PAC install instructions for '02 non bose
Old Jan 9, 2003 | 06:46 AM
gfys12's Avatar
I used search and went through many posts but did not find details.
My questions.....
Anyone have a good write up on installing the PAC SWI-X Steering Wheel Radio Control Interface in a 2002 SE non bose with pioneer HU installed?
Also I read something that there is some type of "eye" that needs to be pointed at the HU. Where do you guys place this?
How big is this thing?
Thanks......
Old Jan 9, 2003 | 07:23 AM
spta97's Avatar
Re: PAC install instructions for '02 non bose
My questions.....
Thanks......
I don't know if the wires differ on the non-bose system, however if you have the 5 wire harness coming from the steering wheel it is probably the same as the bose. You can check this:
5th gen wiring diagram
I was also looking for a good place to install the eye. The whole unit is a black box about 1" x 2.5". It has a wiring harness coming out of it (that has connections for power, ground, switched, and a wire that connects to the steering wheel harness - white in my 2k3 Bose). The "eye" is just a small IR lense (about the size of a LED) that is attached to the unit via a bigger gauge wire (about 13 - 14 ga.). The wire is about 2 feet (or less) long.
I originally mounted mine behind the stereo but I could not find a place for the eye to get a line of site. I was just messing with it the other day and I'm going to mount it in the ceiling where the sunglass holder / map light is located. it fits nicely in there, and if you run the wire down to the rear view mirror you have a perfect line to the stereo.
Also, I can get power, ground, and switched from up there so I just had to run the white wire to the back of the stereo where the steering wheel harness was located (you have to use 2 resistors and splice them together with the white wire and the respective wires on the harness).
Sorry I don't have a writeup, but hopefully this will help.
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
Johnny9595
Sep 3, 2015 05:18 AM
