Sponsored by:
Sponsored by: CARiD
Quickest 00VI question, PIC INSIDE!!!
Old Oct 15, 2010 | 07:07 PM
OC_Nooby's Avatar
Ok I don't know what this hose does. Its always been left unhooked. Can someone tell me if I should just leave it unhooked or have it go to vacuum or boost?
I know the first nipple is for the vias (non vacuum) second is for the butterfly valve, but the third (red arrow), I never knew what it does.
Old Oct 15, 2010 | 10:00 PM
OC_Nooby's Avatar
I guess it wasn't that quick...
Old Oct 16, 2010 | 07:07 AM
FallenOne's Avatar
if you have doubts on it, just plug it.
Old Oct 16, 2010 | 07:55 AM
hornepirate's Avatar
i always just left that one un hooked
Old Oct 16, 2010 | 08:38 AM
essential1's Avatar
My axles cry for mercy...
If I remember correctly, that goes to the vacum actuator thingy for the butterfly valves in the lower intake manifold.
In stock form, it should connect to that vacum port on the rail that you have blocked off to the left of the question mark. It then leads to the other side of the IM where another rubber hose connects it to the vacum actuator.
I'm just going off memory so if i'm wrong, someone correct me.
Old Oct 16, 2010 | 09:26 AM
I thought the nipple above the brove plug was the vac port for the actuator for the lim valve?
Old Oct 16, 2010 | 02:22 PM
shadyonedeath's Avatar
thats vacuum for 2000 swirl valves. Dont need it.
I ran that hose attached to the gold nipple next to the vias fresh air port to seal it. (one on the right)
Old Oct 16, 2010 | 06:05 PM
essential1's Avatar
Exactly, I just looked at mine and remember that I blocked mine off too after I removed my swirl valves.
Old Oct 16, 2010 | 06:25 PM
ajcool2's Avatar
Always left this open
Old Oct 16, 2010 | 06:34 PM
i did too aj... doesn't create a VAC leak by leaving it open does it?
Old Oct 18, 2010 | 05:18 AM
maxboy325's Avatar
Mine is capped from factory
Old Oct 18, 2010 | 08:37 AM
OC_Nooby's Avatar
Perfect, Thanks!
lowpost99
Sep 8, 2015 05:06 AM
maximusrising
Sep 4, 2015 06:31 PM
dcardello
Sep 3, 2015 11:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
