HEY- does DYNMAT work?
Old Nov 23, 2002 | 09:38 AM
iregula's Avatar
id like to minimize some trunk rattle and increase bass quality. whoever has experience with dynamat, can u guys comment ? thanks
Old Nov 23, 2002 | 09:40 AM
iregula's Avatar
hey guys...does DYNMAT work?
Old Nov 23, 2002 | 10:16 AM
metallic97gxe's Avatar
Master Will
yes it does work just apply to "rattle" points in your trunk...and deck lid....
Old Nov 23, 2002 | 10:18 AM
ereet's Avatar
Re: HEY- does DYNMAT work?
Our main problem with rattles is the trunk Lid. Dynamat is not very effective in this area, because it's hollow. The best way I've found to sound deaden the trunk in our cars is to dynamat (or dynamat substitute, whatever) everything on the inside of the trunk, and then use a spray-foam style sound deadener on the lid.
Old Nov 23, 2002 | 10:31 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Re: hey guys...does DYNMAT work?
the new dynamat xtreme is pretty good, much better than the original. they have specials on ebay sometimes.
btw why dont you put this in the audio and electronics forum?
Old Nov 23, 2002 | 11:31 AM
slimer's Avatar
Re: Re: HEY- does DYNMAT work?
posting in more than one forum i see. i guess its good to cover all the bases
Old Nov 23, 2002 | 11:42 AM
nadir_s's Avatar
vicodin ... gift of life
this'll get moved to the audio forum anyways.
I have bought dynamat many years ago for my first car (89 celica) and omg, that stuff is perfect. My car complete interior was practically lined w/ it. I had a killer sound system, and with it on, you can't hear it outside at all.
If you're gonna get dynamat, line the doors too w/ it so outside road noise will be minimized as well. Let us know how much you find dynmatat for, i'm really inteterested in gettin it. Don't forget, there are alternatives to Dynamat... i'm not sure of all of em, but there's stuff like eDead and raammat. You sometimes see discounts in the group deal forum. Good luck.
Old Nov 23, 2002 | 01:49 PM
scmaxima2k's Avatar
Ive got dynamat in my trunk and it works pretty well, but it doesnt completely eliminate all rattles. I could definately notice a difference after dynamatting but i think i could slap a few more pieces in a few other areas.
Old Nov 23, 2002 | 07:29 PM
95emeraldgxe's Avatar
dynamat is very thin, yet it does alot to isolate vibrations - what is it made out of exactly??
Old Nov 23, 2002 | 08:56 PM
Kanaka's Avatar
I think it's a asphalt type material.
Old Nov 23, 2002 | 11:12 PM
TylerBorg's Avatar
works great, more layers more dampening
cheapest i've seen is www.fatmat.com
Old Nov 24, 2002 | 01:18 AM
Jepht20's Avatar
Custom User Title...
what would happen if you covered your car in that? like behind door panels, under all carpet and seats...or is it just to reduce rattling?
Old Nov 24, 2002 | 02:19 PM
Bad97MaxSE's Avatar
It works well, but expensive
Old Nov 24, 2002 | 04:53 PM
Matt93SE's Avatar
STFU n00b!
You can do as much of the car as you want..
Yes, it works. Yes, it's expensive... Yes, it stinks the first few weeks of summer (unless you get the foil backed stuff like I used) but is it worth it? YES.
http://www.ee.utulsa.edu/~mblehm/pic...tereo/dynamat/
check the .mpg at the bottom of the list for a comparo. guess which door has dynamat on it.
Old Nov 24, 2002 | 05:14 PM
ny96max's Avatar
i get Dynamat 1/2 off
Ant
Old Nov 24, 2002 | 05:59 PM
ereet's Avatar
Half off is still pretty expensive .. I used b-quiet and still have about 10^3' of it lying around in my apartment. Very good for floors/flat parts. Not so good for vertical / upside down stuff. The adhesive isn't strong enough.
Old Nov 24, 2002 | 06:25 PM
Maximajism94se's Avatar
whatever, i can do that on my car, cept its from all the bondo in my rear quarter panel
btw...ne1 use that fatmat stuff??? is it goodish?
Old Nov 24, 2002 | 06:53 PM
Matt93SE's Avatar
STFU n00b!
sure.. anybody can do it with bondo, but that's easy.
don't worry, there's gonna be some in my left rear corner soon too.. some ba$$tard hit me in the school parking lot and left his signature on the corner. now if only I could find who has a black bumper with red paint on it.....
Old Nov 24, 2002 | 06:59 PM
d_warner's Avatar
Old Timer
DynaMat extreme is tha $hit. The original stuff is simply OK. I did my entire trunk, and it definately helps. I still need to do my rear deck lid, and back of the license plate. the stuff is amazing.
Old Nov 26, 2002 | 07:05 AM
TallB'00SE's Avatar
Extreme
What exactly does the aluminum foil do?
Old Nov 26, 2002 | 07:47 AM
cwally's Avatar
Re: Extreme
I used dynamat on my 5th gen and I got rid of all of my rattle inside of the car. Here is a link to the things that I did when I dynamatted.
http://forums.maxima.org/showthread....e+instructions
Old Nov 26, 2002 | 10:16 AM
DARTHSWAN's Avatar
I have Ultra on the trunk lid, and extreme and reg throughout the trunk. Very little rattle. Only thing you hear is the air vent in the trunk, when the air moves over it.
K
Old Dec 8, 2002 | 11:47 AM
SWEETSOUND2001's Avatar
It works but you shouldn't buy the brand name "Dynamat" when there are other much cheaper alternatives available. I have some pictures in my homepage.
Old Dec 8, 2002 | 09:59 PM
ballz3's Avatar
dynamat extreme
I used dynamat Extreme throughout my car. It helped TONS!. I used two layers on the trunk lid, and it actually did work very well, to my surprise. I also did the back license plate, and the front door panels for about 1ft around the speakers. My car was pretty air tight. Yes, the only thing that would move was the rear deck panel, which I think some thing under it for a spacer would keep it from slamming down, and you shouldn't hear any thing from it.
Old Dec 8, 2002 | 11:36 PM
meccanoble's Avatar
Sports Button FTW
hahah, yea i see it does work but i also see a bias knock, that second door didn't get the stressful knock the first one got but i can hear the difference, sounds real hollow (first one, which i would take to be the one without dynomat)
Old Dec 9, 2002 | 08:40 AM
xarfox
dynamat makes a huge difference by increasing SPL levels inside the car as well as decreasing the amount of rattles you get from bass
if you want to be cheap just dynamat the sub (trunk area), it will have the largest effect
if you want to go all out do the doors for the speakers as well
i recommend dynamat xtreme cuz its really easy to put on
about $250 worth will do your whole car
Old Dec 10, 2002 | 06:50 AM
releasedtruth's Avatar
rilla dope
There's one other thing that makes a serious difference. Poly fill is just the same stuff you find in 2 dollar pillows, I stuffed every metal panel in my trunk that had space with that poly stuff, even before I matted, it made a big difference, bigger than the mat imo. Just sandwich it into all the big crevasses in the trunk, then mat if you so choose. No one ever sees the poly fill anyway
Old Dec 11, 2002 | 05:07 PM
DanIAm's Avatar
poly fill sounds like a good idea, i just bought 32sq ft of extreme dynamat off ebay for like $123 shiped to my door and hopfully it works out nice, i notice a lot of rattle from my 3 12's but i also realize its 3 12's, theres probably always gonna be somthing that rattles but i also notice a lot from the spoiler since the clips or whatever holds it on broke on the end parts so im guessing thats causing some noise too
Old Dec 25, 2002 | 02:11 AM
Nismo3112's Avatar
Custom User Title
Exactly what i did, it eliminated most of the rattles, now if that stuff would stay in my trunk lid, id be rattle free
Old Dec 25, 2002 | 09:16 PM
Shugarhi's Avatar
not as familiar with the 4th gens, but you could also try porting your rear deck to depressurize your trunk some
Old Dec 25, 2002 | 09:25 PM
meccanoble's Avatar
Sports Button FTW
my experience with dynomat is that it works well in the doors. It gets rid of a lot of rattle but isn't 100% full proof, all systems are different and dynomat couldn't take out THEE BEST system IMO but what its great for is increasing the thump of bass. I hear a heavier thump when bass comes now than before. I would definitely use it again but if u r running like 600 watts of PURE power to the subs or something and have the super bomb system, i would go for something a little stronger, especially in the trunk....
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
