Sponsored by:
Sponsored by: CARiD
the swap once again
Old Oct 17, 2012 | 03:02 PM
Mr.Yammy's Avatar
the swap once again
hello im new here and i have a 2000 maxima auto and a 2002 3.5 6speed parts car due to being totaled from behind i was just wonder would it be a easy swap since i have every part from the 2002.........
Old Oct 18, 2012 | 08:38 AM
Aaron92SE's Avatar
NWP Engineering.com
That would be a great way to go about it. Having a parts car at your disposal will solve almost all your problems. Besides the engine, you'll need to swap over the engine control harness and the dash harness. Also, the ECU, NATS, and probably the instrument cluster. I've only done this swap in the 92 Maxima. So I'm not completely sure what problems you may run into with your 2000 Maxima.
Old Oct 26, 2012 | 09:43 PM
Blackwind's Avatar
if you think of it like this: "pick everything up and move it over" you should have no real problems at all, you will need to switch over the steering column also because if you are using EVERYTHING you will need that.
Old Nov 28, 2012 | 06:22 PM
nsnrider's Avatar
the swap would be straight forward, remove everything from the 5th gen. then remove and install everything from the 5.5gen over to the 5th gen. Enjoy.
Go for it.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
