Sponsored by:
Sponsored by: CARiD
Slightly high Idle 00VI
Old Dec 13, 2010 | 05:04 PM
dgoodhue's Avatar
I finished up my 00VI install tonight. 4th gen lower/00VI intake/4th Gen IACV/4th Gen Throttle Body/5th Gen Air box & Resonator w/ a fitting for IACV.
My idle is a little high 1200 park/850 in gear. Is some tweak of the idle normal? or do I have small vacuum leak somewhere. The car runs and drives fine other wise. (I just have to run a wire to engine compartment for the RPM switch)
Old Dec 14, 2010 | 06:15 AM
cardana24's Avatar
Blown
Did you do a coolant bypass on the TB? I had a high idle when I did a coolant bypass on the TB when the temps dropped close to freezing.
Old Dec 14, 2010 | 10:20 AM
dgoodhue's Avatar
I did do a coolant bypass (pretty much had to because the EGR is in the way of the 4th Gen TB coolant hoses). I am starting to think I might have a small vacuum leak. I will try spraying some carb cleaner around the intake, to see if I can locate it.
Old Dec 14, 2010 | 10:37 AM
cardana24's Avatar
Blown
maybe you do, but I know that a coolant bypass can cause what you are describing on a vq30de (I have also bypassed the TB on my VE30 and the idle does not bump up when it is cold). Here is a link I could find that I posted in, other people have this problem too.
http://forums.maxima.org/4th-generat...ded-trips.html
Old Dec 20, 2010 | 07:11 AM
dgoodhue's Avatar
You are right it is the Fast Idle Cam raising my idle. I couldn't find any vacuum leaks. The actual adjustable arm was also bent. I disabled it (ie removed it) It seems like i just need to give my car a slight bit of gas when it is cold out, otherwise it seems to idle fine.
Does anyone know if the fast idle circuit affects fueling in anyway?
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
