zapco z600 and 2 12' L5 solobaric
Old Dec 3, 2002 | 03:30 PM
jdmmax's Avatar
ok
so here it is i am installing a system for a friend need to know how to wire the subs to the amp.
amp
Zapco Z600
bridged mono 325watts x 1 @ 4ohms
900watts x 1 @ 2ohms
amp info link below
http://www.zapco.com/nosound/index3.html
go to:
products
competition
zsieries
z600
woofer
kicker 12' L5 2 ohm speakers
sould i wire it in parallel or in series
thanks frank
Old Dec 3, 2002 | 04:52 PM
SWEETSOUND2001's Avatar
You have to wire the subs in series (minus from one sub, plus from another and plus/minus connected together) so your amp will get a 4 ohm mono load and will produce about 600 watts.
Anton
Old Dec 4, 2002 | 01:16 AM
jdmmax's Avatar
is it the same for a dual voice coil speaker. sorry forgot to mention that.
Old Jan 24, 2003 | 03:26 AM
imported__Q_'s Avatar
If the woofers are D2s, then wire each woofers voice coils in series so each woofer becomes a 4 ohm woofer, then parallel them down to 2 ohms at the amp, bridged, this should get the most out of this amp.
If they are D4s, then do the same thing, however you will only get about 1/2 as much power out of the amp.
If you were just doing short burps, and they are D4s, you could parallel all 4 voice coils down to 1 ohm at the amp, and at the peak spl frequency the amp should actually see about a 2 ohm load due to working impedance rise, but if that's the case, you should port the box(es) at right about 4-7Hz below the peak burp frequency.
Old Jan 24, 2003 | 07:11 AM
1MAX2NV's Avatar
So they are dual voice coil 2 ohm subs?
Old Jan 24, 2003 | 09:11 AM
jdmmax's Avatar
i believe so.
Max4Good
Feb 20, 2003 10:06 AM
max'n out
Jun 18, 2002 08:16 PM
max'n out
Jun 17, 2002 06:14 AM
seanqlee
May 21, 2002 09:22 PM
Mikesburn
Feb 27, 2002 04:04 PM
