installation help
Old Dec 12, 2002 | 05:55 PM
TRuFLiPpeR's Avatar
yeah, i donated....so?!?
installation help
does anybody know of a website, or other place, where you could get instructions on how to remove door panels, trunk panels, rear seats, headliners, etc., from a 2k2 max? i'm planning to dynamat the entire interior and run some 0ga wire to the trunk. any help would be much appreicated. thanks!
n1cK!
Old Dec 12, 2002 | 08:59 PM
ocMax's Avatar
Re: installation help
n1cK!
Its not that hard just look around for screwws and clips. also where are u? maybe i could help i used to install car electronics profesionally. also if you dont mind me asking. . y r u dynamating ur whole car and y the big wire?
Old Dec 14, 2002 | 11:37 PM
TRuFLiPpeR's Avatar
Re: Re: installation help
m
i'm in san diego, point loma....i may have went a little overboard when i said i was dyanmating the whole car. i am dynamating most of the trunk, and all the doors where the speakers are. i plan to dynamat around the kickpanel that i am going to use, but i might just use some fiberglass baffle. also, the big wire is for the two amps that i will run, the ppi pcx-4125 and the pcx-2200. both require 4ga each. i've looked around for screws and clips, but it's kind of hard on the firewall. that's my biggest problem. i've already dynamatted most of the trunk and found lots of places to route the wire through.
n1cK!
Old Dec 16, 2002 | 10:16 AM
spta97's Avatar
Try this:
Removing Rear Deck
(this one has some links to pics on removing trunk pieces)
Removing Bose stereo
Oh, when you remove the fastners from the trunk, its a good idea to mark the holes with a felt pen. This way, you can know what not to dynomat over (there are a billion holes in the sheet metal) and it makes it easier to put things back together!
spta97's Avatar
Try this:
Removing Rear Deck
Old Dec 16, 2002 | 10:56 AM
spta97's Avatar
Try this:
Removing Rear Deck
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
