Bose wire codes- 96 GLE
Old Jul 30, 2002 | 11:41 AM
phenryiv1's Avatar
Mod her. Ate her.
I found the wire codes below in a search for Bose wire codes, but they all pertain to the HEADUNIT. DOes anyone have the wire codes as they exist at the rear speakers? I want to tap at the rear speakers to use speaker -level signal to the converter (as opposed to signal level. I know that signal level should be "cleaner," but from what i have read on the .org, it is recommended that I use speaker-level signal fo rsome reason).
Also, can I tap into the BOSE amp turn-on signal to turn my amp on? I don't just want a 12V switched, b/c I want the amp on only when the stereo is on, not any time the car is on...
Can anyone help me out?
pink or pink / blue - bat (back up)
blue or blue / black - acc
red / yellow - ill cont
red / blue - light sw
green / white - amp on signal
brown - frsp lh (-) amp
yellow - frsp lh (+) amp
nca??? - grd
light green - frsp rh (-) amp
purple - frsp lh (+) amp
red - rrsp lh (+)
green - rrsp lh (-)
nca??? - grd
pink - rrsp rh (+)
blue - rrsp rh (-)
blk / red - ant sig
Old Mar 29, 2006 | 07:46 PM
Tim96I30t's Avatar
this is old but good to know...
Old Mar 29, 2006 | 09:30 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Please dont dig up old posts like that, its quite annoying.
Old Mar 30, 2006 | 01:38 PM
Tim96I30t's Avatar
Why I have a 96 I30??? and it helps to have in my CP so it is easy to find. Didn't need any help...thanks for your concern
Old Mar 30, 2006 | 07:53 PM
Pearl96Max's Avatar
Read the FAQs rather than digging up old posts...
Old Apr 1, 2006 | 08:10 AM
Tim96I30t's Avatar
what is so hard to understand about having it in my CP???? you don't have to post a suggestion when it is not wanted....
Old Apr 1, 2006 | 08:15 AM
Pearl96Max's Avatar
Everything is this thread can be found in the FAQs. Furthermore your sarcasm and attitude are not wanted, now this thread will be closed.
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
