Fuzzy pillar tweeter replacement
Old Sep 1, 2002 | 06:07 PM
cmcknite's Avatar
What size tweeters go in the tweeter pods in the A pillars? Are they easy to replace?
Old Sep 3, 2002 | 05:23 AM
mzmtg's Avatar
Minister of Silly Walks
Pull the pillars off and take a look....
Old Sep 3, 2002 | 06:19 AM
cmcknite's Avatar
Thanks............But no thanks!
I did not ask for a flame, I asked for an answer.
Smart a$$.....
Old Sep 3, 2002 | 08:05 AM
releasedtruth's Avatar
rilla dope
I think they are 1" and yes, they are pretty easy to remove and leaves a nice spot for new tweets if you so choose
Old Sep 3, 2002 | 08:15 AM
cmcknite's Avatar
Thanks for the help!
Old Sep 3, 2002 | 11:58 AM
Sin's Avatar
Sin
They may possibly be 1", but I'd like to see you mount another tweet in there using the same mount. Also, the opening for the tweet is not what you expect it to me.
Trust me, if you want to replace the tweet, open up your door, or go to a good shop that has worked on a 4th gen max before.
When you actually do see the stock tweet, you're gonna say, what they heck is that?
Old Sep 3, 2002 | 12:18 PM
rilla dope
True, I assumed the 4g was the same as the 5g as far as the tweet goes. I didn't mave much problem mounting another one there, wasn't as good a fit as the clarion that was in there, but I like the location myself over the door option. Now wiring a component set without drilling a hole in the door, that I haven't managed. I know the pros can do it, but that tube of wires is packed tight.
Old Sep 3, 2002 | 10:13 PM
max'n out's Avatar
The factory tweets are 3/4"...difficulty of replacment depends on how nice you want it to look if you reaim it or just try to drop it in...But some work will be needed.
Old Sep 4, 2002 | 06:34 AM
rilla dope
Break out the dremel, it's go time baby! Several pages list them as 1", but they are weak a$$ little things no matter the size. I think the GXE non-premium has no holes in the pillars so you can make your own, which would be ideal, but most of us have the "premium" crap in there. Anyway, good luck. Take some pics for the guys here. I may redo mine with another set, make a writeup on the subject..... If I'm not too lazy
Old Sep 5, 2002 | 12:22 PM
LeonBlackMax's Avatar
Ok guys like me help you out here.
I bought the kicker R13 Tweeter. I intalled it flush mount where the hole is int he door. It fits very nicely. All you have to do is trim a circle in the door panely where the weird looking one is already. These look like a custom install done by a shop and i did them myself. I'm very happy with the results. I will post pics whenever i get a chance. Oh and they are 3/4". But it really doesnt matter cuz all you have to do is trim the hole a lil bigger for a 1".
Oh and they sound very good so if your lookin for some nice tweeters then i recommend these.
Old Sep 5, 2002 | 02:33 PM
Tanman's Avatar
I drilled a hole in the right A-pillar and used one of the mounts that came with the tweeter. For the left side pillar, I couldn't get the drill to fit because of the dash, so I just stuck the tweeter there with double-sided tape, then put the A-pillar on. The pillar holds the tweeter firmly in place, and so far it sounds great.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
