Audio (BOSE)
Old Jul 28, 2002 | 09:26 PM
ZeRo MaX's Avatar
Audio (BOSE)
I know this was said somewhere before.. but i did try to search for it... i'm thinkin' about upgrading my system.. but keepin' everything bose or maybe add an amp to the bose... i don't like the bose that much.. it's loud and sounds good.. but outside.. can't hear a thing.. i wanna show off my system.. and especially my sweet ride.. so what can i do to add a lil thump without using a lot of space in the trunk.. and not a lot of wires in my car.. and all..
here's my choices..
Bose system with a 10" in a box... no amp.. or 2 10" in a box with an amp. i'm not sure.. cuz i don't wanna use too much space.. so would a 10" work added on to the bose with out an amp work.. or do i need an amp to go wit the 10... i'm lookin' for somehtin cheap.. and that can add a lil more base to the works.. wonder what i can do...
and help?
Old Jul 28, 2002 | 09:39 PM
dwapenyi's Avatar
1st off, if you add a sub, you need an amp, point blank. Don't try adding just the sub. As for options with BOSE, look at the PD-2 and PD-4 here;
www.linkmeup.com
There are also others that are cheaper, the PD-4 and PD-2 are more top notch. Look for LOCs, or line output converters on the net. They do the same thing but are cheaper.
Also, given your concersn with adding a sub and keeping space, look at the JL audio Stealhbox. It's kinda pricey at around $400, but it is also oh so stealthy
http://www.jlaudio.com/stealthbox/maxima.html
If cost is dis-couraging, look at the infinity basslink.
http://www.justwoofers.com/Woofer_Pa...assLink-X.htm3
HTH
DW
Old Jul 29, 2002 | 12:59 PM
ZeRo MaX's Avatar
What does the PD-4/2 do to the Bose system??
I like the stealth box...
Old Jul 29, 2002 | 11:06 PM
dwapenyi's Avatar
The PD-4 makes an RCA line out so you can feed an external amp, since BOSE has no standard external connections.
Also, I forgot to mention, the basslink is an amp and sub all in one. So, no need to get an amp if you go that route.
DW
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
