Amp question
Old Nov 27, 2002 | 10:02 PM
MoDiddy's Avatar
Amp question
Ok i dont know all that much about subs and amps....i was just wondering what wattage amp i would need to run 2 12's of
120oz Double Stacked Strontium Magnets
Power Handling: 1100 watts R.M.S.
Frequency Response: 20Hz - 500Hz
Efficiency: 90dB
PHAT 2" Multi-layer Foam Surround
Stamped and Balanced Aluminum Cone
2.5" 4-Layer AVS Voice Coil
Dual 4 Ohm Voice Coils
2 Ohm or 8 Ohm Operation
Mounting Dimensions: Depth; 6 3/4" Hole; 10 7/8" Diameter; 12 1/2"
Multi-connect Lug Lock Terminals
2200 peak power...thanks alot..
also i might consider just one 12 so gimmie feed back please on what amp i would need on 1 12"...Thanks A lot
MoDiddy
Old Nov 28, 2002 | 06:34 AM
jmax
The enclosure will determine how much power will be able to get max SPL without blowing the sub. You can do it two way. First is to check the makers web site and look up their recommendations for the enclosure size and style you plan to use. Second is that you could download a box building program and install the parameters yourself to come up with an estimation.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Socalstillen
Sep 26, 2015 12:01 PM
