Aackshun's VQ35DE Swap Plans...
#81
So basically why you are saying is you want to have torque where it always drops off for these motors? The VQ37 is improved because of its crazy cam timing and IM but its still drops off, At that kind of RPM i dont think torque really matters also its a steady trade for HP and he was still at 210ft lbs. Thats 20wtq of his peak at 230. take into account that was an UNTUNED car. With a tune it would have been a much better torque curve something like aarons.
With the sentras short gearing i would want to extend my rev limiter so i dont loose the top end i had before.
And btw here is a 370Z dyno:
![](http://img.photobucket.com/albums/v176/justoneofmyhoes/NewStock370ZDynoBaseline.jpg)
just looks like a smoother version of deckdout's dyno lol
#82
Maybe because it's stock... After a few mods they look like....
![](http://www.the370z.com/members/semtex-albums-stillen-g3-intake-installation-picture1770-dyno-run-dynojet-after-installing-g3-intakes-i-did-so-we-could-compare-numbers-dyno-dynamics-306-4-dd-321-3-dj.jpg)
And TQ not mattering in the top end? Chas wha choo chiink, it is of my belief that TQ wins races and HP sells cars.
And Aaron's dyno (the one I posted) was the untuned one, when he tuned it, it turned into your typical VQ35, not something I want.
I might have to put this in my sig so I can stop saying it but...
If I wanted a bunch of top end HP with no TQ, I would have gotten a Honda.
#83
Because that is a stock 370Z dyno, you posted a modified one. Unless you get its Cam timing system i wouldnt expect to see a curve like that. It controls duration and lift. Its just the characteristics of a VQ to drop torque like that. Its really just the characteristic of an internal combustion engine lol.
Anyway things you should know by now, the intake manifold will make or break this swap more than. If your not concerned about appearance do something like sparks. And please dont be impressed only by high reading dynos, that is the easiest way to screw yourself over.
#84
Yes, I do know... Why do you think I'm getting an Altima motor?
High reading dynojets???? Really??? Either way... Have you been paying attention to what I have been saying the whole time?
#85
#86
I don't plan on having one, even though I'm quite sure I will get extremely similar lines @ WOT, the only thing I plan on having is TQ with my HP.
#87
![](http://www.nwpengineering.com/forum/275hp-Runfile-054-vs-013-raw.jpg)
I posted the Blue run because I liked the TQ curve better than his Red one.
//Edit I looked at it again, I like the red one too
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Then why say something about high reading dynos when all I'm concerned with is the curve of my power band?
#88
The one I posted was the untuned one... Well correction... Street tuned.
//Edit I looked at it again, I like the red one too![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Then why save something about high reading dynos when all I'm concerned with is the curve of my power band?
i think you kinda misinterpreted what i was saying anyway. If you up the compression like i was suggesting(HR pistons&shaved head) its a bump up in power across the board not just a high rpm. If you are gonna do a build you might aswell get some decent cams. Duration decides where you make power, Lift is the amount of power.
But do as you please, my suggestion would be let the thing rev.
#89
lol see what im saying. His dyno tune did him more favors in numbers and bragging rights, he went back to his street tune a couple of weeks after he had it dyno tuned.
Sure I feel ya on the pistons, I'll consider it, doubt it because of the allowed budget for my motor build, but if there's room in the budget for it, then I think ya I'd drop some $$$ for pistons... Especially since we have an HR core in the warehouse
I will let it rev if it has to (thus the headwork!), but if it doesn't have to then... it doesn't have to!
Officially kicks off today, I'm serious enough now to actually make a thread....
07+ Altima VQ35DE (Aiming for 20k-40k miles on the motor)
- Cams TBD
- Stock Z33 Injectors
- Minor Head Porting
- HR head gasket
- HR Head Bolts
- RU Water Pump
- RU Water Pump gasket
- 3.0L Timing Kit
- Cam Adapters
- FPR Regulator
- Walbro 255lph
- RevUp Oil Pump
- ARP Rod Bolts
- JWT ECU (Not going to happen till after the motor goes in sadly)
Anywho, just making a thread so I can not get side tracked by anything else, not being able to compete in IFO has really irk'd me the last few days and I really want to finish this and compete in one before the year is over with.
My goal date is 10/13/11 to get this car running with a 3.5.
Build thread to come when I have attained all of the parts.... Just made this thread to discuss and ask some questions I have along the way of collecting parts.....
- Cams TBD
- HR head gasket
- HR Head Bolts
- RU Water Pump
- 3.0L Timing Kit
- Cam Adapters
- FPR Regulator
- Walbro 255lph
- RevUp Oil Pump
- ARP Rod Bolts
#90
Cams for this motor are expensive and the 07+ Altima motor already has half-decent cams. But this would get you the most gains from anything else on your list. But $1000+ for cams during the Greatest Depression is a lot of cheese.
Waste of money, it'll get you nothing over the stock Altima injectors.
Waste of money. These heads flow great stock.
Waste of money. I don't think anyone has compared the stock 07+ altima head bolts with HR head bolts. If you were tearing down and building an engine, you should use NEW bolts anyways. If you were going FI, head studs would be better. The stock multi-layer metal head gasket is great and almost never fails. The only real difference between the HR and first gen head gasket is slightly better cooling. No difference at all in sealing performance.
Why not use the stocker? My stocker has 190k on it and is still in great condition. The engine oil lubricating these pumps make them last forever.
Another waste of money.
This one is questionable. I don't think anyone really knows except Nissan engineers if the 07+ Altima engine has stronger rod bolts or not, but ARP couldn't hurt.
Waste of money. The JWT will be tuned for 3.0L injectors and therefore you'll run rich with this ECU unless you can get JWT to change the fuel maps accordingly.
As for the Walbro pump...I had my stocker go out and purchased a new pump at Idiotzone or O'Reilly's a few years back and it was actually a Walbro pump inside the box.
#91
i dunno if i would consider a rev-up oil pump a waste of money depending on how high he plans on revving. if he is gonna stick around the stock rev limit or no higher than 7k then yea it probably is, any higher thou. Its some nice insurance.
#92
This isn't a first gen motor. Do you have any proof that the oil pump is inferior to the rev-up?
#93
#94
You need to hang out @ My350z more often my friend, you can find new cams from failed builds for $800 shipped awl dae (problem is, is it the right cams that I need)
Unless the 07+ injectors flow more than the -06 ones then no. Plus I can get them for nearly free, good insurance.
False, the TQ falling off @ redline says otherwise
True dat, I'll find out when tearing down the motor, but as for now new head bolts are the plan (they're pretty much the same price anyways).
I know this, I need every single degree cooler I can possibly get, my track day @ MSR was an eye opener for me.
Revving to 8k could possibly be the demise of a stock water pump.
Insurance incase I have to rev to a billion to get the power I want.
Again, doing the timing chain swap allows direct access to the crank... Why not? They're not that expensive....
Not if I tell them NOT to tune it for 3.0L injectors.....
Niiiiice!
Niiiiice!
My thoughts exactly, plus it's not that expensive.
#95
The only thing I request from this build is a good intake manifold. That's the biggest bottle neck other than the cams.
The altima one may work well though. Haven't really seen much from it.
The heads flow a **** load for stock heads.
#96
Something is starving the motor of air north of 6k, I'd love to see spark's intake manifold on a motor with cams, because we know on his setup the IM was not the bottle neck, his TQ still had a nice cliff towards his redline.
#97
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
#100
I bought a set 2.5 years ago, w/ double shims, HR springs and an install tool. Puss'd out and sold them about 1.5 years ago.
Now, finances are in much better shape ... so yeah
A bit obvious considering I just bo8ught a manifold of this nature.
![wall](https://maxima.org/forums/images/smilies/peepwall.gif)
#101
What cam specs are you going with?
#107
#108
Then again, if I want my peak to be further to the right, I can just dyno in a lower gear like I've seen in the past.
#110
The 350z, which has the same heads, achieves a 105% VE at some RPMs which proves the heads flow great, stock.
When I was doing my build, I used HR pistons and a thicker cometic head gasket because I had difficulty getting machine shops to touch the pistons. I used HR head bolts.
If you want to use the OEM HR gaskets, I have some that I'll cut you a deal on.
I suppose it's possible, but highly unlikely. There's no reciprocating mass. Never heard of a stock water pump failing because of revs. It's always because of a lack of cooling system maintenance or using the wrong coolant.
Ok, looks like you're right in that JWT will customize the fuel maps for the size injectors you specify, but then you have the other issue of timing with the HR pistons. The JWT will kill that motor, you'll have too much ignition advance.
#111
I don't doubt it, but $800 is still a lot for a set of cams. The fact of the matter is that we get sodomized on cams for our motors. But it's the only way to make any power at all above stock redline.
It's the only way to achieve what I want, cams + intake porting + gutting the IM, I will have VQ-esque TQ with my HP damnit!!! Screw the rest of the powerband, I only need about 1700rpm of glory!!!! Plus there's plenty of dyno data of 12+whp and like 15+ft/lbs untuned just by camming the motor
More fuel without more air is a fail. Since when do these motors run lean, NA?
Says everyone else who makes decent power![Nervous](https://maxima.org/forums/images/smilies/nervous.gif)
False, that's more a function of the stock cams, intake manifold, and valve timing a lot more than the heads. This isn't like some crappy head on some pushrod motor from the 80s made by drunk and/or high overpaid union members.
I meant to say velocity, I knew you'd pick on me for my poor choice in words.
The VQ35 heads have excellent flow, outflowing most if not all of the world's top performing motors
Wow? Awesome, but you still said a very painful word... SOME rpms.... I'm only concerned about 6k+ right now when these motors seem to make the most HP
It's not really going to decrease the overall water temperature. That's more a function of the radiator/fan combo than anything else. Our radiators are a little small for the power output you're talking about. My PSD puts out 300rwhp and it has a radiator that's 2x the area and about 2x as thick as my 4th gen max radiator. And of course a diesel expels less waste heat than a gasser for a given power level too.
I'm not concerned about where the temperature needle lies, I'm more concerned about it STAYING, why not do everything I possibly can to keep this motor cool on the road course?
I have no intention on changing the pistons, making high numbers is not my goal in a 2600lb car.
Sweet![Cool](https://maxima.org/forums/images/smilies/cool.gif)
I will have to research some more on the Z forums they spend more time about 6k than any of us Maxist over here, the water pump aint that expensive anyways....
Yes, if you're revving the 8k, I wouldn't trust the stock rod bolts. I'm not sure that I would trust the stock rods with ARP bolts. But on the other hand HR pistons weigh less which put less stress on the stock rods. But physics says that velocity plays a much larger role in kinetic energy than does mass. E=.5mv^2
My physics is rusty... But I do not recall that formula... Then again I am a C+ physics student, damn 7am labs....
Again, not running pistons at this point in time, unless I have some extremely convincing evidence, adding pistons to this project will not let me finish this before the year is over...
Sweet
#112
Don't want to keep beating a dead horse here, but man, with all that work building the motor it might be less work just to take my advice, do the full ecu swap, put in a stock 3.5 instead, you can't beat stock reliability and if the motor does blow you can put a new 3.5 right in without any effort. Throw on some NWP intake spacers, NWP VIAS delete, ES motor mount poly bushings, while you are at it. The only real downside is getting all of the harness bits and having to switch to a non cable driven throttle body sucks.
#114
Or you want me to do a 02-03 ECU swap then use the altima motor?
![Secret](https://maxima.org/forums/images/smilies/secret.gif)
#118
#120
hahah ok! I ment to txt u back, im going out of town so it would be next weet at soonest!
Just got some goodies in the mail today! Got everything i need for the re attempt!
