The proper way to mount the crossovers
Old Jul 28, 2002 | 01:26 PM
Y2KMaxGXE-R's Avatar
I have ordered Infinity Kappas to replace my speakers in the front and the back, but both pairs come with crossovers. What is the proper way to mount these babies inside of the door panels so they won't get loose during sharp cornering and acceleration, he-he.
Old Jul 28, 2002 | 02:47 PM
mzmtg's Avatar
Minister of Silly Walks
I have the X-overs for my Eclipse components mounted like this:
Old Jul 28, 2002 | 03:21 PM
thanks, but I would rather try to hide them somewhere if I could...
Old Jul 28, 2002 | 04:16 PM
max'n out's Avatar
Anywhere there is space and no clearance problems, just screw um down...also you don't just have to put them in the door, under the dash and kickpanel area tends to have room.
Old Jul 28, 2002 | 08:26 PM
Sin's Avatar
Sin
Re: The proper way to mount the crossovers
I used double sided foam tape on the back of them, and stuck them to the dynamat. I also used glued a water shield over them, just in case.
Old Jul 28, 2002 | 08:52 PM
Redmax's Avatar
Redlinemax Owner
you can also use doble sided tape and stick them in the door.
Old Jul 28, 2002 | 09:29 PM
Mikesburn's Avatar
Why not under seats? It gets ventilated and it's very secure, dry!
Old Jul 28, 2002 | 09:30 PM
Sin's Avatar
Sin
Too much wiring. The shorter the run, the better the audio.
Old Jul 28, 2002 | 09:31 PM
max'n out's Avatar
You can, just put um up pretty far so they don't get kicked by back passengers...The only downside is running the wires all that extra way
Old Jul 28, 2002 | 09:45 PM
Mikesburn's Avatar
Yea, I did, it takes a little work, but it doesn't loose the signal, if you use good quality wires and right amp
Old Jul 28, 2002 | 09:47 PM
mb1's Avatar
mb1
I screwed my in inside the door pocket. I'll take pics tommorow.
Old Jul 28, 2002 | 09:49 PM
I would really prefer to keep them in the door panel..hope that tape works..btw what kind of tape is it and where can it be bought? I wish there were pics for me to see.
Old Jul 28, 2002 | 10:42 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Mine are in my trunk in a panel made for them....
Right Corey??
--Don
Old Jul 28, 2002 | 11:25 PM
Mikesburn's Avatar
Re: Re: The proper way to mount the crossovers
Right Corey??
--Don
jese, I'm thinking about the wiring you've done! It's even longer then mine under my seats!
Old Jul 28, 2002 | 11:27 PM
Pearl96Max's Avatar
Re: Re: Re: The proper way to mount the crossovers
But with a lil fiberglass, and some vinyl it looks real purty.
--Don
Old Jul 28, 2002 | 11:31 PM
Mikesburn's Avatar
Re: Re: Re: Re: The proper way to mount the crossovers
--Don
Uhh I bet!!!
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
