What gauge wire required for running two amps?
Old Dec 28, 2000 | 09:40 AM
CandiMan's Avatar
Say Candyman 5 times
I'm planning on installing 400W amp for sub bass, and a 140W amp for mids and highs. From the battery I'll run this wire to a distribution block in the trunk to feed both amps. I'm thinking a 4ga wire should handle the load from both amps. Also what fuse rating should be used for this wire. One fuse for the main power harness, and two seperate fuse for the amps.
Old Dec 28, 2000 | 11:35 AM
Whitemax's Avatar
Disco Biscuit
4 GA is fine
If you only have 2 amps, that more than enough. As far as amp fuses under the hood, I have 2 amps, and each amp is wired as 2, so each amp is fused at the amp at 50amps. I have an 80amp circuit breaker under the hood that is fine.
Old Jan 1, 2001 | 05:34 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Agreed
Definetly 4 ga is enough and the fuses he mentioned are plenty big.
________
California medical marijuana dispensaries
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
cruce91
Sep 20, 2015 10:23 AM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
