Need opinions on JBL BP600.1 amp
Hey guys, I was hoping to get some feedback from people that have had experience with a JBL BP600.1 amp or any other JBL model amp. I have an Infinity Kappa Perfect 12.1 and I'm looking to power it with 300-400watts rms. I looked at the JL 500/1 but it's a little out of my price range. Would this JBL amp be sufficient or are they're other types of amps I should be looking at? Thanks everyone,
Nathan
Nathan
Originally posted by TL@altimas.net
if you have the dual 4 ohm version of the 12.1 it should work great..
I had a 1200.1 and never had a problem..
I've got the JBL 600.1 running through an Alpine Type R, which is basically the same sub as the Kappa Perfect. I've got almost full power running through it, and it sounds great!
Plus, its got a cool little light at night
If it were me, I'd go with the 180.2 instead then.. a little more power (360w), and will work great as a front amp when you upgrade later
Nathan
Originally posted by LeonBlackMax
get the 600.1, if you ever get another sub the power will be there waiting for you, they are great amplifiers and dont get all that hot, especially at 4 ohms, they barely get warm.
Nathan
Re: Need opinions on JBL BP600.1 amp
Great amp...I have it's bigger brother, the 1200.1, and it runs cool at 2ohms. As mentioned above, you will not be making full use of that amp at 4 ohms. Also, be warned, that this amp does not have a subsonic filter. A subsonic filter proves very very very usefull when working with a ported enclosure (i ripped apart 2 subs on the 1200.1 because of no subsonic filter). However if you are going to only be running sealed (that is what the perfects are meant for anyhow), then you should be fine.
Nathan
Nathan
Re: Re: Need opinions on JBL BP600.1 amp
Nathan
Re: Re: Re: Need opinions on JBL BP600.1 amp
No problem. At 4 ohms the bp600.1 will put a rated 300wrms, where as at 2 and 1 ohm it will put out the rated 600wrms (realistically closer to 700). I suggest that you either get the dvc version of the perfect so that you can create a 2ohm load, or some time down the road, get a 2nd perfect that is in svc 4ohm configuration (so that the 2 svc 4 ohm subs together will create a 2 ohm load in parallel).
Hey thanks for the helpful info. So what you're saying is that if I get the BP600.1 I won't be using it to its full potential because I'll have it at 4ohms but I can always get a 2ohm sub right? And yes I will be putting the Kappa in a sealed enclosure so the subsonic filter issue shouldnt be a problem. Anymore suggestions would be much appreciated.
Nathan
Nathan
rukus = good advice..
as far as bass boost goes.. I don't like using it, it puts an unnatural hump in the response that I don't care for..
but both are good amps, if you can get the D4 version like the king said, do that..
Okay I've been shopping around the net for this amp and just about all the people on ebay wont ship to my location in Toronto, Canada. I tried Etronics.com out of NY because they have the cheapest price ($184.99) but they charge tons in taxes. Are there any places that will ship to Canada and have good prices as well? Anyone from the .org that can get a hold of one of these amps for a good price?
Nathan
Nathan
Nathan
Nathan
All I can say is that when you finally find someone to ship to canada, you will be paying a lot in customs. I bought my jbl bp1200.1 a few years ago for 350US, and it came out to be ~700cdn after shipping/duty. I got my amp off of carstereo2000 (or something like that), off of e-bay, and I suggest you do not get it from them, as I am pretty sure that my amp was used before I got it (it was supposed to be new).
Nathan
Nathan
Nathan
REDinLV
Aug 15, 2024 12:30 AM
popdedop
Sep 11, 2015 11:17 AM
