Sony XM Install...What Do I Need?
Old Nov 28, 2002 | 04:52 PM
Maxima-Ness's Avatar
Hey, ive got a question for you smart Audio peeps. Im purchasing the Sony Xm Radio system for my 2K2 and I wanted to know how I would wire it so that I dont need the stupid tape player thing. Is there a way to have the tuner hardwired to the cars stock dash receiver? What will I need and while im at it, who has it cheapest but still a good company to buy from?
TIA!!!
Old Nov 28, 2002 | 06:20 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Re: Sony XM Install...What Do I Need?
TIA!!!
What you need in an RF modulated tuner, or also known as FM modulated. You will also need the Nissan antenna adaptor (both ways), and a little bit of knowledge in the car audio field. Really not difficult at all.
-_Don
Old Nov 28, 2002 | 08:05 PM
Re: Re: Sony XM Install...What Do I Need?
-_Don
Okay, I dont want one of those little controls for a modulator. all I thought I needed was the dash mounted tuner, an antenna and the kit that plugs into the back of our head unit. am I wrong?
Old Nov 28, 2002 | 08:07 PM
Pearl96Max's Avatar
Re: Re: Re: Sony XM Install...What Do I Need?
Unless your car is XM ready.....how would you control the stations?
and be able to read whats on?
--Don
Old Nov 28, 2002 | 08:13 PM
Re: Re: Re: Re: Sony XM Install...What Do I Need?
--Don
From the Sony dash mounted tuner.
see link here....
http://www.xmradio.com/catalog/produ...956&type=Tuner
Old Nov 29, 2002 | 05:46 AM
Pearl96Max's Avatar
Ok.......like I said you need to connect the RF modulator.
--Don
Old Nov 30, 2002 | 01:46 AM
GundamWZero's Avatar
You won't be able to do what I think you are trying; to use your headunit to control and display your XM radio. If Sony makes a headunit that is XM ready, then yes they would have made something that would connect the XM tuner to that head unit. So far, I have noticed only Kenwood and Pioneer with XM Ready headunits. There may be more, I don't know. I have the XM Ready Headunit and the XM tuner, however until I get another IP-BUS cable to connect the CD changer to the XM Tuner I will still have to use the RF Modulator.
Old Nov 30, 2002 | 01:53 AM
Re: XM Radio
Okay, I checked www.carstereomall.com. They DO have an XM Ready headunit for Sony. However, I would have to check if Sony makes the IP-BUS cables to be compatible with Pioneer XM tuners or do they make them compatible with the Sirrus XM tuners..........
Old Nov 30, 2002 | 02:08 AM
Re: Re; XM radio
Okay, peep this........
There is a Sony XM radio tuner. A Sony XT-XM1 satellite tuner. It is compatible with select Sony Unilink recievers, and the antennas are still sold separately, so you can pick up a inexpensive antenna. You have to find out if your Headunit is a Unilink Reciever. Then you'll have to pay $249.99. Go to http://sm.crutchfield.com/cgi-bin/S-...u.asp?c=3&s=45
Hope that helps.....................
MaDMaX024
Jun 24, 2001 09:35 PM
BeatJunky
Jun 9, 2001 04:14 PM
pkim23
Apr 22, 2001 03:57 PM
tony
Feb 22, 2001 01:29 PM
tony
Feb 18, 2001 02:53 PM
