Sponsored by:
Sponsored by: CARiD
Aackshun's VQ35DE Swap Plans...
Old Nov 8, 2011 | 01:49 PM
  #241
aackshun's Avatar
Originally Posted by SurraTT
I am disappointed
lol
GL with build man!!!
we can all dream, but when you blow your motor earlier than you wanted to, reality hits and you gotta do what you gotta do.
I am still VERY confused on the piston clearance issue.
The HR Pistons have clearance issues in a DE block w/ a DE crank yet....
In Rod Length: DE = HR = 09 Maxima
Piston Height: DE > HR > 09
Deck Height: 09 > HR = DE
Crankshaft radius: HR = 09 > DE
*EDIT* THIS IS ALL WRONG, I CAN'T READ FSMS. I AM A N00B, kthx.
As it seems.... This is probably one of those things I will find out the hard way, we'll see if I will be uh dismantling uh motor Sunday....
Old Nov 8, 2011 | 01:55 PM
  #242
SurraTT's Avatar
HR Swap Pioneer
I understand!
http://forums.maxima.org/all-motor/5...hout-mods.html
Old Nov 8, 2011 | 02:04 PM
  #243
aackshun's Avatar
I know, I read over it, over, and over again, even on different forums!!!
According to the FSM that should NOT be happening... With a smaller crank radius, shorter piston, same deck height, same rods... Shouldn't you loose compression and gain clearance?
Old Nov 8, 2011 | 02:12 PM
  #244
SurraTT's Avatar
HR Swap Pioneer
Oh ok idk man. Im good at some stuff, def not a engine builder tho.
Old Nov 8, 2011 | 02:32 PM
  #245
aackshun's Avatar
Me neither :/ this is my first non arm-chair attempt.
I'm going to dismantle both of the motors this weekend, we'll find out first hand why these motors are here and to see if I can make a salvage ghetto build for 260whp.
Old Nov 8, 2011 | 02:34 PM
  #246
mightyMax95's Avatar
it also depends on how high or low in the piston the wrist pin sits.
btw...
all of the bad stuff has already happened to me! No more delaying (I hope)
Old Nov 8, 2011 | 05:47 PM
  #247
taz394's Avatar
Lol this thread started in august ? LOL damnit aaron ...
All i have to do on my setup is have the core as soon as frank takes it off ... Teehee
  #248
bamboomerang's Avatar
How is it possible for the HR pistions to have clearance issues w/ the block when they are shorter than DE Pistons??
The same reasons a piston that is 2.2mm 'shorter' overall can have a higher CR in the same block/head. The shape is different.
Also, the FSM only gives the measurement from the base of the skirt to the crown, it doesn't tell you the distance from the centre of the pin to the crown, which matters if interchanging between rods of the same length.
Old Nov 8, 2011 | 07:01 PM
  #249
aackshun's Avatar
Originally Posted by mightyMax95
btw...
It's coming to a close very soon, as soon as I run a compression test and do some investigating on the core VQ35DE that will determine what I'll be doing motor wise (Either two things... It jumped timing... Which I don't care about cause it'll be on 3.0L timing.... Or it's burnin up di oi-yul)
After some more thought this is what I have in my head for some ghetto fabulous powah:
02 VQ35DE Block
09 Pistons (Still a strong maybe, depends on what happened to the motor)
Z33 IM + Custom Elbow for a Q45 TB (Don't have a 02VI to use, but plenty o' Z manifolds)
5/8th Plenum Spacer
NWP Economy Spacers
Z33 Injectors
3.0L Timing + Cam Adapturz
The "Aackshun" Tuning Solution
That's it.... mated w/ my current tranny and exhaust, lolz will be had, and this is all going to be done for under $700
This.
I learned this while talking to the Maxima Mechanic in town, he broke it down to essentially everything I said was just not accurate at all and the FSM gives no idea to what the pistons, deck height, rod length really is in the VQ's
Old Nov 8, 2011 | 07:26 PM
  #250
shrek's Avatar
well...according to wikipedia :
The new engine block retains the same bore and stroke, but the connecting rods were lengthened and the block deck was raised by 8.4 mm to reduce piston side-loads. This modification, along with the use of larger crank bearings with main bearing caps reinforced by a rigid ladder-type main cap girdle to allow the engine reliably rev to 7500 rpm.
from what i remember (i'm more of a RWD VQ guy) the HR's deck heigth is more like the VQ40's(has a much bigger stroke) that's the reason you can't put an HR or VQ40 with a DE tranny
Old Nov 8, 2011 | 08:46 PM
  #251
when did i become "The Maxima Mechanic"?
Old Nov 8, 2011 | 09:02 PM
  #252
kzoosho's Avatar
have q45 maf and tb
Old Nov 9, 2011 | 06:49 AM
  #253
grey99max's Avatar
LandShark has Cosworth
I'll donate a new set of StephenMax's cam adapters.... gimme mailing address. Also have a couple of Q45 TBs... did you know that they mike out at 80mm ID, not 90mm? Unless my Harbor Freight digital micrometer has a low battery again.
Have you considered ARP rod bolts, HR head gaskets and bolts, and modding the block for better water flow because of the HR gaskets?
Old Nov 9, 2011 | 07:56 AM
  #254
J2FRESH's Avatar
^donate to me goddamnit hahaha jk jk (but seriously )
hey OP gl with your build
Old Nov 9, 2011 | 08:50 AM
  #255
aackshun's Avatar
WAKE UP, WAKE UP, YOU'RE DREAMING!
Originally Posted by kzoosho
have q45 maf and tb
We're in discussion already.
You. Are. Da. Man.
I've considered it, but this is a super ghetto budget backyard junkyard parts build, it was part of my original VQ35 build plan before I revamped it to the altima build.
Pshhhhhhhhhh
Thanks, this is all pending a compression test and visual inspection which is about to go down in an hour
//Edit:
Ok, any tips on discovering what could be an oil burner???
Also I did find a FWD manifold in stock.... I think I am sticking w/ teh Z manifold for simplicity, easy for me to have cut and welded the elbow for whatever the **** I want (Q45 TB)
Old Nov 9, 2011 | 06:24 PM
  #256
One trick is: if you have the heads off, coat the cylinders in grease and rotate the crank - if there are sealing problems/cylinder wall pitting - there will be little portions of grease that aren't 'swept' up by the rings.
Otherwise, in a perfect world you can perform a leakdown - or even just compare the carbon buildup on the the valves/head ports with a flashlight (oil in the U/L IM will be an earlier sign). If you have the oil pan off, from the bottom - locate the line where the rings 'stop' sweeping the cylinder wall, you'll see the point where the untouched crosshatch pattern meets the point where the rings touch the walls. You have limited access, but with a flashlight you can see whats left of the crosshatch where the ring does make contact. Compare how 'smooth' or 'crosshatched' each wall is, they should be fairly similar, but if 1 or 2 cylinders are completely smooth, or one side of a wall is extremely smooth and the corresponding other is fairly crosshatched, its a sign something is up (ie - the cylinder is an 'oval').
Old Nov 9, 2011 | 08:57 PM
  #257
aackshun's Avatar
Removing the heads will be a last ditch effort IMO, once I do that I'd MUCH rather go ahead and tear down the 09 motor @ work and pop in the pistons into the 02 block we have.
But this is some really helpful info!!! Thanks a lot!
Old Nov 16, 2011 | 10:29 PM
  #258
shrek's Avatar
updates?
Old Nov 17, 2011 | 06:23 AM
  #259
aackshun's Avatar
Trying to figure out what's the cheapest option for a VQ35... I have a few, just crunching #'s, in the mean time my car sits in the garage, this weekend I'm taking it apart though.
Oh and the core VQ35 we have here... Threw a rod, and the motor ceased, so it's only good for a full build.
Old Nov 17, 2011 | 06:31 PM
  #260
aackshun's Avatar
OAN....
OM NOM NOM NOM NOM
Old Nov 17, 2011 | 08:42 PM
  #261
OM NOM NOM NOM NOM
HAX!!! joo stow ma pic foo!!!
Old Nov 19, 2011 | 05:41 PM
  #262
shrek's Avatar
another needed part would be a q45 MAF with 3.5 intake piping to go with that q45 throttle body,...the result would be unrestricted airflow atleast until the IM's elbow ,....i plan on doing the same on a Z33 intake manifold but with a 3.5 elbow
Old Nov 20, 2011 | 04:45 PM
  #263
aackshun's Avatar
Tee-hee... There will no be elbow to my UIM
And the BBMAF is already taken care of also
I'm pretty sure I'm going to have terrible cold starts and bad idling, but whenever people ask I can give them the appropriate answer... because race car.
Old Nov 20, 2011 | 05:02 PM
  #264
Flava_24/7's Avatar
Boosted Panda
Talk is cheap, git er done already.
Old Nov 20, 2011 | 05:11 PM
  #265
aackshun's Avatar
Talk is cheap... so am I...
I hope to have it running by dec. 3rd
Old Nov 21, 2011 | 12:15 AM
  #266
J2FRESH's Avatar
goodluck man
Old Nov 21, 2011 | 06:55 AM
  #267
kzoosho's Avatar
I also have a z33 rev up upper and lower clam along with lim. U will need all to run the z33.
Old Nov 21, 2011 | 07:16 AM
  #268
aackshun's Avatar
So do I
Old Nov 21, 2011 | 07:37 AM
  #269
Flava_24/7's Avatar
Boosted Panda
Thats just around the corner, GL man.
Old Nov 22, 2011 | 06:57 AM
  #270
Shift_Max's Avatar
Keep us updated. Even better if you provide pics
Old Nov 28, 2011 | 10:38 AM
  #271
aackshun's Avatar
So...
Problem?
Next ting...
If one runs a BBMAF on my old skool 3.0 electronics... Could you use a VAFC (or whatever you call that damned thing) to make the correctiions? My car was NOT happy @ idle during the BBMAF test trials, but due to my richness it ran perfectly fine while driving... just @ idle it sounded like a Cammed SBC, which is awesome... at times... but I know I will find it extremely annoying eventually.
As much as I hate to have these silly things on my car... I may need it to get my car to idle correctly...
Old Nov 28, 2011 | 10:41 AM
  #272
haha, you said nipple...
Old Nov 28, 2011 | 12:03 PM
  #273
schmellyfart's Avatar
I want to say that the SAFC is the one that scales the maf signal for BBMAFs.
Do you have a wideband installed?
Old Nov 28, 2011 | 12:16 PM
  #274
aackshun's Avatar
Ah, good and jes I haz access to both and I plan on installing them for testing.
Old Nov 29, 2011 | 12:20 AM
  #275
shrek's Avatar
you will instal both for testing but the S-AFC,will need to stay there to keep the settings,what BBmaf are you running? q45??? and you'r on FWD vq35 injectors right?.----i want to instal my q45 maf on vq30 electronics with DE-K injectors...any impressions on how it drives after BBmaf??? better top end? more responsive? more low end?
sorry to bother you with questions but i'm eager to find how does a 3.5" intake and maf react on VQ30 electronics
Old Nov 29, 2011 | 06:20 AM
  #276
aackshun's Avatar
I know that, i'd rather not have any of that stuff on my car, I will try my best to run with as little aids as possible.
If it starts, runs, idles, I will not use the SAFC
Uhhh Home Depot/Grey99max BBMaf
No it'll be Z injectors.
And I tested a 3" maf on my VQ30, rough idle, but throttle response and low end was improved were the most noticeable things. Probably a bump in power overall, but this is all butt dyno results.
Edit, did some more research on the TB I have it's 80MM not 90 like I thought, so my intake piping and maf will all be 3 inches not 3.5.
Old Nov 29, 2011 | 10:06 AM
  #277
ajcool2's Avatar
My friend installed a 3 inch MAF on his Z it was dangerously lean. I just waited till I got my tune to install mine.
Old Nov 29, 2011 | 10:11 AM
  #278
But he'll be running larger injectors as well as open loop which is a richer map to begin with.
Old Nov 29, 2011 | 10:14 AM
  #279
SurraTT's Avatar
HR Swap Pioneer
Dont mess with MAF size, or injectors unless you can tune. Unless you like playing games. edit RWD Z injectors are fine tho, not big enough to throw stuff off
Old Nov 29, 2011 | 11:54 AM
  #280
shrek's Avatar
DE-K injectors are supposed to be z33 injectors at a lower fuel pressure ,...so combining a BBMAF with bigger injectors (not that big) ..will need only a slight tune with an SAFC to get perfect AFR's
so that means that :for guys doing a 00VI with lower IM should also upgrade to a BBMAF and would get really good gains and will only need to adjust AFR's a little to get them perfect
