question about amp and sub hook up....veterans please come on down!!!
Old Aug 7, 2002 | 07:47 AM
meccanoble's Avatar
Sports Button FTW
have Kenwood KAC 929 which says it works on 2 and 4 ohms...
i have Shiva MK 3 12" sub which says DVC 8 ohm...
i'm going to bridge the sub but i'm worried that since sub says 8 ohm and amp says 2 or 4 ohms...the quality might not be up to par...
talked to people on net and they say i should be fine especially since i'm bridging or I should line them up parallel....is this true? what do you guys recommend?
amp has 460 watts bridged at 4 ohms i believe the the peak for subs is like 600 or 800....
Old Aug 7, 2002 | 08:32 AM
mb1's Avatar
mb1
Re: question about amp and sub hook up....veterans please come on down!!!
This should be a perfect setup. If you run your dual 8ohm coils in parallel, the amp will see a 4ohm load. Then you can run the amp bridged at 4ohms mono. Most multi-channel amps can't handle a lower load.
Old Aug 7, 2002 | 08:48 AM
meccanoble's Avatar
Sports Button FTW
Re: Re: question about amp and sub hook up....veterans please come on down!!!
seriously? I feel all tingly when people say PERFECT setup....Pearl96max, i'll be at your house next week DAMMIT!!! i want to see what my investment can do
Old Aug 7, 2002 | 10:24 AM
Gates's Avatar
Re: Re: Re: question about amp and sub hook up....veterans please come on down!!!
Yep if you wire your Shiva in parallel then you'll get a 4 ohm load. If your amp puts out 460 @ 4 ohms that should be great for the Shiva.
Old Aug 7, 2002 | 04:42 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Not a problem, Im here!
--Don
Old Aug 7, 2002 | 06:35 PM
meccanoble's Avatar
Sports Button FTW
Re: Re: Re: Re: question about amp and sub hook up....veterans please come on down!!!
--Don
man, i just learned that i'm only gonna push like 230 to 300 to my sub cause its 230X2 at 2 ohms and 150X2 at 4 ohms...and since my one shiva sub is 8 ohms, i think i can only use 4 ohms on the amp....dam, i wanted that 460...oh well, i'll get a better amp in future....
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Socalstillen
Sep 26, 2015 12:01 PM
