Two 4 Ga. or a 2 Ga. to a distribution block?
Old Nov 26, 2002 | 09:00 AM
spta97's Avatar
Hey all, some wiring questions here. I've got 1 JL Audio 500/1 amp running 4 Ga. to the battery and I'm going to be adding a 300/4 (which will also take 4 Ga.).
1) Am I better off running a 2 Ga. wire (or 0 Ga?) from the battery to a distribution block or just getting another 4 Ga. for the 2nd amp? I know it would be cleaner if I had the one wire, but is there a difference in performance?
2) Will a 2 Ga. wire be enough for two 4 Ga or do I have to go to zero Ga?
3) Will two 4 Ga wires have fitment problems when running them to the back of the car?
Thanks!
Old Nov 26, 2002 | 10:23 AM
DARTHSWAN's Avatar
Run the 2 ga. I have 2 Rockfords, Punch 200xi and 240x4. I run 4 ga to a distribution block, then 8 ga to the amps. I don't know the power output of those amps, so i don't know what to say.
Old Nov 26, 2002 | 11:20 AM
spta97's Avatar
It's 500 watts RMS for one, 300 watts RMS for the other = 800 total.
Old Nov 26, 2002 | 01:36 PM
DARTHSWAN's Avatar
If they accept 4 ga wire, do the 2 ga off the battery into the distribution block. Then 4 ga to the amps.
K
Old Dec 3, 2002 | 12:52 AM
kingrukus's Avatar
no more maxima...
Re: Two 4 Ga. or a 2 Ga. to a distribution block?
Well they say 4awg is good up to 1000wrms...however that is dependant on the length. To be safe, go with the 2 or 0 awg to a distro and do 4 from there, like what was mentioned above. I had both a JBL BP1200.1 and a Pioneer GM-X554 producing around 1500wrms and they were both connected off a single 4 awg wire. I am pretty sure though I shoulda used a larger wire, but then again I had the gains down.
Thanks!
shilov
Feb 19, 2024 09:40 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
