Sponsored by:
Sponsored by: CARiD
Need opinions on camming a DEK.
Old Aug 29, 2010 | 11:16 PM
MoncefA33's Avatar
I'm at a crossroads now. I've got full bolt-ons and an EU hooked up and running, and I'm looking at getting cams.
I'm trying to decide between the following.
JWT S1 for VQ30 (256/256, 0.415/0.415)
JWT S1 for VQ35 (260/260, 0.428/0.428)
The S1 for VQ30 is more convenient to get ahold of. Aside from that, I'm looking to make maximum power between 4200-7200 RPM or somewhere in that range.
As far as the differences in duration/lift, what kind of change in power/delivery will I be looking at (qualitative or quantitative)?
Also, with regards to timing, since I can run the StephenMax adapters on the VQ35 cams, would it be a better choice for me to do those to fine-tune the powerband shift?
Thanks!
Old Sep 1, 2010 | 03:23 PM
MoncefA33's Avatar
Help...I haz to be faster than 3.5s...
Old Sep 1, 2010 | 06:25 PM
DrunkieTheBear's Avatar
Turbo'd Saab
vq35 cams cause more lift.
Turbo'd Saab
I think Jeff is selling his knockoff s1s with that setup...
Old Sep 1, 2010 | 07:01 PM
MoncefA33's Avatar
Yeah I'm trying to get Jeff's cams but I know another dude with the VQ30 S1s that are cheaper.
I know they have more lift, that's what my original post said.
Old Sep 3, 2010 | 05:14 PM
Turbo'd Saab
you will be happier with more lift...TRUST ME
Old Sep 3, 2010 | 05:38 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
It also comes down to where you set the intake timing with the VQ35 cams in a VQ30 engine.
Dyno2000 software shows better overall gains with the VQ30 cams with less low end loss. With the VQ35 cams there is about the same peak HP but more loss of midrange. That said it matters where the intake timing is set on VQ35 cams, I put in cam timing for when the CVTC is shut off.
Also past 0.4" lift there isn't much more flow in VQ30 heads, so that little bit of lift does not make much of a difference for power. It will put a little more stress on the valvetrain.
If I ever get around to camming a DEK I would go with the JWT VQ30 cams, but thats just me.
Old Sep 3, 2010 | 09:56 PM
MoncefA33's Avatar
98SE, thanks for your thoughts. Those were the lines I was thinking along too.
REDinLV
Aug 15, 2024 12:30 AM
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 29, 2015 06:44 PM
dvcamp
Sep 18, 2015 10:17 AM
