component install
Old Jul 14, 2002 | 07:43 PM
magnum's Avatar
component install
ok if nobody knows of an installer in south fl, im gonna have to do this myself. so what do i need to cut the holes in the door where the tweeters go? how much trouble are we looking at here
Old Jul 14, 2002 | 10:08 PM
loudmaxima's Avatar
Re: component install
where in south fl are you located?
Old Jul 14, 2002 | 10:49 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Go to Home Depot or Lowes, wtc.... and get an "adjustable" hole saw. It should run you about $15-$20. It should have all the possible sizes you need for your tweets.
--Don
Old Jul 15, 2002 | 12:27 AM
jmax
If I were going to ruin my image by putting tweets in the door, I would mount them as high as possible, in the sail panels. Or, in the bottom front corners angled up, almost straight up. Either way I would test listen to a musical / voice variety in both positions to decide.
Old Jul 15, 2002 | 06:27 AM
Mad-Marcus's Avatar
Check the hole size on the installation instructions for the mounting hole size. I watch my installer(a friend) do it. He ran the drill reversed at the beginning as this prevents ths the vinyl on the door panel from catching and tearing. After that layer has been cut reverse direction to the proper cutting direction.
I put my tweets as hi and as forward as possible and angle them up and torwards the windshield. I also have time alignment in my deck so the imaging and soundstage are very good.
Good luck,
Old Jul 15, 2002 | 01:58 PM
magnum's Avatar
thanks guys.. the thing i was most worried about was the cushiony vynil, but marcus answered that for me. im gonna put the tweeters kinds to above and closer to the dash in the doors, if you have a 5th gen, theres kinda a flat spot there.
2kmaximel
Sep 16, 2015 03:19 PM
Violator
Sep 9, 2015 10:14 AM
carid
Sep 9, 2015 05:06 AM
