06:29 AM
  #266
ampire's Avatar
I wish my UIM had a EGR port for the sniffer's sake, I'd trade ya but my car seems to be done lol.
Old Jan 21, 2011 | 07:27 AM
  #267
cardana24's Avatar
Blown
Just let me know. It will be hanging out in my garage.
Does anyone know if the 3.5 knock sensor harness will plug into the factory wiring harness on my 4th gen?
Old Jan 21, 2011 | 08:39 AM
  #268
ajcool2's Avatar
You have to cut down the 4th gen plug and it will plug in to the PF iacv. Its the same procedure as when you use a 5th gen IACV with a VI swap. I thought I had a pic but cant seem to find it.
Old Jan 21, 2011 | 08:59 AM
  #269
cardana24's Avatar
Blown
gotcha. I will probably just stick to remote mounting my 4th gen on since I already have the adaptor plate.
What have you guys done for mid pipes? I am going to run a jwt pop charger, but i was going to run a mid pipe between the throttle body and the MAF. Do you use a 3.5 or 3.0 mid pipe?
Old Jan 21, 2011 | 09:05 AM
  #270
ampire's Avatar
My IACV makes an annoying whistle/whine with its external mount, but my idle is about right at 700.
Just curious if your external mount will have same issue.
Old Jan 21, 2011 | 09:11 AM
  #271
ajcool2's Avatar
We didnt run a midpipe at all. Our setup was TB>MAF>JWT pop charger.
Old Jan 21, 2011 | 09:31 AM
  #272
ampire's Avatar
I have the stock intake lol.
Old Jan 21, 2011 | 10:07 AM
  #273
cardana24's Avatar
Blown
Can you post a picture of how the shop hooked up your IACV?
Old Jan 21, 2011 | 10:44 AM
  #274
ampire's Avatar
Edit: Hey got them up. I'll add them to your thread too.
The shop took these photos, they are not mine. Looks pretty professional!
Old Jan 22, 2011 | 06:59 PM
  #275
Requin6's Avatar
Wow Carson nice work!
I totally missed this thread. I will be checking it out regularly now to see your progress.
I have to make it down there one of these days and check out the setup.
Old Jan 24, 2011 | 06:42 AM
  #276
cardana24's Avatar
Blown
Even though it was cold as ish this weekend I got some stuff done.
I got the engine mount on and probably a few other things that I don't remember
Put the new front exhaust header on
Finally took the engine off of the stand
Installed a new pilot bearing
Then started taking my flywheel apart to put on a new friction surface
Old Jan 24, 2011 | 06:46 AM
  #277
cardana24's Avatar
Blown
Flywheel bolted back to the crank
ACT 6 puck sprung hub clutch bolted to the fidanza flywheels
One of my tool cabinets
And after a really long cold day....
Old Jan 24, 2011 | 08:03 AM
  #278
ampire's Avatar
Awesome looking good. Not much left to do.
Old Jan 24, 2011 | 08:13 AM
  #279
cardana24's Avatar
Blown
It's getting there. I am waiting on some gaskets and misc. stuff from the dealership and then I can make some more progress. I would like to get the rear header installed and bolt the transmission up while I am waiting on stuff. If I can stick with it, hopefully I will be trying to start it in a few weeks.
Old Jan 24, 2011 | 10:42 AM
  #280
Ceasars Chariot's Avatar
Old Maxima Legend
BEAUTIFUL !!
