Sponsored by:
Sponsored by: CARiD
4" Intake + 440CC
Old May 19, 2015 | 01:04 PM
maxima92se's Avatar
4" Intake + 440CC
Finally got around to installing the 4" intake and 440cc injectors and all I have to say is the intake is no slouch. I had to add fuel using the VAFCII just to be able to get the car to run at 14.7 idle(close to 22%). I have a UTEC that needs to wired up but the exchange rate took a dump and increased the cost of doing business (sending it to voltagedrop from plug and play wish there was someone in Canada that would do it) but I think I will need it becasue the VAFC does retard timing if you add fuel.
Anyway I just wanted to give anyone a heads up that is looking to run the same setup that the 4" intake and 440cc injectors WILL not run without adding fuel.
Old May 19, 2015 | 03:57 PM
NmexMAX's Avatar
dot dot dot ...
Yup, I was adding anywhere from 18-22%, even with the 1/17 in/out setting but keep this in mind too, as I saw a very aggressive timing curve even adding that much fuel due to the IPW.
Good posts in this thread about it. https://maxima.org/forums/dyno-discu...-bolt-ons.html
Old May 19, 2015 | 11:46 PM
george__'s Avatar
Yipiee
Please come help fellow Canadian ><
Old Jun 23, 2015 | 12:12 PM
03maximaguy's Avatar
is there a specific injector size that would even out the air flow of bigger air meter? Back in the day on the old mk3 supra we used to upgrade to the bigger Lexus v8 air flow meter housing. Going up to 550cc injectors evened things out so it would run without much adjustment.
Old Jun 24, 2015 | 07:36 AM
MoncefA33's Avatar
I run my Bosch 560cc injectors in all my customers Maxima 4" MAF/SAFC combos to get the flow correction as close to 0% as possible. There is some negative correction at full throttle/high RPM, which gives you some extra timing advance
I sell these injectors brand new all the time, I also build intakes and sell SAFC tuners as a complete package. If you have any Q's on this, let me know.
Old Sep 15, 2015 | 12:04 PM
95maxrider's Avatar
Lightly modded
Got any pics of a 4" intake/MAF setup on a 4th gen? I think my 3.5 wants more air! Approximately what whp do the stock 3.5 injectors max out at? Are 440s or larger really necessary for a NA setup? I'm thinking about cams and 4" intake for next year....
Old Sep 15, 2015 | 06:02 PM
95naSTA's Avatar
I have 380cc injectors and they're overkill for my 4" intake, 3" exhaust 4.7 gen hybrid setup.
Old Sep 15, 2015 | 08:21 PM
schmellyfart's Avatar
Here is a shot of mine.
Old Sep 16, 2015 | 10:09 AM
MoncefA33's Avatar
I only do them for 2000+, unfortunately.
Schmellyfart has a great looking 4" setup for 4th gens.
Stock 3.5 injectors max out around 280whp Dynojet.
Let me know if you need cams though.
Old Sep 17, 2015 | 10:05 AM
NmexMAX's Avatar
dot dot dot ...
Hadn't we heard of the guy @ 90% IDC @ 240 fwhp using the OEM Injectors? And I also thought the 335 Z injectors were good for 280?
Either way, I just hit you up re: 560cc injectors.
Old Sep 17, 2015 | 10:49 AM
MoncefA33's Avatar
It's possible, the IDC to WHP correlation isn't 100% accurate unless we know the car's A/F and the type of dyno it was on, and what RPM range it was making that power.
Old Sep 29, 2015 | 12:57 PM
NmexMAX's Avatar
dot dot dot ...
Can't find the dyno thread but he was in the low to mid 240's near 6k running fairly lean (13.8 or so).
Old Sep 29, 2015 | 02:29 PM
MoncefA33's Avatar
Stock ECU? 5.5 gen or 6th gen? Need moar info.
Old Sep 29, 2015 | 03:05 PM
NmexMAX's Avatar
dot dot dot ...
5.5 gen AT, normal bolt ons I/H/E, not 3" exhaust, stock ECU. I'll look again, can't be that hard t find in that dead dyno forum.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
