2 ohm's or 4 ohm's, what is this?....
i am looking at getting a sub and amp for my civic.
i want to get either this setup: ( better, but more expensive )
amp: https://www.onlinecarstereo.com/cara....asp?sku=12090
sub: https://www.onlinecarstereo.com/cara....asp?sku=10748
or this setup: ( good setup, less expensive )
amp: https://www.onlinecarstereo.com/cara....asp?sku=12091
sub: https://www.onlinecarstereo.com/cara....asp?sku=12511
this just depends on how much money i have to spend on the system, the second setup is cheaper, and is the one i am going for right now, but i am trying to see if i can get the better setup, maybe if i make my own box or something, i can afford it, i dunno.
i just want some good bass for when i'm in the car, i dont care for that loud bass that can be heard for blocks away, thats why i'm going with just the one sub.
now, both amps run at 150 watts at 4 ohm's and 300 watts at 2 ohm's.
the subs have a RMS rating of 300 watts, so i figure i run the amp at 2 ohm's and get the neccesary 300 watts out of it, right? will that work, or will i just mess up the sub and amp like that?
what is the difference at running the amp at 2 and 4 ohm's?
because my budget is limited, i am going to install this myself, so i really dont want to get the wrong stuff, and do something wrong during install.
thanks in advance.
btw, i already have a pioneer deh-7400mp mp3/cd player, and soon to arrive cerwin vega HED 6.5" components for the fronts and same model coax 6.5" for the rears ( the speakers will run off of deck power )
thanks in advance.
Re: 2 ohm's or 4 ohm's, what is this?....
Re: Re: 2 ohm's or 4 ohm's, what is this?....
Originally posted by bahmax
The first sub the W6 you will only be able to run at a 3 ohm load, meaning your amp will put out somewhere in between the 2 ohm and 4 ohm rating. If you want a 2 ohm load you will want the dual 4 ohm option on the W3. Of those choices perhaps amp #1 and sub #2 would be best. But for the money, I think you can do better
i dont know much about this stuff, like what goes together well, so i would really appreciate some help. i dont want to spend more than $500 on everything, that includes one amp, one sub, a box ( that i might make ) and the wiring.
thanks in advance.
thanks in advance.
Other than that I agree with ...first amp,second sub.
As far as running your components....do NOT run them off of radio power, it is not a clean enough signal to run components, and will cause distortion leading to blowing them. Most manufacturers will recommend strongly against doing this.
--Don
thats my current dillema, getting an amp for the components. they sound great right now, but lots of people, like yourself, have told me to get an amp, so i think i might do that first, like a 75 watts x 4 amp. then i'll work on getting the above sub and amp, thanks for the advice guys.
...ugh, i hate to be the Alpine lover on this board.
First amp is nice...
but i wouldnt go with JL sub.
I am the ex owner of 2 jl w3's...and yes they POUNDED, but for the SAME MONEY, i got TWICE the sub when i got Alpine Type R's. The Type R's are AMAZING...they are clean and they hit very hard...harder than the w3 i had...
Just a thought, alpine amp with alpine sub, also looks good together
jmlee44
Oct 2, 2022 02:13 PM
kjlouis
Nov 24, 2018 06:09 AM
jskirwin
Jun 8, 2016 08:49 AM
bryants95max
Oct 2, 2015 12:52 PM
