Little Help With Install
Old Sep 19, 2002 | 01:15 PM
Stick Max's Avatar
i got a 95 maxima gxe
i just got new speakers for the back the Boston nx65 and i got a kicker box with 2 subs, two 10's Kickers. I got a Kenwood KAC-820 or 850 dont remember. the speakers are new, the subs and amp are used. i have all the wires but i have no idea how to install it. NOT THE SLIGHTEST CLUE. if anyone can help me i need info on how to hook them up from where to plug in the power, and where to put the ground wire, to where i should put my amp should i tie it down somehow. EVERYTHING if possible, if i have to hook it up to the back of my head unit. I NEED HELP. Please ASAP!!!! i wanna put it at 5 today its 4 right now. NO IDEA WHAT IM DOIN
new guy. thanx alot.
Old Sep 19, 2002 | 01:48 PM
JeffesonM's Avatar
living out of a maxima...
<pretend to be moderator>
Why don't you try posting this in the Audio forum?
</pretend to be moderator>
Old Sep 20, 2002 | 02:28 AM
maximamoose's Avatar
ehh, cut him a little break. he is pretty much a newbie. just direct him toward either the search engine(with a link), or the audio forum(with a link). thank you
Old Sep 20, 2002 | 06:59 AM
steeo's Avatar
Not as hard as it looks.
Out of the back of the radio there should be 2 block connectors
1. with 8 wire's these are the speaker wires
2no green (rear left)
2no white (front left)
2no grey (front right)
2no violet (rear right)
2. with about 6 wires (may vary)
1no red (to ACC, +12V DC)
1no yellow (continuous 12V DC)
1no black (earth)
1no blue (electric antenna)
1no orange (car telephone mute lead) optional
1no blue w/white strip (external amp lead)
If u have a pre-out lead this is for conecting to the amp, use a RCA lead and run this lead to ur amp (this is for the sound) and run a wire to the amp from the blue wire in your radio(this will turn on the amp when ur radio is turned on).
You will also need to run a seperate fused power lead from ur battery direct to ur amp (4-8 gauge wire). U can earth the amp with a wire running to the rear seat belt mounting point.(make sure it is earthed properly or u will run into trouble)
Wire the 2 subs to the amp(wiring will depend on if the amp is a 2 channel or 4 channel amp)
And secure the amp to something solid (trunk floor or to the sub box)
and secure the sub box aswell
PS. this job is not an afternoon job as all the wires will have to be run under the carpets and that is time comsuming
Hope this is of some help to u
Old Sep 21, 2002 | 08:15 AM
Stick Max's Avatar
Thanx alot exactly what i was looking for, except now my problem is those speakers didnt work. i didnt buy them a friend gave em to me... im gonna buy 2 jbl 12s for 200 is that good bad? let me know
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
