Aackshun's VQ35DE Swap Plans...
I see no carpet or rear seats in that car.
Either way, I think it may be hard for a Maxima to beat a hatch that has been fully built up for an NA setup.
Hmmm, the AMS rules states "All seats (front and back), door panels, dash, and carpet (front and back) must remain inside vehicle. "
w/ the cars, those cars are for other classing. Not AMSI may just have to do some shady things to get my car down to a lighter weight when that magical day the Altima motor is in my car..... Meh that's another thread for another time, I just want a running maxima w/ some 12 sec time slips for now.
He fits into import face off all motor pro rules though.
BTW ID of the Z33 03-05 350z Intake Manifold is 71MM, ID of the back of the G50 Q45 TB is 84MM...... Mmmmm moar airrr.
EDIT: Do you see a spare 2010 Maxima UIM laying around anywhere?
I seen that too! Cool thing is they are in NC!
You're confusing the vids
2010 Maxima UIM and LIM....... 75mm and MUCH bigger ports.... or use a tapered spacer from 84mm down to 71mm, just to keep velocity high.... or get in line with sparks03max for a custom... all these choices.
And no, sollddd it
So.... Prototype a driverside 6mt axle for us
You know we do...
the hatch did follow all AMS rules apparently ...had all factory body panels, glasses, interiors, weight, and all the necessary safety, ie.. cage, scattershield, under carry tray, etc
and it was a stroked out K series to a 2.7L made 400whp ALL motor
... scary ... lol
Thats insane, very impressive but insane at the same time. LOL
Rev Up cams are going in the motor (courtesy of taz394)
Timing chain kit should be in some time this week, then buying a water pump for xmas.
Then sometime after xmas I can haz VQ35z?
but forreal ... idk if you can beat me with that vq35 swap
NOW if you had a DEK swap .... you might have a chance
all that whopping 220 raw whp and -200 tq might just have me ....
/sarcasm
/sarcasm
/tqless wonders of the world
Also, for future reference or for anyone reading this- To break crank pulleys loose- put the belt on, loop it around 360* & tuck it into itself & hook the extra loop around the motor mount. I probably have pics somewhere around but there should be youtube videos as this works on any car, I once bent a 3/4" round breaker on a tundra w/6' pipe attached to it this way!
What did you end up deciding on for cams? The last 3.5 swap I did had BC's, jwt 7,200, rev z33 IM w/spacers & portwork (And a HIDEOUS hood scoop), arp's, rev-up pump, cleaned up & portmatched heads and im's, etc etc etc. That car sounded like a beast, you're gonna love that thing once it's all done.
Quick summary
At the beginning I had planned on doing a cammed 07+ Altima motor with some minor port work and gutting the UIM, tuning achieved via some Z33 standalone (NOT UTEC!!!)...
As I later learned it really doesn't matter what cams you get, all of them are different in their own ways but you are able to fine tune your setup around the cams to get what you want out of them (EG plenum volume, intake size, length, head ports, valve sizes).
But I think I will end up going w/ BC's stage 2.
...But then I blow ups mah 3.0 (just a head gasket, but it's not worth my time to do just a HG) and I decide to to a ghetto 3.5 fixer upper which includes.... (All will be FS when I get the Altima motor BTW
)06 Max Motor 61k miles
Z33 UIM w/ 3.5ID elbow/pipe
Q45 TB
Q45 Maf
3.5" ID Intake
Rev-Up Cams
380CC injectors
3.0L Timing+Electronics
Super Ghetto Tuning Solution (Will go into detail later).
mated to what I already have which is....
OBX 3.5 Headers, 3" TP, Cattman 3", 6mt HLSD w/ a 4.1 FD
Lolz will ensue.
This will decimate all, after about 15 grand and some overnight parts from Japan....
Buying a water pump after I get paid today, and then that's it! Motor is getting re-assembled next week *squeeee*
something doesn't seem right. somehow i don't think he'd conform to AMS rules.
it's terrible, but it may work, i wish my 3.0 worked a little bit longer to fully test it, only thing I got to do was put the theory on paper, never got to implement it.
lol
